Upgrading Siebel Seeded Workflows
Upgrades: All upgrades.
Environments: All environments
This topic is part of an upgrade process. See Performing a Siebel Database Upgrade.
Customizations to seeded workflows were saved and migrated during upgrade, but you must manually reimplement them in order for them to work properly.
In Siebel CRM Release 7.7.x, workflow definitions were relocated to the Tools Repository.
To upgrade a seeded workflow
In the Siebel Repository, revise each seeded workflow so that a new copy is created with a new version number.
Manually merge in your customizations, and then deploy the workflow.
