Code Setup and Control Quick Reference
The following table lists methods that you can use to perform setup tasks and to control the flow of logic in Siebel VB code.
Statement Purpose Reference
Shell
Starts a Microsoft Windows application.
Call Application Method
Call
Transfers control to a subroutine.
Call Subroutine Method
Sub name
Creates a subroutine.
Create Subroutine Method
Function
Creates a function.
Create Function Method
Type userType
Declares a custom data type.
Declare Custom Data Type Method
Declare Sub Declare Function
Declares a procedure or a function.
Declare Procedure Method
Const constantName
Declares a symbolic constant.
Declare Symbolic Constant Method
Environ
Returns a string from the operating system environment
Get Environment Setting Method
Nothing
Sets an object variable to not reference an object.
Remove Object Method
AppActivate
Sends keystrokes to a Microsoft Windows application.
Send Keystrokes Method
Clipboard
Accesses the Microsoft Windows clipboard.
Use Clipboard Methods
