Convert String to Uppercase Method
The Convert String to Uppercase method converts lowercase letters to uppercase letters. It returns a copy of this string. Note the following:
The conversion occurs according to the country specified in the Microsoft Windows Control Panel.
It accepts any type of argument and converts the input value to a string.
If the value that the string argument contains is NULL, then this method returns a Null variant. For more information, see Variants.
Format
UCase[$](string)
For information about the dollar sign, see Usage of the Dollar Sign.
The following table describes the arguments that you can use with this method.
Argument | Description |
string |
A string or string expression. |
Example
The following example converts a file name that the user enters to uppercase letters:
Option Base 1
Sub Button_Click
Dim filename as String
filename = "c:\temp\trace.txt"
filename = UCase(filename)
End Sub
