2. Upgrading the Oracle Financial Services Lending and Leasing Database
2.1 Pre-requisites
2.2 Audience
This document is intended for system administrators or application developers who are upgrading Oracle Financial Services Lending and Leasing Application.
2.3 Conventions Used
Term
Refers to
Home Directory/$OFSLL_HOME
Oracle Financial Services Lending and Leasing Home Directory
Application
2.4 Upgrading Application Database
An upgrade is a process of updating an existing version to its higher version. For example, upgrading Oracle Financial Services Lending and Leasing from 14.8.0.0.0 to 14.9.0.0.0.
2.4.1 Upgrade to 14.9.0.0.0
Choose ‘2’ as the installer option at the ‘Selecting the Install Type’ stage, then the script runs the upgrade installer.
Respond to the prompts and continue. For more details, refer to ‘Installing Upgrade’ section in Database Installation Guide.
While installing the upgrade, the installer performs the following tasks:
  1. Stop the running services, if any.
  2. In case you see the below prompt to stop the queue for loading objects, press ‘Y’ and press Enter to confirm.
  3. In case the Schema is EBR (Edition based Redefinition) enabled,
    • You will be prompted as below. Press 'Y' and enter to continue.
    • Enter the Edition name and press enter. Confirm 'Y' when prompted.
  1. Install the upgrade
  2. Recompile the invalid objects and complete installation.
  3. Install the database object of web services by referring to the instructions detailed in chapter 2 ‘Installing WebServices Database Objects’ of WebServices Installation Guide.
  4. Grant access/permission by doing the following:
In the prompt, enter the user responsibility. You can also specify ‘ALL’ to provide screen access to all the users in bulk.
Further, you can customized the access through Setup > User > Access screen as detailed in setup guide.
Note
2.5 Upgrade Fusion Middleware
There is an infrastructure upgrade required (from 12.2.1.3.0 fusion middleware to 12.2.1.4.0 fusion middleware) when upgrading from OFSLL 14.8.0.0.0 to OFSLL 14.9.0.0.0.
