Known Issues
The following table lists the known issues in version 4.3 of Oracle Communications Session Monitor.
ID Description Severity Found In
30920564 Meditation Engine or Fraud Monitor installation shows error on the PSA GUI while installing on X8-2 server. 3 4.3.0.0.0-103.
Workaround: Refresh the PSA GUI. After the refresh, the correct status of installation is shown.
Resolved Known Issues
The following table provides a list of previous known issues that are now resolved in 4.3 GA.
ID Description
27862634 HTTP APP GET request failing with nginx 301 Moved Permanently response.
30089603 Fraud Monitor 4.1 reports less number of incidents as compared to 3.3.
29881497 Upgrade from 4.0.0.3.0 to 4.1.0.4.0 takes a very long time to upgrade.
30163935 The user role View Media Info cannot be assigned.
30173584 VSI shows dropped packets and is causing Red Bars. Need to understand why VSI is overloaded and dropping packets
30245588 In Operations Manager 4.2, non-preferred numbers are not greyed out, although the corresponding system setting is set to TRUE.
29395243 Some calls are missing in OCOM from the Calls section.
30233801 In OCSM 4.2, REST API does not work with TLSv1.
30161712 In OCSM 4.2, there is a delay of up to 1 hour between the alarm and the call
30051871 Secure LDAP (LDAPS) Support needs to be configured.
30385707 Broadsoft reported that Mediation Engine is down after upgrading from 4.1 to 4.2.
30398761 The DPDK script configure_dpdk.py which is listed in the Installation Guide to be used, fails.
30360536 ISUP body not decoded.
Operations Manager is not able to parse and display the ISUP body in some cases.
26046378 Operations Manager 3PCC Call Correlation Support for 2 Outbound calls.
23188252 RFE: Chat Anonymization enhancements.
30655385 Maximum concurrent sessions do not work with external authentication.
30517390 Header and content privacy setting fails to anonymize contents of the message if the subject is not present.
30646618 RTP headers cannot be downloaded after V4.2 upgrade.
30644297 4.1: Not able to get login page and setup page.
30765160 Red bars can be seen and correlation failures after upgrade to 4.2 Release.
30727470 Red bars are seen after upgrading to 4.2 P1 UDP traffic.
30779429 The reason the header information is missing in the Call Summary Page.
30526923 OCSM encountered segfault in 4.2.
30202303 Filtered calls are not exported.
30760460 Unencrypted ESP packets support on OCOM.
30561182 Empty call flow diagram for few calls.
30968880 Message Flow RTP stats defect.
