Introduction
The Oracle Communications Session Monitor Release Notes provide information about new features, enhancements, and changed functionality in release 4.3
Session Monitor Supported Hardware
The products within the Oracle Communications Session Monitor suite are supported on Oracle, Sun, and HP systems.
Table 1-1 Supported Hardware for Oracle systems
| Component | Requirement |
| Server | The following severs are supported:
| Network Adapter | The following adapters are supported:
The Oracle X7-2 and Oracle X8-2 server supports Session Monitor Installation using RPM installer only.The following table lists the hardware supported for Oracle systems.
Table 1-2 Supported Hardware for Oracle Sun systems
| Network Adapter | The following network adapters are supported:
The following table lists the hardware supported for HP systems.
Table 1-3 Supported Hardware for HP Systems
| Server | The following servers are supported:
| Network Adapter | The following network adapter s are supported:
| Driver/Chipsets | The following drivers/chipsets are supported:
Hardware Requirements for Production Systems
For production systems, Oracle recommends completing a sizing exercise with Oracle Customer Support. Higher performance hardware may be required, for example, in cases with:
- High levels of monitored traffic
- High numbers of concurrent users
- High volumes of historical information
On the Mediation Engine machines, Oracle recommends using a RAID-10 array for the operating system and the database. A separate RAID-5 array is recommended for storing long-term data.
Hardware Requirements for Demonstration Systems
For development or demonstrations systems with little network traffic, the following table lists the minimum requirements to install any of the Session Monitor machine types.
Table 1-4 Hardware Requirements for Demonstration Systems
| Component | Minimum Requirement |
| Processor | 2.6 GHz Intel Xeon processor, 64-bit with 8 processing threads |
| Memory | 8 GB RAM |
| Disk Space | 80 GB storage on a hardware RAID controller |
| Ports | 2 Ethernet ports |
Session Monitor Virtualization Support
This section describes the software and hardware requirements for Session Monitor virtualization.
Hypervisor Support
The following hypervisors are supported:
- Oracle VM version 3.4
- VMware vSphere ESXi 5.x/6.x
- Kernel-based Virtual Machine (KVM)
Virtual Machine Requirements
The following table lists the minimum requirements for the virtual machines.
Table 1-5 Hardware Requirements for Virtual Machines
| Processor | 8 vCPUs |
| Memory | 8GB RAM |
| Disk Space | 80GB |
| NIC Card | 1Gbps vNIC |
In virtualized Mediation Engines, 50,000 concurrent calls (1 SIP leg per call) have been tested successfully.
Host Machine Requirements
The physical machine that hosts the virtual machines should contain at a minimum the hardware resources that are required to host all the virtual machines, in addition to the hardware that is required for the hypervisor.
Session Monitor Operating System Requirements
Oracle Communications Sessions Monitor (OCSM) is offered as a set of Linux applications. The latest version of OCSM 4.3 is tested, benchmarked and certified on Oracle Linux platform. Oracle Linux is binary compatible with RHEL kernel, and OCSM has been tested with RedHat Compatible Kernel. Customers who want to use OCSM with RHEL are encouraged to load and test OCSM on the version of Linux on which they are planning to deploy. In this case, performance and capacity characteristics may vary from those tested while running OCSM on Oracle Linux. When OCSM is deployed on RHEL, Oracle will continue to support OCSM, and in case of issues that Oracle Support determines to be related to RHEL, the customer will be directed to work with RedHat support organization for issue resolution.
The following table lists the supported operating systems for running Session Monitor.
Table 1-6 Supported Operating Systems
| Product | Version | Notes |
| Oracle Linux 7 x86-64 (64 bit) | Version 7 to Version 7.7 (with Oracle UE Kernel for Linux) | By default Oracle Linux installs Kernel 3.
Oracle recommends that the latest Unbreakable Enterprise (UE) Kernel 4 for Linux is installed. |
| Red Hat Enterprise Linux 7 | Version 7 | See clarification above. |
- You must configure a network device when installing Oracle Linux 7.
- If required, update the DPDK drivers.
Session Monitor Connectivity
Following are Session Monitor connectivity details:
- One AE (OCOM's MEC feature): Supports up to 64 MEs
- One ME (OCOM, OCCPM):
Supports up to
- Native-Only Probes:
- Media+Sig ; Signalling-Only: 128
- Packet Inspector: 16
- Embedded-Only Probes
(SBC as a probe):
- < 500 parallel calls per SBC: 1k (might require some manual tweaking, unlimit open files)
- >= 500 parallel calls per SBC: 128
- Mixture of SBC and native probes: 128 (individual limits still apply)
- One Probe (OCOM, OCCPM) or
SBC-probe can be connected to up to:
- Probe: 2 MEs
- SBC: 8 MEs
- One ME (OCOM, OCCPM): Connected to up to 1 AE
Session Monitor Software Requirements
The table lists the supported client browsers:
Table 1-7 Supported Client Browsers
| Browser | Version |
| Microsoft Internet Explorer | 8 or higher |
| Mozilla Firefox | 1.5 or higher (on any operating system) |
| Apple Safari | Any version, including Safari for iPad |
| Google Chrome | Any version |
| Opera | 9 or higher (on any operating system) |
Compatibility Matrix for Session Monitor
| Product Name | Version |
| DPDK | 19.08 |
| ISR | 6.3 |
| SP-SBC | S-Cz8.3.0
Works with Operations Monitor and Enterprise Operations Monitor |
| E-SBC | S-Cz8.3.0
Compatibility Matrix for Fraud Monitor
| DPDK | 19.08 |
| ISR | 6.3 |
| SP-SBC | SCZ 8.3.0
Works with Fraud Monitor and Enterprise Telephony Fraud Monitor |
| E-SBC | SCZ 8.3.0
| SDM | 8.2.1 |
Session Border Controller Supported Versions
The table lists supported Session Border Controller (SBC) versions.
Table 1-8 Supported Session Border Controller Versions
| Product | Versions |
| Enterprise Session Border Controller (E-SBC) |
| Session Border Controller (SBC) |
Database Support
The following databases run in concert with Oracle Communications Session Monitor.
MySQL Enterprise Edition
- 5.5.54
- 5.7.10
- 5.7.24
Session Monitor System Architecture
The Session Monitor system works by capturing the traffic from your network, correlating it in real-time, and storing it in indexed formats so that they are available for the various reports offered by the web interface.
The Session Monitor system architecture has three layers:
- Probe layer: This layer is responsible for capturing the traffic from your network and performing the Media Quality analysis. The probes send meta-data for each of the signaling messages to the Mediation Engine layer and analyze the RTP streams locally, sending the results of this analysis to the Mediation Engine layer.
- Mediation Engine (ME) layer: This layer is responsible for understanding in real-time the traffic received, correlating it and storing it for future reference. This layer is also responsible for measuring, managing, and storing the KPIs. In the common case, there is one ME per geographical site. It is possible, however, to have the probes from multiple geographical sites sending the traffic to a single ME. It is also possible to have multiple ME installations in the same geographical site.
- Aggregation Engine (AE) layer: This layer is responsible for aggregating the global KPIs from all the MEs linked to it, and for the global search features. In a typical setup, there is only one AE for the whole network.
Each of the three layers supports high-availability by deploying two identical servers in active-passive or active-active modes of operation. For small setups, it is possible to run the probe layer and the ME layer on the same physical hardware. The AE layer always requires its own hardware.
From the Session Monitor products perspective, the Operations Monitor and the Control Plane Monitor (CPM) run on the Mediation Engine (ME) while the Mediation Engine Connector (MEC) and the Fraud Monitor products run on the Aggregation Engine (AE).
Upgrade Information
DPDK upgrade is required. Release 4.3 supports DPDK version 19.08. After upgrading to 4.3, see the Session Monitor Installation Guide for information on upgrading DPDK.
Licensing Changes
- L107092 Enterprise Operations Monitor with Fraud Protection
- L107093 Enterprise Operations Monitor, Basic Edition
These changes affect the Enterprise product portfolio only.
The Enterprise Operations Monitor base capacity license (L98611) and the Fraud Monitor license (L106475) are not available for new purchases starting November 5 2019. Please refer to the Enterprise Operations Monitor licensing document for details on license descriptions/restrictions/dependencies for the new licenses.
