Upgrading MySQL
This chapter provides the instructions for upgrading MySQL from release 5.5.54 to 5.7.10 and from 5.7.10 to 5.7.24.
Upgrading MySQL from Release 5.5.54 to Release 5.7.24
Session Monitor version 4.3 supports MySQL 5.5.54, 5.7.10, and 5.7.24 versions. If you have upgraded from a previous Session Monitor version, your system will be running MySQL 5.5.Upgrading MySQL will not create any loss of data. But all the services will be stopped during this upgrade. The upgrade time depends on the size of the database.
Before upgrading MySQL, configure yum proxies and repos as yum must connect to the configured repos. Refer to "Configuring Proxies and Repos".To upgrade to MySQL 5.7.24 for the latest performance updates and improvements, perform the following steps in the maintenance window:
Log in to the Session Monitor server console as the root user and run the following command to load the environment variables.
source /opt/oracle/ocsm/ocsm_env.sh
Stop the Session monitor services.
pld-systemctl stop
From MOS, download the below patch from Patches and Updates section:
p28822761: MySQL Database 5.7.24 RPM for Oracle Linux / RHEL 7 x86 (64bit)
Download the zip file p28822761_570_Linux-x86-64.zip and place it under /root or any directory on the system.
Unzip the file.
[root@ocsm ~]# unzip p28822761_570_Linux-x86-64.zip
Install all the rpms extracted from the zip file.
yum install -y mysql-commercial*.rpm
Complete all the MySQL table migrations from release 5.5 to the latest release 5.7.24.
mysql_upgrade
This command may take some time to complete depending on the DB size.
Once complete, run the following command to move MySQL configuration file, my.cnf:
cp /opt/oracle/ocsm/etc/iptego/my-5.7.cnf /opt/oracle/ocsm/etc/iptego/my.cnf
Restart the mysqld service.
systemctl restart mysqld.service
Start the Session Monitor services.
pld-systemctl start
(Optional) Verify the MySQL version installed.
mysql --version
Upgrading MySQL from Release 5.7.10 to Release 5.7.24
Session Monitor version 4.3 supports MySQL versions 5.5.54, 5.7.10, and 5.7.24.Upgrading MySQL will not create any loss of data. But all the services will be stopped during this upgrade. The upgrade time depends on the size of the database.
pld-systemctl stop
Patch 28822761: MySQL Database 5.7.24 RPM for Oracle Linux / RHEL 7 x86 (64bit)
p28822761_570_Linux-x86-64.zipand place it under /root or any directory on the system. -
Unzip the file.
mysql_upgrade
This command may take some time to complete depending on the size of the database.
pld-systemctl start
mysql --version
