This manual is designed to help you to quickly get acquainted with the Oracle Banking Enterprise Limits Management system. It provides an overview and takes you through the various steps involved setting up and maintaining the Oracle Banking Enterprise Limits Management system.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and pressing <F1> on the keyboard.
This manual is intended for the following User/User Roles:
Role |
Function |
Back office data entry clerk |
Input functions for funds |
Back office managers/officers |
Authorization functions |
Product Managers |
Product definition and authorization |
End of day operators |
Processing during end of day/ beginning of day |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at
This manual is organized into the following chapters:
Chapter 1 |
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Limits explains a series of maintenance options facilitated by Oracle Banking for Enterprise Limits Management. |
Chapter 3 |
Annexure 2 - Value Dated Facility discusses the feature to maintain facility details based on a specific value date. |
Chapter 4 |
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
You may find the following acronyms/abbreviations in this manual.
CASA |
Current Account and Savings Account |
DDA |
System that holds the CASA account and balances |
ELCM |
Enterprise Limits and Collateral Management |
ECA |
External Credit Approval |
FCUBS |
Oracle FLEXCUBE Universal Banking Solution |
GW |
Gateway |
HTTP |
Hyper Text Transfer Protocol |
ID |
Identification Number |
ORMD |
Oracle Revenue and Billing Management |
UI |
User Interface |
VD |
Value Date |
XML |
eXtensible Mark-up Language |
This User Manual may refer to all or some of the following icons:
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
For more information refer to the Oracle Banking Enterprise Limits and Collaterals User Manuals on:
