This illustration shows the Cash Flow Edits window or pane. Select the checkbox next to the Cash Flow Edit rule that you want to View, Edit, Copy, or Delete. Click Add to create a new Cash Flow Edit rule. You can search a Cash Flow Edit rule using Rule Name, Folder, and Dimension fields. The search list shows the Cash Flow Edit details with Name, Creation Date, Created By, Last Run Date, Last Run By, Status.
