Using General Keyboard Shortcuts
The following table lists and describes the supported
general keyboard shortcuts.
| Keyboard Shortcut | Description |
| <TAB> |
This is the primary key used by all keyboard users to move
from each control that can accept focus.
| <SHIFT>+<TAB> | This keyboard combination works the same as <TAB>, except it works in the opposite direction. For example, it enables you to switch focus to the previous control or field, rather than the next control or field. |
| <SPACEBAR> |
Use for:
| <ENTER> |
Use to:
| <DOWN ARROW> |
Use for:
| <UP ARROW> | Works the same as the <DOWN ARROW>, except it enables you to move in the opposite direction (previous instead of next). |
| <LEFT ARROW> | Works similar to the <UP ARROW>. |
| <RIGHT ARROW> | Works similar to the <UP ARROW>. |
| <HOME> | When in the context of tabs, sets focus to the first tab. |
| <CTRL>+<HOME> | Takes you to the very top of a page. |
