Toggle Switch The following table lists the keys to use to work with toggle switches to enable and disable some of the options. Key Description <TAB> Navigate to the next available toggle. <SHIFT> + <TAB> Navigate to the previous available toggle. <SPACEBAR> Toggle a particular switch.
