Description of Components
The components of the ISR consist of the following:
- RSS - Record Store Server
- CIS - Control Index Server
Each of these components are described in the following paragraphs.
Record Store Server (RSS)
The RSS consists of the following components:
- Call Manager - Using call state, channel and route information Call Manager handles account and platform-related call decisions.
- SIP Agent - Processor for SIP-related events.
- Channel Map - State storage and reference for active call information and available channels.
- Local Route Cache - Binary tree store of route-based information for call and recording decisions. Initializes reflecting the dashboard-driven route_config database table with periodic (configurable) updates mirroring changes in the table.
- Call Stats Updater - Processes call metrics and refreshes call and recording tables with call statistics.
- RTP Port Manager - Returns available RTP ports and maintains port status for SIP Agent.
- Event Queue - Prioritizes and stores call and other events
- Cache Manager - Local audio store which makes available audio content such as busy messages and beeps during recording.
- Mixer Channel - RTP support
for sending, receiving, buffering, transcoding and mixing audio which contains
the following:
RTP I/O - RTP input and output stream handling.
Audio Mixer - Audio stream processing for injecting platform or route-specific audio.
Recorder Thread - Manages audio and file stream processing.
- RSS API - offers ISR remote call and recording services along with resources for route and channel references in ISR database.
- RSS API Servlet - Service handles ISR XML-RPC API requests.
- REST API - REST resource for ISR API commands.
- Archiver
- SIPREC - Used to interact
between a Session Recording Client (SRC) and a Session Recording Server (SRS).
Codec Negotiator - Responsible for generating supported Codec list for SDP offers and answers to offers.
SIPREC Processor - This component is responsible for processing SIPREC requests. When the SIP Proxy receives a SIPREC call, judging by multipart bodies, it passes call context and SIPREC Metadata to SIPREC process. The SIPREC Processor then parses the Metadata of the Recording Session (RS) into a structured data object. The SIPREC Processor, in turn, passes the call context back to SIP Proxy with flag set for detailed instructions on SIP signaling. Note: Final SIP action for SIPREC from SIP Proxy, afterward, is also affected by Call Manager.
