ISR Linux Users and File Permissions
This section lists the
Permissions.
| Component | Type | File Name | Permissions | Owner |
| Recorder | log | /opt/isr/logs/recorder/ISRService.log | -rw-rw-rw- | isr |
| Recorder | log | /opt/isr/logs/recorder/recorder.log | -rw-r--r-- | isr |
| Recorder | recordings | /opt/isr/Recordings/*.* | -rw-rw-rw- | isr |
| Recorder | binary | /opt/isr/rss/isrl.elf | -rwxr-xr-x | isr |
| Converter | log | /opt/isr/logs/converter/converter.log | -rw-r--r-- | isr |
| Converter | log | /opt/isr/logs/converter/converterService.log | -rw-r--r-- | isr |
| Converter | binary | /opt/isr/rss/converterl.elf | -rwxr-xr-x | isr |
| API | log | /opt/isr/logs/api/api.log | -rw-r--r-- | tomcat |
| API | config | /var/lib/tomcat/webapps/IsrApi/WEB-INF/web.xml | -rwxr--r-- | tomcat |
| API | code | /var/lib/tomcat/webapps/IsrApi/**/*.* | -rw-r--r-- | tomcat |
| EEN | log | /opt/isr/logs/ApiLog/ IsrApiEvent.log | -rw-r--r-- | tomcat |
| Archiver | log | /opt/isr/logs/Archiver/ISRArchivalService.log | -rw-r--r-- | tomcat |
| Archiver | recordings | /opt/isr/ArchivedRecordings/*.* | -rwxrw-r-- | tomcat |
| Archiver | code | /var/lib/tomcat/webapps/ISRArchivalService/**/*.* | -rw-r--r-- | tomcat |
| Archiver | config | /var/lib/tomcat/webapps/ISRArchivalService//WEB-INF/web.xml | -rw-r--r-- | tomcat |
| RSS Web Server | log | /etc/tomcat/server.xml | -rw-rw-r-- | tomcat |
| RSS Web Server | log | /var/log/tomcat/catalina.<yyyy-mm-dd>.log | -rw-r--r-- | tomcat |
| RSS Web Server | log | /var/log/tomcat/localhost_access_log.<yyyy-mm-dd>.txt | -rw-r--r-- | tomcat |
| Dashboard | log | /var/log/puma/puma.log | -rw-r--r-- | puma |
| Dashboard | config | /opt/isr/puma/puma_config.rb | -rw-r--r-- | puma |
| Dashboard | binary | /usr/bin/puma* | -rw-r--r-- | puma |
| Dashboard | siyrce | /usr/lib64/ruby/gems/2.3.0/gems/puma-3.4.0/**/* | -rw-r--r-- | puma |
| Dashboard | log | /opt/isr/logs/dashboard/production.log | -rw-r--r-- | puma |
| Dashboard | config | /var/www/dashboard/current/config/*.* | -r--r--r-- | puma |
| Dashboard | source | /var/www/dashboard/current/app/**/* | -r--r--r-- | puma |
| Face | log | /opt/isr/logs/Face/Face.log | -rw-r--r-- | tomcat |
| Face | config | /var/lib/tomcat/webapps/Face/WEB-INF/web.xml | -rw-r--r-- | tomcat |
| Face | code | /var/lib/tomcat/webapps/Face/**/*.* | -rw-r--r-- | tomcat |
| Index | config | /etc/my.cnf | -rw-r--r-- | mysql |
| Index | log | /var/lib/mysql/index.err | -rw-r----- | mysql |
| Index | log | /var/log/mysqld.log | -rw-r----- | mysql |
| Index | data | /var/lib/mysql/**/* | -rw-r--r-- | mysql |
| Provision API | log | opt/isr/logs/provapi/init.error.log | -rwxr-xr-x | tomcat |
| Provision API | log | opt/isr/logs/provapi/init.log | -rwxr-xr-x | tomcat |
| Provision API | log | opt/isr/logs/provapi/provapi.log | -rwxr-xr-x | tomcat |
| Provision API | config | opt/isr/application.properties | -rwxr-xr-x | isr |
| Provision API | config | opt/isr/log4j2.properties | -rwxr-xr-x | isr |
| Provision API | llog | opt/isr/logs/provapi/logs/localhost_access_log | -rwxr-xr-x | tomcat |
