ISR Provisioning API
The
ISR supports REST APIs
to provision the following features:
- Recording Format Profiles
- Routes
- Users
- Accounts
The provisioning API feature is available for all user types except Tenant Users and API Users and can configure all parameters within each feature except for Email and Password.
All of the provision APIs use HTTPS standards. Any HTTP request is
redirected to HTTPS before sending to ensure data privacy. The JWT token
generated for Provision APIs is valid for 5 hours from the time it is
generated.
You must send the complete object for the specified API PUT requests. If any field is missing, the application changes the missing value to the default value. For sending an incomplete object with missing fields, PATCH request functionality is available.
