New Features in Oracle Communications Interactive Session Recorder 6.4
This section lists and describes features developed and released new for Interactive Session Recorder (ISR) 6.4.
ISR Provision API
The ISR Provision API allows you to perform all the CRUD operations you perform using the ISR Dashboard without the need for the UI. ISR 6.4 supports provisioning APIs for Accounts, Routes, Users, and Recording Format Profiles. These provisioning APIs can be used once a user has been authenticated. To ensure security, the ISR uses JWT to authenticate each request made to the server. For more information on using the ISR Provision APIs, see "ISR Provisioning API" in the API Guide.
ISR Audio Codec Enhancements
The ISR now supports the AMR-WB codec to record and playback calls. For more information on supported audio codecs, see "Supported Codecs" in the Installation Guide.
Disabling ISR User Password Expiration
The ISR can be configured to disable User password expiration. When set to Yes, that User's password never expires. When set to No, that User's password follows the configured password expiration policy. For more information on disabling User password expiration, see "Adding a User" in the Administrator Guide.
Red Hat Compatible Kernel Support
The ISR is compatible with the Red Hat Kernel and Oracle Linux 7.6. For more information on RHEL support, see the Installation Guide.
Performance Enhancements
Optimization and performance enhancements have been made to ISR components. Contact your Oracle representative for more information.
