This section describes the minimum requirements to upgrade the SPMS application to SPMS 20.1.
Microsoft Windows 10 with .NET Framework 4.7.2 enabled.
Preinstalled Oracle Database Full Client 12c Release 2 or any newer version on PC running the upgrade.
Preinstalled Oracle Data Access Components (ODAC) 12c Release 2 or any newer version for PC running SPMS Applications.
A non-administrator user account.
Latest Webserver.zip
The System Database ID (DB SID) on client PC must be the same as DB SID on Web Server.Note:
Third party software providers who integrate to SPMS WebServices must change their application to support the new login method. See the OHCWebServices Technical Specification for more information.Microsoft Windows Server 2012 R2
Microsoft Windows Server 2016
Microsoft Windows Server 2019
Compatibility
Oracle Hospitality Cruise Shipboard Property Management System version 8.0.8 and above.
For customers using a version below 7.3.8xx, a database upgrade to the recommended or latest version is required. See the SPMS Installation Guide for more information.
