9. Configure AQ-JMS Bridge
The following steps are to be performed to configure the AQ-JMS Bridge through the Weblogic Console:
Note
Ensure that MDB EJB is not configured and deployed (i.e. OfsllAppQueue.ear deploy­ment) on the same server on which the other WebServices are deployed.
9.1 Create Data Sources for AQ-JMS Bridge
  1. Login to Oracle Weblogic 12c console (http://hostname:port/console).
  2. On successful login, the following window is displayed.
  3. Click Domain Name > Services > Data Sources. The following window is displayed.
  4. Click ‘Lock & Edit’ button on the left panel. Click ‘New’ on right panel and select ‘Generic Data Source’.
  5. The following window is displayed.
  6. Specify the following details:
Note
If required, you may specify any other JNDI name, but ensure to use the same JNDI name during other configuration steps.
  1. Click ‘Next’. The following window is displayed.
  2. Select the Database Driver ‘Oracle's Driver(Thin XA) for Services connections;Versions:Any’.
  3. Click ‘Next’. The following window is displayed.
  4. Click ‘Next’. The following window is displayed.
  5. Enter the Database details.
  6. Click ‘Next’. The following window is displayed.
  7. Click ‘Test Configuration’. On completion, displays a confirmation message as ‘Connection test succeeded’.
  8. Click ‘Next’. The following window is displayed.
  9. Select target Server as ‘OFSLL_ManagedServer’.
  10. Click ‘Finish’ to activate the changes.
Update the following parameters in JDBC data source connection pool:
  1. Select Services > Data Sources > select the AQ_JMS_DB data source > Connection Pool.
  2. Initial capacity and Maximum capacity is defaulted to 30, if the number of concurrent users are more this needs to be increased.
  3. Click Advanced button and update the ‘Inactive Connection Timeout’ to 300 seconds.
  4. Click 'Save' and restart the Data source.
Similarly create ‘QueueAppDS’ data sources which is used by MDB for all database related operations by following the steps mentioned in above section (Create Data Sources for AQ-JMS Bridge).
Do not perform the JDBC data source update and instead follow the below steps to configure the created ‘QueueAppDS’ data source:
9.2 Configure MDB Flow
To configure the MDB Flow from Weblogic Console, do the following:
  2. On the left pane, click 'Services'.
  3. In Messaging tree click ‘JMS Modules’. The following window is displayed.
  4. Click 'New'. The following screen is displayed.
  5. Specify the following details:
  2. Select target servers as ‘OFSLL_ManagedServer’.
  4. Click ‘Finish’ to activate the changes. The following window is displayed.
  5. Click on the JMS Module that you created. The following window is displayed.
  6. Click ‘New’ in ‘Summary of Resources’ section. The following window is displayed.
  7. Select ‘Foreign Server’ as the option for type of resource to be created and click ‘Next’. The following window is displayed.
  8. Specify the name of the Foreign Server as ‘AQForeignServer’ and click 'Next'. The following window is displayed.
  9. Click ‘Finish’ and activate the changes. The following window is displayed.
  10. Click on the Foreign Server that you created. The following window is displayed.
  11. Specify the following details:
  1. Click ‘Save’.
  2. Select ‘Destinations’ Tab and click ‘New’ to create new destination. The following window is displayed.
  3. Specify the following details:
  1. Click ‘OK’ and save the changes.
  2. Select ‘Connection Factories’ Tab and click ‘New’ to add new connection factory. The following window is displayed.
9.3 AQ-JMS Topic Setup
AQ-JMS Topic Bridge facilitates for group publishing to set of subscribed users. In a configured setup, a published message is sent to all the interested subscribers. Accordingly zero to many subscribers will receive a copy of the same message.
9.3.1 Create AQ-JMS Topic Bridge
To configure the AQ JMS Topic from Weblogic console, do the following:
  2. On the left pane, select Services > Messaging > JMS Modules. The following window is displayed.
  3. Click 'AQJMSModule'. The following window is displayed.
  4. In the Summary of Resources section, click 'New'. The following window is displayed.
  5. Select 'Foreign Server' as the option for type of resource to be created and click 'Next'. The following window is displayed.
  6. Specify the name of the Foreign Server as ‘OfsllTopicFS’ and click 'Next'. The following window is displayed.
  7. Click 'Finish' and activate the changes.
  8. Click on the Foreign Server that you created. The following window is displayed.
  9. Specify the following details and click 'Save'.
  1. Select 'Destinations' tab and click 'New' to create new destination. The following window is displayed.
  2. Specify the following details and click 'OK' to save the changes.
  1. Select 'Connection Factories' tab and click 'New' to add new connection factory. The following window is displayed.
  2. Specify the following details and Click 'OK' to save the changes.
9.4 JMS Queue Configuration
JMS queue is used to hold webservice invocation exception messages. It provides a mechanism for third parties to handle communication related failures.
Perform the following steps to configure JMS queue in application server.
9.4.1 Create JMS Server
  1. Login to WebLogic Server 12c console (http://hostname:port/console). The following screen is displayed.
  2. Specify the Weblogic administrator user name and password and click 'Log In'. The Oracle Weblogic home page is displayed.
  3. Click Domain Name > Services > Messaging > JMS Server.
  4. In the main window, click 'Lock & Edit'. The following window is displayed.
  5. Click 'New'. The following window is displayed.
  6. Specify the JMS Server Name as ‘OfsllJMSServer’. Click ‘Next’, the following window is displayed.
  7. Select 'None' as the Persistent Store type. Click 'Next', the following window is displayed.
  8. Select the target managed server and click 'Finish'.
  9. Click 'Activate Changes' under Change Center. Once done, the following window is displayed:
9.4.2 Create JMS Module
  1. Login to WebLogic Server 12c console (http://hostname:port/console) by specifying the Weblogic administrator user name and password.
  2. Click Domain Name > Services > Messaging > JMS Modules. The following window is displayed.
  3. Click 'New'. The following screen is displayed.
  4. Specify the following details:
  1. Click ‘Next’. The following screen is displayed.
  2. Select the target server and click 'Next'. The following window is displayed.
  3. Click 'Finish' to save and activate the changes. Once done, the following window is displayed.
9.4.3 Subdeployment
  2. Click Domain Name > Services > Messaging > JMS Modules. The main window displays the list of JMS modules available.
  3. Select the created JMS module ‘OfsllJMSModule’ and click 'Subdeployments' tab. The following window is displayed.
  5. Specify the Subdeployment Name as ‘OfsllJMSSD’. Click 'Next', the following window is displayed.
  6. Select the check box against the newly created JMS Server and click ‘Finish’. Once done, the following window is displayed.
9.4.4 Create JMS Connection Factory
  3. Select the newly created JMS module ‘OfsllJMSModule’. The following window is displayed.
  4. Click 'New’. The following window is displayed.
  5. Click 'Next'. The following window is displayed.
  6. Select 'Connection Factory' option and click 'Next'. The following window is displayed.
  7. Specify the following details:
  1. Click 'Next'. The following window is displayed.
  2. Click 'Advanced Targeting'. The following window is displayed.
  3. Select the Subdeployments as ‘OfsllJMSSD’ from the drop down list.
  4. Under JMS Servers, select the check box against 'ofsllJMSServer'.
  5. Click 'Finish' to save and activate the changes. Once done, the following window is displayed.
9.4.5 Create JMS Queue
  4. Click ‘New’. The following window is displayed.
  5. Select the 'Queue' option and click 'Next'. The following window is displayed.
  6. Specify the following details while creating new JMS System Module Resources:
  2. Select the Subdeployments as 'OfsllJMSSD' from the drop-down list.
  3. Click ‘Finish’ to save and activate the changes. Once done, the following window is displayed.
You can further click 'New 'to create more Queues and repeat the steps explained above.
9.5 Configure External Client Certificates
The Webhook option in OFSLL extends the support of interfacing with third-party applications by sending REST API based notifications of changes through system generated Webhook event actions.
In a Webhook setup you can notify the changes that are done in OFSLL by triggering Webhook request as an event action and propagate the information to the dependant third-party applications (client) through specific https communication channel.
For webhook HTTPS communication, client certificates are to be imported in Weblogic OPSS keystore for each channel.
Follow the below steps to import the certificates.
  1. Login to the Oracle Enterprise Manager 12c console. (i.e. http://hostname:port/em)
  2. Click on ‘Weblogic Domain’ drop-down list and navigate to Security > Keystore.
  3. Click on ‘Create Stripe’.
  4. Enter the Stripe Name as ‘OFSLL_STRIPE’.
  5. Click ‘OK’. The following OFSLL_STRIPE is created.
  6. Select the newly created ‘OFSLL_STRIPE’ and click ‘Keystore’.
  7. Enter the Keystore Name as ‘OFSLL_KSS’ and click ‘OK’.
  8. Select ‘OFSLL_KSS’ and click ‘Manage’..
  9. Click ‘Import’.
  10. In the below ‘Import Certificate’ screen, specify the following details:
  1. Click ‘OK’.
9.6 Create Credentials and System Policies
In order Configure MDB flow, you need to create credentials and system policies. The credentials are accessed through CSF framework which is managed by Oracle Weblogic Server. The keys are managed by Maps and Maps need to be given with Permissions.
  1. Login to Oracle Enterprise Manager (http://hostname:port/em).
  2. On the left panel, right click on OFSLLREL_domain and select Security > System Policies > Credentials. The following window is displayed.
  3. Click ‘Create Map’. The following window is displayed.
  4. Enter Map Name as ‘ofsll.int.bureau’ and click ‘OK’.
  5. Click ‘Create Key’. The following window is displayed.
  1. Click ‘OK’.
  2. Similarly you need to create the following Maps and corresponding keys as indicated in following table.
    Maps
    Keys
    Description
    ofsll.int.bureau
    This map is used to setup keys for all credit bureau interfaces
    ProxyServer
    Name of the proxyServer to be configured
    ProxyPort
    Port to which ProxyServer is running.
    ExpEcalsURL
    The Experian Connection URL to be config­ured.
    ExpDirectExperianEna­bled
    If you set value as true, then you would be set­ting ecals response URL. Else, the Ecals request URL
    ExpCertPath
    The location of .jks file which contains the valid certificate for Experian Credit Bureau.
    ExpBusUserNamePass­word
    Login Credentials to be configured for Experian Business reports.
    ExpConUserNamePass­word
    Login Credentials to be configured for Experian Consumer reports.
    EfxURL
    The Equifax Connection URL to be configured.
    EfxCertPath
    The location of .jks file which contains the valid certificate for Equifax Credit Bureau.
    EfxUserNamePassword
    Login credentials to be configured for access­ing Equifax Reports.
    TucCertPath
    The location of .jks file which contains valid cer­tificate for Transunion Bureau .
    TucCertPassword
    The password that requires to read the valid .jks certificate for the Transunion Bureau.
    TucUserNamePassword
    Login credentials to be configured for access­ing Transunion reports
    TucConnectionURL
    The Transunion URL to be configured.
    jdbc_ds_key
    Datasource configured to retrieve data for bureau.
    source
    Configured as EXTERNAL for actual call.
    ofsll.int.outbound
    This map is used to setup keys for the Route­One and Dealer track call back from OFSLL.
    roUserNamePassword
    Login Credentials used at the time of call back from OFSLL to RouteOne Interface.
    dtUsernamePassword
    Login Credentials used at the time of Call back from OFSLL to Dealer Track Interface.
    jdbc_ds_key
    Datasource configured to retrieve data for out­bound Resources.
    roPostDealerUsername­Passwd
    Credentials required to upload the dealer details to Route One Portal
    roPostDealerWbsURL
    Route One Post Dealer Web Service url
    roDealerUploadURL
    Route One URL to upload the Dealer details
    dtPostDealerUsername­Passwd
    Credentials required to upload the dealer details to Dealer Track Portal
    dtPostDealerWbsURL
    Dealer Track Post Dealer Web Service url
    dtDealerUploadURL
    Dealer Track URL to upload the Dealer details
    VertexUserNamePd
    Credentials required to connect to VERTEX web service
    VertexTrustedId
    ID required to connect to VERTEX web service
    TorqueItsUserName­Password
    Credentials required to connect to TorqueIts web service
    TorqueItsURL
    TorqueIts Decision service URL
    ProxyHost
    Name of the proxyServer to be configured.
    ProxyPort
    ofsll.int.bip
    This Map is used to setup all the Keys required to setup interface with BIP to generate reports.
    local_top_dir
    Define the path of the local BIP server where you would like place the generated BIP reports.
    email_from_addr
    Define the From Email address to be used while sending email for the generated BIP reports.
    emailBodyContentPath
    The path for ‘file.properties’ file that contains the content of the subject and body required while sending letter, report or correspondence as mail to the applicant or producer.
    For example; /tmp/file.properties
    *Refer to note below for details on ‘file.proper­ties’ file creation for email configuration.
    fax_server
    Configure the name of Fax server to be used to fax the generated BIP reports.
    jdbc_ds_key
    Datasource configured to retrieve data for BIP.
    ofsll.int.filetransfer
    sftp_key
    Credentials to login to SFTP server(Username/Password)
    sftp_top_dir
    Top root directory for SFFTP server
    sftp_servers
    SFTP server names
    ofsll.int.security
    bip_key
    This is BIP login credentials
    ofsll.int.gri
    GriURL
    GRI web service URL to be configured.
    GriAPIKey
    GRI API key to be configured
    ProxySet
    System Level Proxy Enabled/Disabled. Value can be either true or false.
    True= proxy required
    False = proxy not required
    ProxyHost
    Set only if ProxySet =true.
    ProxyPort
    Port on which ProxyServer is running.
    jdbc_ds_key
    Datasource configured to retrieve the request XML for GRI.
    GriCertPath
    The location of .jks file which contains the valid certificate for GRI.
    Configure only when a valid certificate is availa­ble.
    ofsll.int.common
    This map is used to setup keys for common JMS Queue
    OfsllJMSQueueJNDI
    The JMS queue JNDI name to be configured
    OfsllJMSQueueCF
    The JMS queue connection factory to be con­figured
    OfsllJMSServerURL
    The JMS server url to be configured.
    Ex: t3://<JMS server host>:<JMS server port>
    ofsll.int.webhook
    jdbc_ds_key
    Datasource configured to retrieve data for Web­hook.
* A new file(file.properties) needs to be created and copied to the application server in the same path as mentioned in the value corresponding to the key 'emailBodyContentPath' under the map 'ofsll.int.bip'. The file should have the following contents:
  1. On the left panel, right click on OFSLLREL_domain and select Security > System Policies. The following window is displayed.
  2. Click ‘Create’. The following window is displayed.
  3. Enter the codebase as ‘file:${domain.home}/lib/OfsllCommonCSF.jar’
  4. Click ‘Add’. The following window is displayed.
  5. Select the check box 'Select here to enter details for a new permission'.
  6. Specify the following details as the first permission class.
    Permission Class
    Resource Name
    Permission Actions
    oracle.security.jps.service.cred­store.CredentialAccessPermission
    context=SYSTEM,mapN­ame=ofsll.int.bureau,keyName=*
    read
    context=SYSTEM,mapN­ame=ofsll.int.filetransfer,key­Name=*
    read
    context=SYSTEM,mapN­ame=ofsll.int.outbound,key­Name=*
    read
    context=SYSTEM,mapN­ame=ofsll.int.bip,keyName=*
    read
    context=SYSTEM,mapN­ame=ofsll.int.gri,keyName=*
    read
    context=SYSTEM,mapN­ame=ofsll.int.common,keyName=*
    read
    context=SYSTEM,mapN­ame=ofsll.http.listener.jndi,key­Name=*
    read
    context=SYSTEM,mapN­ame=ofsll.int.webhook,key­Name=*
    read, write, update
    oracle.security.jps.service.key­store.KeyStoreAccessPermission
    stripeName=OFSLL_STRIPE,keystoreName=OFSLL_KSS,alias=*
    read
  7. Click ‘OK’.
9.7 Deploy MDB EJB
  1. Login to Web Logic application server enterprise manager (e.g.:http://hostname:port/em)
  2. Enter valid login credentials. The following window is displayed.
  3. Select ‘Lock & Edit’ option in the lock drop-down list available in the header.
  4. Click ‘Deployment’ in the left panel. The following window is displayed.
  5. Select ‘Deploy’ from the Deployment drop-down list. The following window is displayed.
  6. The following window is displayed.
  7. Browse to the folder containing the MDB EJB. Eg: C:/OfsllQueueApp.ear
  9. Select the server on which the MDB EJB needs to be deployed.
  10. Click ‘Next’. The following window is displayed.
  11. Select the option ‘Install and start application (servicing all requests)’.
  12. Check the context root and click ‘Next’.The following window is displayed.
  13. Click ‘Deploy’. On successful deployment, the following window is displayed.
  14. Click ‘Close’. Post deployment, you need to activate the changes by selecting ‘Active Changes’ option from ‘Edit Session’ drop-down list as indicated in step 4 above.
Note
While starting the ‘OFSLLREL_ManagedServer’, always start with option ‘-DUseSun­HttpHandler=true’ to enforce the weblogic server to uses SUN SSL implementation.
