11. Configure Oracle Analytics Publisher for Applica­tion
  1. Copy the OfsllCommonCSF.jar from /WEB-INF/lib available in the staging area to $DOMAIN_HOME/lib
  2. Update the setDomainEnv.sh file ($MW_HOME/user_projects/domains/mydomain/bin directory) by appending the above jar file path – EXTRA_JAVA_PROPERTIES="…….. ${EXTRA_JAVA_PROPERTIES}
    -Dofsll.csf.path=${DOMAIN_HOME}"
  3. Configure Security via EMconsole
Note
It is assumed that BI Publisher is installed and configured. Refer BI Publisher Guide for further details.
  1. Click WebLogic Domain on the right panel. Select Security > Credentials. Click ‘Create Map’.
  2. Enter the Map Name: ofsll.int.security.
  3. Click ‘OK’.
  4. Click ‘Create Key’ Button.
  5. Enter the details as per your requirement. Specify ‘User Name’ and ‘Password’ of BI Publisher console.
  6. Click ‘OK’. The following window is displayed.
  7. On the left panel, right click on the domain OFSLL_domain > Security > System Policies. The following window is displayed.
  8. Click ‘Create’.
  9. The following window is displayed. Enter the codebase as ‘file:${ofsll.csf.path}/lib/OfsllCommonCSF.jar’ and click ‘Add’.
  10. The following window is displayed. Select the checkbox 'Select here to enter details for a new permission' and enter the following details as the first permission class.
Configuring JNDI Name for http Listener
  1. Similarly, click Add to add the second permission class. Select the check box 'Select here to enter details for a new permission' and enter the following details as the second permission class.
  1. Click ‘OK’. The following window is displayed.
  2. Click ‘OK’. The following window is displayed.
