8. Configuring JNDI name for HTTP Listener
  1. Click ‘WebLogic Domain’ on the right panel. Select Security > Credentials.
  2. Click ‘Credentials’. The following window is displayed.
  3. Click ‘Create Map’. The following window is displayed.
  4. Enter Map name as 'ofsll.http.listener.jndi'.
  5. Click ‘OK’. The following window is displayed.
  6. Click ‘Create Key’ Button. The following window is displayed.
  7. Enter the followng details as per your requirement.
    • Key: jndiname
    • Credential: java:comp/env/jdbc/ofsllDBConnDS
    • Type:Generic
  1. Click ‘OK’. The following window is displayed.
