5. Deploying Application
5.1 Deploying Application
- Login to the Oracle Enterprise Manager 12c console . (i.e. http://hostname:port/em)
- Click on ‘Lock and Edit’ as shown below.
- The following window is displayed.
- Click on Deployments in the left panel. To deploy go to Deployments option in the menu as shown below.
- Click ‘Choose File’ button and select OFSLL application archive file i.e. ofsll_1410.ear. Choose the ‘Deployment Plan’ (if any).
Note
A deployment plan can be used to easily change an application's WebLogic Server configuration for a specific environment without modifying existing deployment descriptors.
Sample plan.xml
- Click ‘Next’. The following window is displayed.
- Check target server as per the requirement ‘OFSLL_ManagedServer’ and click ‘Next’. The following window is displayed.
- Click
button to select Repository Name. The following window is displayed.
- Select Repository as per requirement and click ‘OK’.
- Enter Partition name as per the requirement and click ‘Next’.
- Click ‘Deploy’. The following window is displayed
- Click Close once the message ‘Deploy operation completed’ is displayed.
