6. Enabling SSL
The application is accessible only via https protocol; hence, after the deployment of the application, you need to enable SSL.
To enable SSL
  1. Login to console.
  2. $Domain_Home > Servers > Manage Servers > Configuration > General. The below screen is displayed.
  3. Check the ‘SSL Listen Port Enabled’ check box.
  4. Specify the port for ‘SSL Listen Port’.
Note
It is recommended to disable http protocol.
