10. Collateral Management
Centralized Asset Management or Collateral Management System (CMS) enables the user to record a new collateral, evaluate it, and re-evaluate the existing collateral.
A Collateral Management System is used to minimize the frauds which involve the same collateral being pledged for different Line of credit and re-evaluating existing collateral manually or connecting to the VIN Interface.
The Collateral Details screen is opened from the Servicing > Servicing > Collateral Management and contains the following tab:
10.1 Collateral Tab
Using the Collateral screen, you can record a new collateral, view the valuation of collateral, and re-evaluate the existing collateral.
The collateral details can also be defined in the collateral screen of Application Entry screen.
The system assigns collateral statuses and the following are the statuses:
Calculate Parameters
The ‘Calculate Parameters’ button is available in the Collateral Details header. Clicking on it calculates the Target parameters for the selected Collateral and populates the computed values in the custom user defined fields.
However, for system to populate data in custom fields, the following setup is required:
For more information, refer to specific section in Setup guides.
To enter the Collateral Details
  1. On the application master screen, click Servicing > Servicing > Collateral Management > Collateral Details.
  2. In this section, you can perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields is given below:
Field:
Do this:
Type and Description section
Collateral Type
Select the collateral type.
Primary
Select the check box if this property is the primary collateral.
Asset ID
View the asset identification number.
Asset #
View the asset number which is automatically generated.
Asset Class
Select the asset Class.
Asset Type
Select the asset type.
Sub Type
Select the asset sub type.
Registration #
Enter the vehicle registration number.
Status
View the vehicle status.
Select Make and Model
Select the Make and Model number of asset from the drop down list. You can use the search option to select the details.
Year
Specify the year of the vehicle.
Estimated Life
Specify the estimated life of the asset.
Make
Specify the make of the vehicle.
Model
Specify the model of the vehicle.
Identification #
Specify the vehicle identification number.
Body
Specify the body of the vehicle.
Description
Specify the description of the asset.
Condition
Select the condition of the asset from drop-down list.
Lien Details
Lien Status
Select the type of Lien action.
Lien Event Dt
Select the lien event date from the calendar.
Second Lien Holder
Specify the name of second lien holder.
Comments
Specify additional details if any.
Lien Release Entity
Select the lien release entity from the drop-down list. The list displays the following values:
- Customer
- Producer
- Others
- Business
Note: If ‘Others’ is selected as the Lien Release Entity, ensure that the Entity Name and Address details are updated cor­rectly since the same is not auto-validated with the data main­tained in the system.
Entity Name
If you have selected the lien release entity as ‘Customer’ or ‘Producer’, system automatically filters entity name list with corresponding customer accounts or producer. Similarly, if the lien release entity is selected as ‘Business’ system displays the Business name if the asset is linked to Business account. Select the required entity name from the drop-down list.
If you have selected the lien release entity as ‘Others’ specify the entity name.
Address section
Country
Select the country.
County
Select the county.
Address #
Specify the address number.
Address Line 1
Specify the first address line.
Address Line 2
Specify the second address line.
Zip
Select the zip code.
Zip Extn
Specify the zip extension.
City
Specify the city.
State
Select the state.
Usage Details
The details maintained in this section is used to calculate ‘EXCESS USAGE FEE’ in pay­off quote and termination transactions.
Start
View/specify the start unit of asset usage.
Base
View/specify the base units.
Extra
View/specify the extra usage units.
Total
View/specify the total usage units.
Vacation Ownership Details
Billling
Check this box to indicate if the asset is considered for billing.
Due Amt Account Type
Select one of the following account type from the drop-down list to indicate on which account this asset is to be considered for billing.
- Current Account
- Linked Account
- Master Account
Note: If ‘Billing’ option is checked and the Due Amt Account Type is selected as Current/Linked/Master Account, then the billing batch job posts the transactions based on Asset Billing Rate setup in Current account / Linked Account of current Account / Master Account of current Account respectively.
Trade Eligible
This check box is selected by default and indicates that the asset is eligible for trade.
If checked (Trade Eligible = Y) then Asset Status is marked as INACTIVE during Trade. If unchecked (Trade Eligible = N) Asset status is marked as ACTIVE.
Consolidate Points at Master
Check this box to indicate that point can be consolidated at master account level. Refer to ‘Consolidate Actual Points at Master’ section for more details.
Points Consolidation Type
Select the type of points consolidation option from drop-down list. This field is used to identify the assets at Associated accounts to consolidate the points.
Custom Fields - This section displays the custom User Defined Fields if enabled in Setup and if configured, populates specific business computation values.
  1. Perform any of the Basic Actions mentioned in Navigation chapter.
  2. Click Submit.
10.1.1 Actual Points and Billing Points Consolidation
Actual Points consolidation at Master account level may or may not include the points at associated account(s) and is controlled based on the status of ‘Consolidate Points at Master’ check box.
Points consolidation is done in following scenarios:
To ‘Consolidate Points at Master’, following validations and update options are provided:
OFSLL uses Billing Points for Asset Billing calculations to derive the transaction amount using different asset billing rates. For more information, refer to Setup > Asset Billing Rate screen.
Billing points consolidation at Master Account level is decided based on status of ‘Consolidate Points at Master’ option selected at Master Account level.
Note
If the ‘Consolidate Points at Master’ option is changed from ‘N’ to ‘Y’ at later point, then points consolidation of Master account is not done. However, consolidation is still done if there is a change in associated account(s).
The consolidated billing points are populated in Vacation Ownership sub tab available in Customer Service screen > Collateral tab > Home sub tab.
Following examples illustrates on how Actual and billing points are consolidated.
Scenario 1: Consolidate Points at Master = N
Here, consolidation is not done and billing points are considered based on Asset Usage Type. Also, even if ‘Consolidate Points to Master = Y’ for associated account(s), the same is not considered.
Account Type
Points on Funding
Actual Points
Asset Usage Type
Billing Points
Master M1
50
50
Half (total Points/2)
25
Associated A1
100
100
Full
100
Associated A2
100
100
Full
100
Scenario 2: Consolidate Points at Master = Y
Here, billing points consolidation is done but Asset Usage Type of Master account is not considered.
Account Type
Points on Funding
Actual Points
Asset Usage Type
Billing Points
Master M1
50
200
(50 points of M1 is overwritten)
Full
(Not considered)
100
Associated A1
100
100
50
Associated A2
100
100
50
Note that, billing points are consolidated only if the following conditions are satisfied:
10.1.2 Valuations Sub Tab
The Valuation sub section contains information about the value of the asset. The Values section enables you enter the value of the asset. The Addons sub tab records information about any add ons associated with the collateral.
To complete the Valuations section
  1. Click Valuations section.
Field:
Do this:
Valuations section
Current
Select if this is the current valuation.
Valuation Dt
Specify the valuation date.
Source
Select the valuation source.
Edition
Specify the valuation edition.
Supplement
Specify the valuation supplement.
Total Value =
View the total value.
Wholesale Base
Specify the wholesale value.
Usage
Specify the usage value; that is, the monetary effect that cur­rent mileage has on the value of vehicle.
Retail Base
Specify the retail value.
Addons +
View the add-ons value.
Usage Value +
Specify the usage. This pertains to Line of credit and usually is entered as the current mileage on vehicle.
  2. In the Addons section, you can perform any of the Basic Operations mentioned in Navigation chapter. You need to specify all the field values for every asset’s add-ons and attributes on the application.
  3. A brief description of the fields is given below::
    Field:
    Do this:
    Addons/Attributes
    Select the add-on/attribute.
    Value
    Specify the value of the attribute.
    Amt
    Specify the add-on amount.
  4. Perform any of the Basic Actions mentioned in Navigation chapter.
10.1.3 Tracking Sub Tab
The Tracking sub screen enables you to record further information associated with the collateral. What items you choose to track are setup during implementation.
To track attributes for the collateral
  1. Click the Tracking sub tab.
  2. In the Tracking Items section, click Load Details.
  3. In the Tracking Items section, you can perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Tracking Item
View the tracking type
Disposition
Select the disposition.
Start Dt
Specify the tracking start date.
End Dt
Specify the tracking end date.
Followup Dt
Specify the next follow-up date.
Enabled
Select to track the information from start date in the Start Dt field.
Comment
Specify any comments regarding the tracking item.
  1. Complete the Tracking Item Details section by entering information about a parameter in the corresponding the Value field.
  2. Perform any of the Basic Actions mentioned in Navigation chapter.
10.1.4 Vacation Ownership sub tab
In the Vacation Ownership sub tab you can capture and maintain ‘Timeshare’ specific collateral details of an account. This tab is displayed only for ‘Home’ collateral and allows to maintain only one records for the selected account.
For detailed information of the fields in this sub tab, refer to ‘Vacation Ownership tab’ section in Customer Service > Collateral > Home tab.
10.1.5 Status History Sub Tab
The Status History sub tab enables you to view the asset history of association with accounts.
To view the Status History
  1. Click the Status History sub tab.
  2. In the Status History section, view the following information:
    Field:
    Do this:
    Account #
    View the account number.
    Status
    View the status of asset.
    Lien Status
    View lien status of the asset.
    Line Event Date
    View lien event date of the asset.
    Data Change Sta­tus
    View the data change status of the asset.
    Data Change Date
    View the data change date of the asset.
    Comments
    View comments of the asset if any.
10.1.6 Asset Relation Sub Tab
The Asset Relation sub tab enables you to view the asset relationship.
To view the Asset Relation
  1. Click the Asset Relation sub tab.
  2. In the Asset Relation section, view the following information:
    Field:
    Do this:
    Account #
    Asset #
    View the asset number.
    Account Status
    View the Account status.
    Current Ind
    Indicates that this is the current asset.
    Primary Ind
    Indicates that this asset is the primary.
10.1.7 Audit Sub Tab
The Audit sub tab enables you to view the asset relationship.
To view the Audit
  1. Click the Audit sub tab
  2. In the Audit section, view the following information:
    Field:
    Do this:
    Account Id
    View the account identification number.
    Asset Id
    Column Name
    View the column name.
    New Value
    View the new value.
    Old Value
    View the old value.
    Changed By
    View the person name who changed the details.
    Changed Date
    View the date on when the details are changed.
10.2 Search Tab
A Search screen is available on the Collateral Management System to help locate information such as an asset type, asset number, identification number, asset status, make, model, and year. This is the information that is used on the Collateral screen.
To search for a Collateral details
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click Servicing > Servicing > Collateral Management > Search.
  2. The Collateral Management screen’s Search screen appears.
  3. In the Search Criteria section, use the Comparison Operator and Value columns to enter the search criteria you want to use to locate a collateral.
  4. Click Search. The system displays result of the search in Results screen.
  5. On the Results screen, select the collateral you want to load and click Submit. The system loads the collateral details on the Collateral Details screen.
