8. Post Dated Cheques (PDC) Management
It is a standard banking practice in some countries to request post-dated checks for the retail Line of credit repayments. When Line of credit are sanctioned, the lending institution collects post-dated checks in advance from the Line of credit recipient - at times for the full tenor of the Line of credit . The main reason for the practice of seeking post dated checks by banks is that it is far quicker for the banks to recover money that is due in a cheque dishonor case than in a regular civil case for recovery of Line of credit dues.
Post dated checks can also be used for payment in the realization for the Line of credit . Security checks are used only when the account becomes non-performing.
Managing accounts using post dated checks is very complex and important, as it has significant bearing on the servicing operations. If the PDCs due for clearing are not sent as required, the repercussions are huge. The lending institution loses its payment from the customer and may levy penalties such as late fees and insufficient funds charges which can lead to customer dissatisfaction. Hence, the utmost care should be taken while servicing the Line of credit accounts using PDC. The PDC process begins with the sorting of checks received from various account holders. They are segregated by Line of credit product and location before being vaulted in conduits at the centralized location or PDC center. This sorting enables the lending institution to quickly retrieve the PDCs with relevant date and send them for clearing.
The Post Dated Cheques screen is opened from the Servicing master tab’s Post Dated Cheques link and contains the following tabs in its link bar:
8.1 PDC Entry Tab
The PDC Entry link opens the PDC Entry screen which enables you to record details about the post dated checks collected from customer.
When post dated check is processed by the PDC batch, the status changes to PROCESSED. All the processed checks will then be picked by the Payment Batch and processed. After this, the system posts s payment transaction on the Payment screen’s Payment Entry tab.
The View Options section enables you to view PDC batches by status (Open, Post, Void, and All). You can choose whether the PDCs from the customer are for a single Line of credit account or for multiple Line of credit accounts in the same bank. Once you enter the Line of credit account number of the customer in the PDC Batch section, The system displays all Line of credit accounts pertaining to the customer.
The information has to be captured to facilitate the inward sorting i.e. sorting the cheques by Line of credit product group and location and then vaulting them in boxes placed in the vaults at the PDC center and subsequently send them for clearance on the day the payment is due. Usually the PDCs are sent for clearance a few days before the actual due date.
Information maintained here can be viewed at Customer Service > Account Details > Contract Information > PDC sub tab.
After the batch has been created, click POST in Action section to post the batch of PDCs to Line of credit account. You can also click VOID in the Action section to cancel the PDC entry on a Line of credit account.
To view the PDC Entry section
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Post Dated Cheques > PDC Entry.
  2. On the PDC Entry screen’s View Options section, select the type of PDC batch you want to view.
    If you choose:
    System displays in the PDC Batch section:
    Open
    All batches with open status.
    Post
    All batches with post status.
    Void
    All batches with void status.
    All
    All batches, regardless of the status.
  3. In this section, you can perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields is given below:
Field:
Do this:
Account
Select the account number.
Date
Specify the date.
Status
View the status.
  1. Perform any of the Basic Actions mentioned in Navigation chapter.
  2. In the Check Details section, you can perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
PDC Type
Select the post dated check type, Security checks or post dated checks for payment.
Bank Acc #
Specify the account number, on which the cheque is drawn.
Account Type
Specify the type of the account
Routing #
Specify routing number of the cheque. It is the number printed on cheque, also called MICR number (Magnetic Ink Character Recogni­tion).
Bank Name
Specify the bank name of the customers cheque
Branch Name
Specify the Branch name of the customers cheque
Docket #
Specify the docket number where post dated checks are supposed to be stored
Check #
Specify the starting cheque number
Check Dt
Select the check date. In case there are multiple checks being deposited that have sequential serial numbers, the date of the first cheque in the series would be entered in the date field. The remain­ing cheque dates would be anniversary dates based on the fre­quency set up.
For example, the cheque range could be from 111 to 180. If date on first cheque-111 is October 12, 2003 and the frequency is set to Monthly, the next cheque would be picked up for processing on November 12, 2003.
Check Amt
Specify the appropriate cheque amount.
Status
Specify if there are any additional status of the PDC.
Comments
Specify any remarks for the details.
Once the PDC batch is posted, an entry appears in Post Dated Checks section on the Customer Service screen’s Payment Mode tab, with OPEN status.
The status changes to PROCESSED when post dated check is sent for clearance on the pre-processing day and the payment is received. At that time, a payment transaction is posted on the Payments screen’s Payment Entry screen.
8.2 PDC Maintenance Tab
The PDC Maintenance tab opens the PDC Maintenance screen which enables you to modify check details for a specific account. You can either use view options to filter the PDC details by status or search the details using Query By Example option. The Edit button enables you to modify docket number, change status, and to add comments.
To view the PDC Maintenance screen
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Post Dated Cheques > PDC Maintenance tab.
  2. On the PDC Maintenance screen’s View Options section, select the type of PDC entry you want to view in the PDC Maintenance section.
    If you choose:
    The system displays in the PDC Batch section:
    Open
    All entries with open status.
    Processed
    All entries with post status.
    Void
    All entries with void status.
    All
    All entries, regardless of status.
  4. A brief description of the fields is given below.
    Field:
    Do this:
    Bank Name
    View the bank name for which check is provided.
    Branch Name
    View the bank’s branch name.
    Drawer Account #
    View the bank account number.
    Docket #
    Edit/view the location number where checks have been stored.
    Check#
    View the check number.
    Check Dt
    View the check date.
    Check Amt
    View the check amount.
    Status
    Select to change or view the cheque’s current status.
    PDC Type
    View the check type (Payment or Security).
    Account Type
    View the bank account type.
    Routing #
    View the bank’s routing number.
    Comments
    Specify or view any comments associated with the record.
  5. Perform any of the Basic Actions mentioned in Navigation chapter.
8.3 Search Tab
The Search tab opens Search screen. On Search screen, the Search Criteria section enables you to locate an account or group of accounts. The Results section displays details of the Line of credit account. This is a useful alternative to using the Customer Service screen to search for account information.
