8. Funding
8.1 Introduction
At this stage of the Loan origination process, the application has been entered into Oracle Financial Services Lending and Leasing and approved manually by an underwriter or by the system. The next step is to view and complete the contract information and make a funding decision to finance or reject the application. This is accomplished by using the Funding screen.
This chapter explains how to:
8.2 Funding (an overview)
In Oracle Financial Services Lending and Leasing, the funding process follows these basic steps:
  1. Open the Funding screen and load the application you want to work with.
  2. In the Funding screen’s Applications master screen, Change the status of the application to Approved - Verifying.
  3. Using the Funding screen’s Applicants link, view and verify information about the applicant (data recorded from the Application Entry screen). This includes verifying the applicant’s actual address and employment information.
  4. Using the Funding screen’s Decision link, view and verify information supplied during the credit bureau pull and underwriting process. This is display only information and cannot be edited.
  5. Using the Funding screen’s Collateral link, view and verify information regarding the collateral for the application.
  6. Using the Funding screen’s Contract link, complete the truth-in-lending information.
  7. In the Funding screen’s the Applications master screen, change the status to Final Document Check.
  8. Using the Funding screen’s Verification link, view any errors and warnings that prevent the status change.
  9. Make changes to the application data that correct the errors until you can change the status.
When the system changes the status of the application to Final Document Check, it sends the application to a supervisor or Loan officer queue where it is viewed and verified. After this, the application’s status is changed to Approved - Verified. If the supervisor/ Loan officer decides to fund the Loan, he or she will change status of the application to Approved - Funded.
Loading an Application on the Funding screen
The first step in the funding process is to open the Applications form and manually or automatically load the application you want to work with. You can manually select an application using the Search tab’s Criteria and Results screens. If your system is configured to load applications based on work queues, use the Queue field in the Quick Search section.
Refer the chapter Searching for Application for more information on the following:
Funding non OFSLL Loan Applications
Oracle Financial Services Lending and Leasing can readily process credit contracts generated from external system for funding. You can load the credit applications data received from external system into OFSLL through the 'Application Entry' screen and proceed with funding. For more information, refer 'Entering a Credit Application' section.
Once the application is processed or approved through OFSLL funding screen, the external system is intimated with the decision. Those applications can still be processed further in external system itself to validate the contract against approved credit. If agreed, the signed contract documents can be distributed in electronic format to OFSLL for funding. Once Credit Contract is distributed, the ‘Contract Type’ is automatically changed to eContract/Dealer in OFSLL and notified to the user.
All communications between OFSLL and external systems are recorded into a log and is accessible through Dashboard > System Monitor > Database Server Log Files screen. Also the ‘Comments’ screen facilitates to exchange information regarding credit contract processing between OFSLL and external system as comments, provided the comment Sub Type is selected as 'OUTBOUND TO INTERFACE' for such communications.
In addition, OFSLL also supports revoking of funded credit contracts worked through external interface by reversing the active transaction in Customer Service > Transaction History > Transaction tab. Whereby the application/account status is changed to 'Void' and subsequently categorized as FLAT CANCEL (indicating as fraud application and funding is withdrawn) or UNWIND (when application still has errors and allowed to update/rectify details and resubmit for funding).
Overall, this process minimizes the application processing time and fastens the funding process.
8.3 Funding Screen’s Master Screen
The Funding screen’s master screen displays information from the Application Entry and Underwriting screens, such as the application number, product and producer. It also contains the Status field that allows you to change the status/sub status of the application and begin the funding process.
For details on this screen refer Applications section in Underwriting chapter.
After opening the Funding screen and loading the application you want to work with, you must change its status to Approved - Verifying before you can begin the funding process. This allows you to begin working with the application.
To change the status and begin work on the application on the Funding screen
  1. Open the Funding screen and load application you want to verify.
  2. In the Funding screen’s Applications master screen, use the Status field to select APPROVED - VERIFYING.
  3. Click Save on the Funding screen.
You can now begin making changes to the application.
Funding an Application
After you have verified the application, entered the contract information and completed the contract edits, the application is ready to be funded. Applications can be approved automatically or manually. To manually fund an application, change the status to Approved - Funded.
After an application is funded, the Loan origination cycle is over. The system moves the application to the Loan servicing module (Customer Service form) where it receives an account number. The system also automatically creates a check requisition for the funded account.
Funding tasks
  1. Load the application on the Funding form
  2. Change the status and initiate Funding process
  3. Verify the applicant information
  4. Complete Contract (5) details
  5. Verify the documents
  6. Generate letters
  7. Attempt to change the application status
  8. Verify edits
  9. Complete Funding
After you approve the application, the information on the Decision tab is unavailable. The application remains in this status of Approved - Verified until a user (usually a supervisor) changes the status to Approved - Funded. When the status is changed to Approved - Funded, the account is created.
8.4 Summary Tab
The summary screen provides a unified view of the application details without navigating to the respective screens/ sub-tabs.
Using this screen, the user can view the applicant details, asset details, ratios (only for Primary Applicant), trade-In, requested details, approved details, itemization, decision history, alerts, comments, and checklist details in the respective section.
To view the Summary
  2. Click Summary.
For details on this screen refer Summary Tab section in Underwriting chapter.
8.5 Applicants Tab
Having selected and loaded an application, you can use the Applicants link to view information about the applicant (s). This is information that was recorded on the Application Entry screen or gathered during the credit pull. You can edit the data from the Application Entry screen at anytime in the following steps. Remember to save your work with each change. Information from the credit bureau pull is available to view only.
To verify information about an applicant
  2. In the Funding tab, click Applicants.
  3. In the Applicants Details section, select the applicant you want to verify and click Edit.
For details on this screen refer Applicant Tab section in Underwriting chapter.
8.6 Business tab
If this application is an SME Loan (defined in the Applications section Class field as small business), the Business Applicant link appears on the Funding link bar. This link displays the small business information recorded on the application entry process. You can edit the Funding screen at anytime in the following steps. Remember to save your work with each change.
If there is no business information associated with the application, the Business Applicant link is unavailable.
For more information about the individual fields in this section, see the Application Entry chapter.
To verify business information from the Business Applicant link
  2. Click Business Applicant.
For details on this screen refer Business Tab section in Underwriting chapter.
8.7 Request Tab
System displays the calculated Payment, Interest Rate, Term and Loan Amount in the Request tab.
For details on this screen refer Request Tab section in Underwriting chapter.
8.8 Decision Tab
With the Decision tab, the system displays information gathered during the underwriting process. Depending on the type of application you are working with, system displays Loan information. On Clicking Calculate, the user can calculate the Loan amount, rate, term, and payment.
The fields on the Decision screens and sub screens are described in detail in the Underwriting chapter.
For details on this screen refer Decision Tab section in Underwriting chapter.
8.9 Customer Credit Limit tab
This tab displays the customer credit limit details captured during the underwriting process and is validated during application funding. Depending on the type of application you are working with, system displays Loan information.
For details on this tab, refer Customer Credit Limit tab section in Underwriting chapter.
8.10 Master Account tab
The Master Account tab in Origination screen facilitates to categorize the current application to be considered as ‘Master Account’ after funding or link the current application to another existing master account in the system.
To define Master Account Details
  1. Open the Underwriting screen and load the underwriting application you want to work with.
  2. Click ‘Master Account’ tab.
For details on this screen refer Master Account tab section in Underwriting chapter.
8.11 Bureau Tab
The Bureau tab displays the credit report (if pulled) for an applicant. If there is a need for another pull for any applicant, it can be done here manually using the New Request section.
To verify the credit bureau data using the Bureau tab
  1. Open the Funding screen and load the underwriting application you want to work with.
  2. Click Bureau
For details on this screen refer Bureau Tab section in Underwriting chapter.
8.12 Contract Tab
The screens associated with the Contract link are the core of the funding process. They allow you to perform the important task of completing the truth-in-lending details. These screens include information mandated by Regulation Z; information about the financed amount, the payment schedule, the total of these payments, the finance charge, the resulting annual percentage rate (calculated according to Federal/Central bank guidelines; that is, within 125% of the Treasury OCC calculated APR) for the conventional Loan, and internal rate of return for Islamic Loan. Use the Loan packet to supply the required information.
In completing the truth-in-lending details on the Contract link, you will enter Loan information. The truth-in-lending details must be completed before a Loan can be funded.
The tabs opened from the Contract link share the following sub tabs:
You can use the quick calculator provided with the drop-down list adjacent to the ‘Calculate’ button to calculate the required Loan parameters. You can also use the calculator available in Tools section for completing this step. For detailed information on using the Calculator tools, refer “Tools” chapter in the document.
While working with the Contract tab for Loan applications, you can either enter the contract details manually or make use of the ‘Suggest’ option which auto populates the contract and payment details.
On clicking the ‘Suggest’ option,
Since in one click all the required contract information is populated to fund the application, this option helps to improve operational efficiency. But however, this option is not available if the contact instrument is already loaded.
To enter the contract details
  2. On the Funding screen, click the Contract tab.
  1. Using the information in the contract packet, complete the Contract section.
(The system calculator may used when completing this section. For more information, see the Tools chapter.)
  1. In this section, you can perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields is given below:
Field:
Do this:
Contract section
Contract Rcvd Dt
Specify the contract received date.
Contract Dt
Specify the contract date.
Instrument
Select the required instrument from the drop down list and click on Load Instrument Details.
Amt Financed
Specify the amount financed: the Loan amount applied minus the prepaid finance charges. Prepaid finance charges can be found on the Good Faith Estimate/Settlement (HUD-1 or 1A). For exam­ple, if the borrower’s note is for $100,000 and the prepaid finance charge total is $5,000, the amount financed would be $95,000. The amount financed is the figure on which the annual percent­age rate (APR) is based.
Loan Term
Specify the term/number of payments.
Index
Select the index.
Index Rate
View the index rate.
Contract Margin Rate
Specify the margin rate.
Contract Rate
View the interest rate.
The following 3 fields - Regulatory Name, Regulatory Rate, and Contract Imputed Rate are displayed only if the ‘Imputed Interest’ check box is selected in Contract Setup (i.e. Setup > Administration > Products > Contract screen).
The value in these fields are automatically populated from setup on selecting a ‘Instru­ment’ with imputed interest and clicking on ‘Load Details’.
Regulatory Name
The regulatory name is populated with the value defined in Setup > Administration > Products > Regulatory Rates screen.
Regulatory Rate
The regulatory rate is populated on loading an instrument with the ‘Interest Rate’ defined for that definition in Setup > Administration > Products > Regulatory Rates screen
Note: If there are no matching records with regulatory rate, the Edits (underlying rules) validation fails (if Edits are enabled) and system does not allow to save the contract information.
View the contract imputed rate which is derived based on Con­tract Rate and Regulatory rate as indicated below:
  • If Contract Rate - Regulatory Rate = 0, Imputed Rate = 0
  • If Contract Rate - Regulatory Rate > 0, Imputed Rate = 0
  • If Contract Rate - Regulatory Rate < 0, Imputed rate = Regulatory Rate (minus) Contract Rate.
While funding if the contract Imputed Rate is greater than ‘0’, sys­tem automatically calculates Imputed Interest Amortization schedule. For more information, refer ‘Imputed Interest’ section.
Balloon Method
View the balloon payment method.
Balloon Amt
Specify the balloon amount.
Due Day
Specify the due day.
1st Pmt Dt
Specify the first payment date.
Maturity Dt
Specify the maturity date.
Finance Charge Amt
Specify the finance charge: the amount of interest, prepaid finance charge, and certain insurance premiums (if any) that the borrower will be expected to pay over the life of the Loan.
Total of Pmts
Specify the total of payments.
Down Pmt Amt
Specify the down payment amount.
Total Sale Price
Specify the total sales price.
Payment Amt
Specify the payment amount.
Final Pmt Amt
Specify the final payment amount.This amount will be same as that in the Payment Amt field when the installment method is EQUAL PAYMENTS. (required).
Repmt Currency
Specify the currency to be used for repaying the Loan.
Principal Balance
View the principal balance on the Loan.
APR
Specify the annual percentage rate: the cost of the Loan in per­centage terms taking into account various Loan charges of which interest is only one such charge. Other charges which are used in calculating the APR are private mortgage insurance of FHA mort­gage insurance premium (when applicable) and prepaid finance charges (Loan discount, origination fees, prepaid interest and other credit costs). The APR is calculated by spreading these charges over the life of the Loan, which results in a rate higher than the interest rate shown on the mortgage/deed-of-trust note. If interest was the only finance charge, then the interest rate and the annual percentage rate would be the same.
Verified Dt
Specify the contract verification date.
Verified By
View the user id who verified the contract.
Signing Dt
Select the signing date on when the documents is signed.
Probable Delivery Dt
Select the probably delivery date.
Note: For Islamic products the following additional fields will be displayed.
Residual Income
View the residual income for the residual days.
Residual Days
View the number of residual days.
IRR
View the interest rate of return.
Profit Rate
View the profit rate (display only).
Instrument Details – An instrument is a contract with specific rules tied to it. An instru­ment associated with the application indicates OFSLL of the type of contract being used for the approved loan. Items defined in the contract are “locked in” when you select the instrument from drop down list and click on "Load Instrument Details". These values cannot be changed on the funding screen.
Any changes to the instrument in account will be handled by monetary/non-monetary transactions.
The system loads all the rules established by the company that are required at the time of funding; for example, the accrual method, billing method, type of billing, tolerance, due dates, extensions and so on.
Accrual Method
View the accrual calculation method.
Start Dt Basis
View the accrual start basis.
Base Method
View the accrual base method.
Bill Method
View the billing method.
Bill Type
View the billing type.
Time Counting Method
View the time counting method.
Installment Method
View the installment methods.
Calendar Method
View the Calendar Method.
Start Days
View the accrual start days.
Stop Accrual Days
View the accrual stop days.
ACH Fee Ind
Indicates that the ACH fee should be applied or not. Depending on the status of check box, the ACH fee is applied based follow­ing conditions
- When the check box is selected and the fee amount is ZERO, system will not apply the ACH fee.
- When the check box is selected and the fee amount is BLANK, system will apply the ACH fee from Contract setup.
- When the check box is selected and the fee amount is specified, system will apply the specified amount and overrides the ACH fee amount mentioned in Contract Setup.
- When the check box is not selected, system will apply the ACH fee amount mentioned in Contract Setup.
Capitalization section
This section displays the capitalization parameters pre-defined at Setup > Contract screen and allows you to modify only the ‘Grace Days’ value for balance capitalization.
Capitalize
If selected, indicates that the capitalization of balances is enabled while funding the application.
Frequency
View the capitalization frequency defined at Contract level.
After funding, all the account balances are capitalized to principal in the same frequency except for ‘Balance Frequency’ where different frequency may be defined for each balance type.
Capitalization Start Basis
View the capitalization start date as either Contract Date or First Payment Date on which capitalization next date is calculated.
Grace Days
View or Modify the grace days allowed in the frequency (minimum 0, maximum 31) before capitalizing the balances to account. This is also the deciding factor for executing the capitalization batch job which is based on Capitalization Frequency + Grace Days.
However, note that Grace Days are not accounted for Month End type of capitalization frequency and is ignored even if specified.
Cap Tolerance Amt
View the capitalization tolerance amount which is the minimum amount to qualify for capitalization.
Promotion Details – If applicable, enter information regarding any promotion associ­ated with the application in the Promotion section
Promotion
Select the promotion.
Type
View the promotion type.
Dlq Days
View the delinquency days.
Period Type
View the period type.
Period
View the promotion period.
Tolerance Amt
View the tolerance amount (displays only).
Index
View the promotion index (displays only).
Index Rate
View the promotion index rate (displays only).
Promotion Margin Rate
View the promotion margin rate (displays only).
Promotion Rate
View the promotion rate.
Rate Caps and Adjustments section
Increase Per Year
View the maximum rate increase allowed in a year.
Increase Max Life­time
View the maximum rate increase allowed in the life of the Loan.
Increase Floor
View the rate cap (minimum).
Increase Ceiling
View the rate cap (maximum).
Decrease Per Year
View the maximum rate decrease allowed in a year.
Decrease Max Lifetime
View the maximum rate decrease allowed in the life of the Loan.
# of Adjs / Year
View the maximum number rate changes allowed in a year.
# of Adjs / Life
View the maximum number of rate changes allowed in the life of the Loan.
Advance section
Stage Fund Allowed
If selected, indicates that multiple disbursements are allowed.
Draw End Dt
Specify the advance draw end date.
Initial Advance Max Amt
View the maximum initial advance amount.
Initial Advance Min Amt
View the minimum initial advance amount.
Advance Max Amt
View the maximum subsequent advance amount.
Advance Min Amt
View the minimum subsequent advance amount.
Late Charge Allowed
If selected, late charges are allowed during the disbursement period.
Billing Allowed
If selected, billing is allowed during the disbursement period.
Billing Method
View the billing method during the disbursement period.
Draw Period Rate
Specify the applicable interest rate during the disbursement period.
PDC section
PDC Ind
If selected, indicates that the customer has opted for PDC.
PDC Security Ind
If selected, indicates that the customer has submitted the PDC as a security.
Escrow section
Allowed
View the escrow allowed indicator. If selected, escrow is allowed for this account.
Opt Out
View the escrow opt out indicator. If selected, escrow is not allowed for this account.
Post Maturity section
Default Rate
If selected, indicates the default rate is available.
Index
Select the post maturity index.
Post Margin Rate
Specify the past maturity rate.
Billing section
Pre Bill Days
This is the number of days before the first payment is due that accounts funded with this Loan instrument will be billed for the first payment. Thereafter, the accounts will be billed on the same day every month.
If an account has a first payment date of 10/25/2003 and Pre Bill Days is 21, then first payment due will be on 10/04/2003, and then 4th of every month.
Bill Cycle
View the billing cycle.
Multiple Billing Asset Rate
Check this box to indicate if multiple asset rates are applicable for one billing period.
System considers billing period from current due date to the next due date. Multiple rates are fetched only when rate end date (rate start date + rate frequency) ends one or more cycle(s) before the next due date i.e. current rate record does not cover the entire billing period.
Payment Caps
Max Pmt Increase / Year
The maximum payment that can be increased for the year.
Max Pmt Increase / Life
The maximum payment that can be increased in the life of an application.
Others
Payment Mode
Select the type of repayment mode to indicate if it is ‘Autopay/Direct Debit or not’ using any of the following option from the drop-down list. The list is populated from REPAYMENT_PMT_­MODE_CD lookup code.
- INSTITUTION DRAFT / CHECK (default)
- AUTOPAY (ACH)
- AUTOPAY (CREDIT CARD)
- AUTOPAY (DEBIT CARD)
- POST DATED CHECKS
For an AUTO PAY type of Payment Mode, ensure that at least one active ACH record exist and for CHECK type of Payment Mode, there are NO active ACH records.
Statement section
This section allows to define the preferences for Mock Statement generation at Master Account level. Generating a Mock Statement helps to mock the asset billing process with a future date and to get an upfront statement indicating future dues of Master and Associated Accounts. In ‘Vacation Ownership’ industry, such statements are required to forecast future dues based on current ‘Timeshare’ holdings.
The default populated preference here are propagated from Setup > Administration > Products > Contract screen when the instrument is loaded.
Note: These fields are enabled only for Master Account, i.e. only if the ‘Master Account’ check box is selected in Origination > Master Account tab. If the option is unchecked even at a later point, system refreshes these fields making them as ‘Read-Only’.
Stmt Preference Mode
Select the account statement preference mode as either Email or PHYSICAL from the drop-down list.
Mock Statement Req
Select this check box to indicate if the account is to be included in Mock statement Generation.
Note: Based on this selection, others fields related to Mock Statement below are enabled and becomes mandatory for providing details.
Mock Start Month
Select the start month of Mock Statements period from the drop-down list.
Note: During the ‘Mock Statement Next Run Date’ validation if next run date is less than Contract Date or GL Date, system moves the ‘Mock Start Month’ to same month of next year. For more information, refer to ‘Mock Statement Maintenance’ in Appendix - Non Monetary transactions sections.
Mock Statement Cycles
Select the total number of billings (between 1-12) that are to be generated post Mock Statement Start Date.
Mock Pre Statement Days
Specify the number of Pre bill days for Mock Statements generation.
Recourse Details
Recourse
View the recourse indicator. If selected, it indicates that there is a recourse associated with the Loan and the following recourse details can be specified.
Recourse Type
Select the recourse type as either 'Partial' or 'Full' from the drop-down list.
Recourse Rea­son
Depending on the type of recourse selected, you can select the following type of recourse reason from the drop-down list.
For recourse type as 'Partial', system defaults the recourse rea­son as ‘Partial’.
For recourse type as 'Full', you can select one of the following options:
- Fraud
- Titles
- Fraud and Titles
- Full
- Full and Titles
Recourse Max %
Specify the maximum percentage of recourse allowed. Ensure that the specified amount does not exceed 100% or the amount defined at Contract.
Note: You can specify the recourse either in percentage or as flat amount in the below field.
Recourse Amt
If ‘Recourse Max %’ is not specified, you can specify a flat amount to be allowed for recourse.
  1. Perform any of the Basic Actions mentioned in Navigation chapter.
  2. Quick Calculate
In the ‘Contract Information’ section, there is a drop-down list adjacent to the ‘Calculate’ button with following options to auto calculate different Loan parameters based on the data provided. Select the required option from the drop-down list and click ‘Calculate’:
The system displays the requested calculation in the respective field.
  1. Click Calculate. The system displays the calculation in the respective field.
Imputed Interest
Imputed interest is the difference of interest rate arising when the regulatory rate offered is less than the contract rate (i.e. market rate). As per the tax regulations, if the stated (regulatory rate) and market (contract) interest rates are substantially different, it is necessary to record the transaction using an interest rate that more closely accords with the market rate.
Hence, for a loan with imputed interest rate, along with repayment schedule which consist of EMI, Principal, Interest and Outstanding Balance, there is also ‘Imputed Interest Amortization Schedule’ generated to depict the imputed interest calculated with ‘Present value of Principal’ (PVP).
Though imputed interest is part of advance principal, the tax calculation is indicated as ‘Imputed Interest’ which is an additional income and is taxable. The imputed interest calculation follows repayment schedule and amortization schedule is processed on executing the batch job TAMIMP_BJ_100_01 (IMPUTED INTEREST AMORTIZATION TRANSACTIONS PROCESSING).
As part of the funding, if the ‘Contract Imputed Rate’ is greater than ‘0’, system calculates Imputed Interest Amortization schedule based on following calculation:
To record the imputed interest amount during loan creation stage, system automatically posts FND IMPUTED INTEREST monetary transaction with total imputed interest amount. In case of loan reversal/cancellation, REVERSE FND IMPUTED INTEREST transaction is posted to post reversal entry on account for imputed interest.
Once the application is funded, the Contract Imputed Rate is propagated to Servicing > Account Details > Contract Information tab.
Amortization Transactions record is created in Servicing > GL Transactions > Amortized Transactions with the following details:
If case there is a change in repayment schedule due to change in interest rate, then respective imputed interest rate also changes since the principal changes. Along with this, if there is an early Payoff or account Charge-off, the remaining unearned imputed interest is written-off. On posting monetary transactions which changes the repayment schedule such as ‘Due Date Change’, ‘Due Date Change Override’, ‘Change Term’ and so on, system recalculates imputed interest amortization schedule along with repayment schedule and posts an Imputed Interest amortization adjustment transaction.
In above cases, system posts the following adjustments/write-off and reversal transactions automatically on loan account to basically write-off some amount:
System automatically creates imputed interest related transaction/journal entries at the time of processing of the following transactions of loan account.
8.12.1 Contract (2) Sub Tab
The Contract sub screen records the application’s servicing branch and collector. It also displays additional information regarding the contract not covered on the Loan screen, such as the tolerance, delinquencies, due dates, billings, and extensions.
To complete the Contract sub tab
  2. Click the Contract > Contract sub tab.
  3. In this section, you can perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Servicing Branch
Select the servicing branch for the contract.
Collector
Select the collector for the contract.
Funder
If you are acting as a proxy for a Funder, then you can select the Funder’s name from the adjoining options list. The list displays all the associated Funders, Funding Supervisors, and Funding Managers.
However, this is not mandatory and can be used while auc­tioning an application on behalf of another Funder.
Misc section
Statement Consolida­tion
By default this check box is selected indicating that system generates consolidated billing statement at Master Account level along with details of all the associated accounts with same Billing cycle and due day.
You can uncheck this option to generate billing statement to only current account.
After funding, the option selected here is propagated to Ser­vicing > Account Details and Contract (2) tabs.
For more information, refer to Master Account tab section.
Link To Existing Cus­tomer
Select to link the application to the existing customer.
Anniversary Period
View the anniversary term.
Default Pmt Spread
View the spread.
HMDA section
Lien Status
Select the lien status.
HOEPA
Select the home owner equity protection act (HOEPA) code.
Rate Spread
Specify the rate spread. You can calculate this spread from a tool on the Home Mortgage Disclosure Act (HMDA) website.
Others section
1st Pmt Deduction
View the first payment deduction indicator. If selected, the first payment deduction is in use.
Days
View the first payment deduction days.
1st Pmt Refund
View the first payment refund indicator. If selected, the first payment refund is in use.
Days
View the first payment refund days.
Pre-Pmt Penalty
View the prepayment penalty indicator. If selected, a prepay­ment penalty can be applied.
% of Term for Penalty
View the prepayment penalty percentage of term.
Pay Off Fee
View the payoff fee indicator. If selected, a payoff fee can be applied to the Loan.
Rebate section
Rebate Method
View the rebate calculation method.
Rebate Term Method
View the rebate term method.
Rebate Min Fin Chg Method
View the rebate minimum finance charge calculation method.
Rebate Min Fin Chg Value
View the minimum finance charge value.
Acquisition Charge Amt
View the acquisition charge amount.
Tolerance section - This section displays the tolerance details as defined in Setup > Products > Contract screen.
Refund Allowed
View the refund allowed indicator. If selected, the refund pol­icies in this section are in use.
Refund Tolerance
View the refund tolerance amount.
Pmt Tolerance Amt
View the payment tolerance amount.
Pmt Tolerance%
View the payment tolerance percentage.
Promise Tolerance Amt
View the ‘Promise to Pay’ tolerance amount.
Promise Tolerance %
View the ‘Promise to Pay’ tolerance percentage.
Writeoff Tolerance
View the write-off tolerance amount.
Delinquency section
Late Charge Grace Days
View the late charge grace days.
Delq Grace Days
View the delinquency grace days.
Delq Category Method
View the delinquency category method.
Time Bar Years
View the total number of years allowed to contact the customer starting from the first payment date as defined in Setup > Products > Contract screen.
Cycle Based Fees - If the ‘Cycle Based Fees’ assessment is enabled for the selected instrument, the details of the defined parameters in Setup > Contract screen are propagated into this section. On funding the application, system automatically calculates the late charges at individual account level based on threshold value. For more information, refer to Setup > Contract details.
Cycle Based Collection Late Fee
If selected, indicates that Cycle Based Collection Late Fee is assessed on the account.
Cycle Based Late Fee
If selected, indicates that Cycle Based Late Fee is assessed on the account.
Cycle Based Collection Late Fee Grace Days
Indicates the number of grace days allowed before cycle based fee is assessed on the account.
Cycle Based Late Fee Grace Days
Indicates the number of grace days allowed before cycle based late fee is assessed on the account.
Due Date section
Max Due Day Change Days
View the maximum due days.
Min Due Day
View the minimum due day.
Max Due Day
View the maximum due day.
Max Due Day Change Year
View the maximum due day changes allowed (year).
Max Due Day Change Life
View the maximum due day changes allowed (life).
Fee Consolidation - This section displays the status of Fee Consolidation indicators propagated from Setup > Contract screen. If enabled, indicates that system is allowed to consolidate that particular late fee at Master Account level.
Late Charge at Master Account
If selected, indicates that system is allowed to consolidate the late charge assessment at master account level.
Cycle Based Collection Late Fee at Master Account
If selected, indicates that system is allowed to consolidate the cycle based collection late fee assessment at master account level.
Cycle Based Late Fee at Master Account
If selected, indicates that system is allowed to consolidate the cycle based late fee assessment at master account level.
Extension section
Max Extn Period / Year
View the maximum extension allowed (year).
Max Extn Period / Life
View the maximum extension allowed (life).
Max # Extn / Year
View the maximum number of extensions allowed (year).
Max # Extn / Life
View the maximum number of extensions allowed (life).
Minimum # Payments
View the minimum number of payments.
Extension Gap in Months
View the extension gap in months.
8.12.2 Repayment Sub Tab
The Repayment sub screen records the application’s advance information, repayment schedule, and skipped repayment months for variable rate Loan.
To complete the Repayment sub tab
  2. Click the Contract > Repayment sub tab.
Field:
Do this:
Repayment section:
Flexible Repay­ment Allowed
If this display only check box is selected, then the flexible repay­ment functionality is set up and allowed for this application's prod­uct type.
Type
Select the flexible repayment schedule you want to use from the following: SKIP PERIOD, USER DEFINED, UNDEFINED.
If you select the repayment schedule type of SKIP PERIOD, you then select the months for which borrower won't make any pay­ments in the Skip Months section.
If you select the repayment schedule type of USER DEFINED, you then enter the repayment schedule requested by borrower in the Schedule section; for example, $300.00 for first 12 months, $350.00 for next 18 months, and so on.
Note: The borrower may not provide a complete repayment sched­ule with the contract. Provisions are available with the system to compute the repayment schedule for remaining periods at a later time, if borrower provides partial repayment schedule.
Skip Months section
Jan
If selected, indicates that repayment is skipped for January.
Feb
If selected, indicates that repayment is skipped for February.
Mar
If selected, indicates that repayment is skipped for March.
Apr
If selected, indicates that repayment is skipped for April.
May
If selected, indicates that repayment is skipped for May.
Jun
If selected, indicates that repayment is skipped for June.
Jul
If selected, indicates that repayment is skipped for July.
Aug
If selected, indicates that repayment is skipped for August.
Sep
If selected, indicates that repayment is skipped for September.
Oct
If selected, indicates that repayment is skipped for October.
Nov
If selected, indicates that repayment is skipped for November.
Dec
If selected, indicates that repayment is skipped for December.
Extendable Balloon section
Max Term
Specify maximum number of payments.
  2. In the Repayment Schedule section, click View.
  3. View the following information:
    Note: Complete the Schedule section only if you have entered USER DEFINED in the Repayment section’s Type field. Click Add to make new entries.
    Seq
    Specify the sequence number of the repayment schedule.
    Pmt Amt
    Specify the repayment amount borrower agreed to pay during the schedule.
    # of Pmts
    Specify the number of payments borrower agreed to pay for stated repayment amount during this schedule.
    Generated
    If selected, indicates that the schedule is system generated.
    Enabled
    If selected, indicates that the schedule is enabled.
  4. In the Payment Change Schedule section, click View.
  5. View the following information:
    Seq
    Specify the payment sequence number.
    Option Type
    Select the option type.
    Frequency
    Specify the payment change frequency.
    Period
    Specify the period.
    # of Adj
    Specify the number of adjustments.
    Value
    Specify the adjustment value.
8.12.3 Itemizations Sub Tab
The system lists the distribution of the Loan proceeds on the Itemizations sub screen when you choose Select Instrument on the Contract link. It lists amounts paid to the borrower directly, amount paid to the borrower’s account, and amount’s given on the borrower’ behalf to third parties. Itemizations are categorized according to advances, finance fees, prepaid fees, producers or escrows. If you have entered itemization amounts during application entry or underwriting, you will see these values in the Amount or Approved Amt columns.
The Itemizations sub screen offers the option of computing the values for itemization according to a itemization formula associated with the selected instrument based on system setup.
If you require any new itemizations, you can add them using the Setup menu Products command. (For more information, see the Products chapter in the Setup Guide.)
To complete the Itemizations
  2. Click the Contract > Itemizations sub tab.
Field:
Do this:
Itemization
View the itemization.
View whether the itemization is added or subtracted.
Amount
View the amount.
Approved Amt
View the approved amount. This is information recorded on the Underwriting screen.
Discount Rate
Specify the discount rate.
Tax
View whether the itemization is taxable (Sales) if box is selected.
Slr
View the seller payment.
Itemization Formula
View the itemization type.
Itemization Type
Prefunding Status
View the prefunding status.
Pmt Dt
View the payment date.
Pmt Ref #
View the payment reference number.
Comment
Specify additional comments, if any.
  1. Choose the option button for the type of itemization you want to use: Advance, Financed Fees, Pre-Paid Fees, Producer or Escrow.
  2. In the Amount column, enter the amount corresponding with what is listed in the Itemization column.
  3. If the Itemization Formula field contains an entry other than UNDEFINED, you can choose Compute to auto-compute the value in the Amount field using a predefined itemization formula.
Itemization formulas are created on the Product Setup screen’s Origination Fees screens. (For more information, see the Org. Fees tab section of the Products chapter in the Setup Guide.)
To ensure you create the correct computed value, choose Compute after entering values for all base itemizations; that is, values of all such itemizations with an Itemization Formula of undefined.
You can also manually enter amounts for auto-computed itemizations.
If you click Initialize, the system sets the values of auto-computed itemizations to 0 (zero).
  1. If you choose, use the Comment field to add remarks.
  2. Perform any of the Basic Actions mentioned in Navigation chapter.
8.12.4 Trade-In Sub Tab
If there is any information regarding an itemized trade-in, use the Trade-In sub screen to enter the details in the system (This sub screen might already contain information supplied during the underwriting process.)
To complete the Trade-In sub screen
  2. Click the Contract > Trade-In sub tab.
Field:
Do this:
Trade In section
Asset Type
Select the asset type.
Asset Sub Type
Select the asset sub-type.
Year
Specify the year of the asset.
Make
Specify the make of the asset.
Model
Specify the model of the asset.
Identification #
Specify the identification number.
Body
Specify the body of the asset.
Description
View the asset description.
Valuations section
Wholesale Amt
Specify the wholesale amount.
Base Retail Amt
Specify the retail amount.
Addons Amt (+)
Specify the add ons amount.
Payoff Amt (-)
Specify the payoff amount.
Total Amt =
View the total amount.
Valuation Dt
Specify the valuation date.
Source
Select the valuation source.
Valuation Supple­ment
Specify the valuation supplement.
Edition
Specify the valuation edition.
8.12.5 Subvention Sub Tab
With the Subvention sub screen, you can enter the subvention information and calculate the subvention amount, as well as override the calculated subvention amount. The participant’s information is automatically populated based on the selected subvention plan.
To use the Subventions sub screen
  2. Click the Contract > Subventions sub tab.
  4. A brief description of the fields is given below:
    Field:
    Do this:
    Subvention section:
    Plan
    Select the subvention plan code.
    Description
    View the subvention plan description
    Sub Plan
    Select the sub plan.
    Sub Plan Description
    Select the subvention sub plan.
    Subvention Type
    View the subvention type
    Subvention Amount
    View the subvention amount for the plan.
    Include
    If selected, indicates that the subvention is included.
  5. Click View in the Subvention Details section.
View the following:
Participants section:
Participant
View the participant.
Participant Type
View the participant type
Collection Method
View the collection method.
Rate
View the subvention rate.
Rent Factor
View the subvention rent factor.
Calculation Method
View the subvention calculation method.
Factor
View the factor.
Calculated Amount
View the calculated subvention amount.
Subvention Amount
Specify the subvention amount.
Total Subvention Rate
View the total subvention rate.
Total Subvention Amount
View the total subvention amount.
Include
  1. Click Initialize to reset the subvention amount to zero.
  2. Click Calculate to calculate the subvention amount.
  3. Perform any of the Basic Actions mentioned in Navigation chapter.
8.12.6 Insurance Sub Tab
If there is any information regarding an itemized insurance amount, enter the details on the Insurance sub screen. The Insurance sub screen also enables you to calculate the commission if there is a commission rule defined during Contract setup.
To complete the Insurance sub tab
  2. Click the Contract > Insurance sub tab.
Field:
Do this:
Insurance Plan
Select the insurance plan associated with the financed insurance product.
Insurance Type
View the insurance type associated with the insurance plan.
Sub Type
Select the insurance sub type offered under the insurance plan.
Insurance Com­pany
Specify the insurance company associated with the insurance plan. The system populates the default insurance plan defined during product setup.
Policy #
Specify the insurance policy number.
Effective Dt
Specify the insurance effective date.
Term
Specify the insurance term.
Expiry Dt
Specify the insurance expiry date.
Commission Rule
View the insurance premium amount.
Premium Amt
Specify the insurance premium amount.
Commission Amt
View the insurance commission amount.
Phone
Specify the insurance company’s primary phone number.
Extn
Specify the insurance company’s primary phone extension.
Phone
Specify the insurance company’s alternate phone number.
Extn
Specify the insurance company’s alternate phone extension.
Beneficiary section
Primary
Specify the primary beneficiary of the insurance.
Secondary
Specify the secondary beneficiary of the insurance.
Cancellation/Refund section
Cancellation Refund Allowed
If selected, a refund is allowed. A selected box indicates that the insurance premium can be rebated to the customer in case of early payoff.
Grace Days
View the number of grace days allowed for cancellation without charging a cancellation fee.
Calculation Method
View the insurance premium refund/rebate calculation method to be used when insurance is cancelled.
Grace Days Can­cellation Fee Allowed
If selected, indicates that cancellation fees during grace is allowed.
Cancellation Fee
View the amount of the cancellation fee to be charged when the insurance is cancelled.
Deduct Fee From
View the option defined in setup screen (Setup > Administration > Products > Insurances) to deduct the cancellation fee.
‘Premium Amount’ indicates fee is deducted upfront before computation and ‘Rebate Amount’ indicates fee is deducted after computation.
  1. If you click the Calculate button, the system computes the commission based on the commission method in the Cancellation/Refund section.
The commission appears in the Commission Rule and Commission Amt fields of the Policy Information section.
It also appears on the Itemizations sub screen.
You can overwrite the suggested value if you choose.
8.12.7 ESC Sub Tab
If there is information regarding an itemized extended service contract or warranty amount, enter the details on the ESC sub screen.
To complete the ESC (extended service contracts) sub tab
  2. Click the Contract > ESC sub tab.
    Field:
    Do this:
    Warranty Information section
    Service Con­tract
    View the extended service contract type.
    Policy #
    Specify the ESC number.
    Effective Date
    Specify the ESC effective date.
    Term
    Specify the ESC term.
    Expiration Dt
    Specify the ESC expiry date.
    Premium Amt
    View the ESC premium amount
    Commission Amt
    View the commission amount.
    Commission Rule
    View the commission rule.
    Warranty Company
    Specify the ESC company’s name.
    Comment
    Specify comment if any.
    Phone No
    Specify the ESC company’s primary phone number.
    Extn
    Specify the ESC company’s primary phone extension.
    Phone No
    Specify the ESC company’s alternate phone number.
    Extn
    Specify the ESC company’s alternate phone extension.
    Cancellation/Refund
    Allowed
    Check this box to allow cancellation/refund.
    Method
    Specify the method of cancellation/refund.
  5. In the Cancellation/Refund section, view the following information.
The commission appears in the Commission Rule and Commission Amt fields of the Warranty Information section.
8.12.8 Escrow Sub Tab
If there is escrow information selected on the Itemization sub screen, enter information about it on the Escrow sub screen. The Escrow sub screen records escrow details regarding disbursement, insurance, and property tax -- information that is parsed to the Customer Service screen on the Customer Service (2) master tab, where it is available for maintenance.
This sub tab is available if escrow is allowed for the instrument selected on the Loan screen.
The Escrow Analysis screen enables you to view and perform the initial escrow analysis. You can perform multiple analyses; however, the system records only the most recent analysis.
To complete the Escrow sub screen
  2. Click the Contract > Escrow sub tab.
  3. The Escrow Information section displays information regarding the escrow recorded on the Itemization sub screen. In this section, you can perform any of the Basic Operations mentioned in Navigation chapter.
Field:
View:
Escrow
The escrow itemization code and description.
Escrow Type
The escrow type.
Escrow Sub Type
The escrow sub type.
Advance Amt
The amount that’s been approved for the Item in the itemiza­tion screen under the escrow.
Required Escrow
If selected, indicates that this is mandatory itemization and customer can not opt out of this escrow item.
Cushion Allowed
If selected, indicates that cushion is allowed.
  1. Select the Opt Out box only if you want to ignore this particular escrow.
  2. In the Disbursement section, enter the following information:
    Field:
    Do this:
    Rule
    Select disbursement rule.
    Yearly Amt
    Specify yearly disbursement amount.
    Account #
    Specify reference account number for vendor.
    Note: If the organizational parameter UIX_HIDE_RESTRICTED_­DATA is set to Y, this appears as a masked number; for example, XXXXX1234.
    Vendor
    Specify the vendor name.
    Maturity Dt
    Specify the maturity date, if one exists.
  3. If this escrow involves an insurance, use the Insurance section to enter the following information:
    Field:
    Do this:
    Coverage Type
    Specify the coverage type.
    Coverage Term
    Specify the coverage term.
    Policy #
    Specify the policy number.
    Coverage Amt
    Specify the coverage amount.
    Effective Dt
    Specify the effective date.
    Expiration Dt
    Specify the expiration date.
  4. If this escrow involves a tax, use the Tax section to enter the following information:
    Field:
    Do this:
    Property Tax Type
    Specify property tax code.
    Comment
    Specify a comment.
  5. Perform any of the Basic Actions mentioned in Navigation chapter.
8.12.9 Compensation Sub Tab
The Compensation (Loan) sub tab records and displays the terms of compensation between the finance company and the dealer for Loan transactions.
To complete the Compensation (Loan) sub screen
  1. Open the Funding screen from the Origination master tab’s Funding bar link and load the application you want to work with.
  2. Click the Contract > Compensation sub tab.
  3. On the Compensation sub screen’s Compensation section, select in the Compensation Plan section the compensation plan you want to use.
  4. Click Load.
The system loads the following information on the Compensation sub screen:
Field:
Do this:
Compensation Plan
View the compensation plan.
Disbursement Method
View the compensation payment method.
Calculation Method
View the compensation calculation method.
Chargeback section
Paid Calc Method
View the charge back calculation method (early payoff).
Paid %
View the percentage of chargeback paid.
Paid Basis
View the charge back paid basis.
Paid Term
View the charge back paid term.
Paid Days
View the charge back paid days.
Charge off Calc Method
View the charge back calculation method (charge off).
Charge off %
View the charge back percentage (charge off).
Charge off Basis
View the charge back basis (charge off).
Charge off Term
View the charge back term (charge off).
Days
View the charge back days (charge off).
Calculation section
Spread Formula
View the compensation spread formula.
Buy Rate
Specify the buy rate.
Factor
View the compensation factor.
Addl Factor
View the additional compensation factor.
Max Spread %
View the maximum spread or percent allowed.
Upfront %
View the upfront compensation percentage.
Flat Amt
View the flat amount.
Upfront Comp Amt
View the compensation amount paid upfront.
Rem Comp Amt
View the compensation amount remaining.
Comp Amt
View the compensation amount.
  1. Make any necessary changes in the Buy Rate field.
  2. Click Calculate.
The system displays the details and amounts for this compensation plan.
8.12.10 Proceeds Sub Tab
The Proceeds sub screen displays the payment amount due to the dealer, based on the Compensation and Itemization sub screens. It is a view only sub screen, though you can record comments.
To use the Proceeds
  2. Click the Contract > Proceeds sub tab.
Field:
Do this:
Itemization
View the proceed itemization.
View whether the itemization is added to or subtracted from the total proceeds.
Amount
Specify the amount.
Currency
Specify the currency of the proceed.
Comment
Specify a comment.
Total Amount
8.12.11 Disbursement Sub Tab
The Disbursement sub screen records how the Loan payment is disbursed and records payments to third parties such as the Department of Motor Vehicles. This sub screen needs to be completed if there is an itemized disbursement.
To complete the Disbursement sub screen
  2. Click the Contract > Disbursement sub tab.
Field:
Do this:
Validate Payee
Check this box to validate payee.
Description
View the disbursement description.
Number
Specify the disbursement party’s number.
Payment Mode
Select the payment mode.
Name
Specify the company name.
Account #
Specify the account number.
Amount
View the payment amount.
Currency
Specify the currency.
ACH Account Type
Specify the account type.
Account #
Specify the ACH account number.
ACH Bank
Specify the bank number.
ACH Routing #
Specify the routing number.
BIC
Select the Business Identifier Code from the drop-down list. The list displays the BIC codes defined in the system.
IBAN
Specify the IBAN (International Bank Account Number). IBAN is used for identifying bank accounts across national borders with a minimal of risk of propagating transcription errors.
Ensure that value entered satisfies the check-digit validation based on modulo 97. On save, system automatically validates the IBAN number length based on country code, characters, white spaces, and checksum. Validation is also done during posting non-monetary transaction (ACH Maintenance).
You can maintain the IBAN length and other details required as per the country code in the user defined table (Setup > Adminis­tration > System > User Defined Tables).
Note: IBAN for 'NL' country code (IBAN_FORMAT_NL) is defined by default with length of IBAN as 18.
Comment
Specify a comment.
Country
Select the country.
Address Line 1
Specify the address line 1.
Address Line 2
Specify the address line 2.
Zip
Specify the zip code.
For non US country, you have to enter zip code.
City
Specify the city.
State
Select the state.
Phone 1
Specify the primary phone number.
Extn
Specify the primary phone extension.
Phone 2
Specify the alternate phone number.
Extn
Specify the alternate phone extension.
Disbursement tab will display the records only if a third party itemization is maintained during contract setup.
8.12.12 Fee Sub Tab
The Fee sub screen is a view-only table displaying what fees on the Loan instrument are in use, based on the contract.
To view the Fee
  2. Click the Contract > Fee sub tab.
  3. In the Fee sub screen, view the following display only information:
    Field:
    Do this:
    Fee
    View the fee type.
    Fee Calc Method
    View the fee calculation method.
    Txn Amt From
    View the minimum transaction amount.
    Amount Financed From
    View the minimum value of amount financed on the contract.
    Percent
    View the maximum percentage.
    Threshold Amt
    View the threshold amount beyond which system is allowed to calculate and post late fee on the account. This is applicable only for Cycle Based Collection Late Fee and Cycle Based Late Fee and the value is propagated from defined in Setup > Contract > Fees tab.
    Min Amt
    View the minimum fee amount.
    Max Amt
    View the maximum fee amount.
    Enabled
    If selected, the fee rule is enabled.
8.12.13 ACH Sub Tab
The ACH sub screen records details about automatic clearing house, if this is a direct deposit payment account; otherwise, it remains empty. This information is used to receive payments, primarily when working with the Payments screen.
To complete the ACH
  2. On the Funding screen, click the Contract tab, then choose the ACH sub tab.
Field:
Do this:
Bank Name
Specify the bank name.
Routing #
Payment Mode
For an active Recurring ACH record, the payment mode selected in Contract tab is automatically populated. If not, select the type of repayment mode to indicate the type of ‘Autopay/Direct Debit’ using any of the following option from the drop-down list. The list is popu­lated from REPAYMENT_PMT_MODE_CD lookup code.
- AUTOPAY (ACH)
Status
Select the required ACH status from the drop down list. By default, the ACTIVE status is selected.
Default
By default, this check box is selected indicating that the current ACH is the default one. If not, you need to uncheck the same.
Start Dt
Specify the ACH start date. By default the first payment date of the contract is auto populated and can be edited.
End Dt
Specify the ACH end date.
Account Type
Select the account type.
Account #
Specify the account number. Note: If the organizational parameter UIX_HIDE_RESTRICTED_DATA is set to Y, this appears as a masked number; for example, XXXXX1234.
BIC
IBAN
You can maintain the IBAN length and other details required as per the country code in the user defined table (Setup > Administration > System > User Defined Tables).
Pmt Day
Specify the payment day. By default the payment due day specified for the contract is auto populated and can be edited.
Pmt Amt
Specify the payment amount. By default the payment amount decided for the contract is auto populated and can be edited.
Note: If the payment amount is specified as ZERO, system will automatically consider the EMI amount.
Pmt Amt Excess
Specify the additional payment (if any). This is the additional amount over and above the regular EMI. Appropriation of this amount is based on the ‘Spread’ defined in the contract.
Pmt Freq
Select the payment frequency. By default the bill cycle frequency defined for the contract is auto populated and can be edited.
  2. If there are more than one ACH banks and an optional End Date, click Add and repeat steps 3 through 5.
8.12.14 Coupon Sub Tab
The Coupon sub screen enables you to order (or re-order) new coupon books. This sub screen is only available if the bill type for this application is a coupon payment, not a statement.
To complete the Coupon
  2. Click the Contract > Coupon sub tab.
Field:
Do this:
Order
Select to order coupon book.
Order Dt
Specify the coupon book order date.
Ordered By
Select the user id of the user who ordered the coupon book.
# of Coupons
Specify the number of coupons.
First Pmt Dt
Coupon Start­ing #
Specify the starting number of the coupon book.
8.12.15 References Sub Tab
The References link enables you to enter any number of people as a reference on the application.
To complete the Reference screen (Contract link)
  2. Click the Contract > References link in this section, you can perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Relationship
Select the reference type.
Name
Specify the reference name.
Status
Select the status of the reference from the drop-down list.
Years
Specify the number of years.
Months
Specify the number of months.
Comment
Specify a comment.
Country
Select the country.
Address Line 1
Address Line 2
State
Select the state.
Zip
Select the zip code.
Zip Extn
Specify the zip extension.
City
Specify the city.
Phone 1
Specify the reference’s primary phone number.
Extn
Specify the reference’s primary phone extension.
Permission to call
Check this box if customer has provided permission to contact through the specified phone number.
When selected, system auto validates this option against the phone number specified. Atleast one phone number should have the per­mission to call for successful pre-qualification of the application. Else, an error message is displayed.
Permission to Text
Check this box if customer has provided permission to contact through text message.
Phone 2
Specify the reference’s secondary phone number.
Extn
Specify the reference’s secondary phone extension.
Permission to call
Permission to Text
If you want to add another reference, click Add and repeat steps 3 and 4.
8.12.16 Real Estate Sub Tab
The Real Estate Fields screen records additional information regarding manufactured home Loan.
To complete the Real Estate Fields screen
  1. Open the Funding screen and load the application you want to work with.
  2. Click the Contract > Real Estate.
Field:
Do this:
Note Transmittal Number
Specify the note transmittal number.
Deed Transmittal Number
Specify the deeding transmittal number.
Cancel/Cashout Transmittal Number
Specify the deeding cancel/cash out transmittal number.
Deed Input Date
Specify the deed input date.
Deed Recording Date
Specify the deed recording date.
Deeding Book Number
Specify the deeding book number.
ConDeeding Page Number
Specify the condeeding page number.
Mortgage Recording Date
Specify the mortgage recording date.
Mortgage Book Number
Specify the mortgage book number.
Mortgage Page Number
Specify the mortgage page number.
8.12.17 PDC Sub Tab
The PDC sub screen displays any post dated checks associated with the contract.
To complete the PDC
  2. Click the Contract > PDC sub tab.
Field:
Do this:
PDC Ind
If selected, indicates that this account involves a post dated check as a method of repayment.
PDC Type
Select the post dated check type, Security checks or post dated checks for payment.
Account #
Specify the account number, on which the cheque is drawn.
Routing #
Specify the routing number of the cheque. It is the number printed on the cheque, also called MICR number (Magnetic Ink Character Rec­ognition).
Account Type
Specify the type of the account
Bank Name
Specify the bank name of the customers cheque
Branch Name
Specify the Branch name of the customers cheque
Docket #
Specify the docket number where post dated checks are supposed to be stored.
Check #
Specify the starting cheque number.
Check Dt
Select the check date. In case there are multiple checks being deposited that have sequential serial numbers, the date of the first cheque in the series would be entered in the date field. The remain­ing cheque dates would be anniversary dates based on the fre­quency set up.
For example, the cheque range could be from 111 to 180. If the date on the first cheque-111 is October 12, 2003 and the frequency is set to Monthly, the next cheque would be picked up for processing on November 12, 2003.
Check Amt
Specify the appropriate cheque amount.
No of Checks
Specify the total number of checks in the range.
Billing Cycle
Select the frequency at which the checks are to be sent for collec­tion.
Comments
Specify any remarks for the details.
  1. Click Generate.
  2. In the PDC Table section, select the record you want to work with and enter, view or edit the following information:
    Field:
    View this:
    Select
    If selected, indicates that this is the current record.
    PDC Type
    The type of post dated check in use.
    Account #
    The account number of the post dated check.
    Bank Name
    The bank name of the post dated check.
    Check #
    The check number of the post dated check.
    Status
    The status of the post dated check.
    Check Dt
    The check date of the post dated check.
    Check Amt
    The check amount of the post dated check.
    Account Type
    The account type of the post dated check.
8.13 Collateral tab
Having selected and loaded an application, you can view the information about the collateral of the Loan.
The Collateral link opens screens with information regarding any collateral associated with an account. Depending on the type of Loan, collateral can be a vehicle, home, or something else, such as major household appliances. The Collateral link is unavailable if this is an unsecured Loan.
A detailed explanation of the fields found on the Collateral link’s screens and sub screens can be found in the Application Entry chapter.
To verify information about the collateral
  2. Click the Collateral link.
Depending on the type of collateral, information about the vehicle, home or other type of collateral appears.
  1. Verify the information regarding the collateral and its sub screens. (This is information that was recorded during the application entry process or gathered during the credit pull.)
If the collateral is a vehicle, the Collateral link displays information about the vehicle.
If the collateral is a home, the Collateral link displays information about the home.
If the collateral is anything other than a vehicle or home, the Collateral link displays information about the other type of collateral.
For details on this screen refer Collateral Tab section in Underwriting chapter.
8.14 Comments Tab
When using the Underwriting screen, you can add comments to an application at any time in the underwriting process by using the Comments screen.
Whenever an application is funded by a proxy user, a system generated comment with timestamp is inserted in the comments tab in the format ‘<User 1> actioned as proxy for Funder <User2>’. Here, User 1 refers to the logged in user who has acted on behalf of User2, who is the concerned Funder. The concerned Funder’s name will also be selected in Contract Tab > 'Funder' field.
To add comments to an application
  2. Click Comments.
For details on this screen refer Comments Tab section in Underwriting chapter.
8.15 Tracking Tab
When using the Funding screen, you can add tracking attribute information to an application at any time in the underwriting process by using the Tracking Attributes screen.
To enter the tracking attributes for an application
  2. Click the Tracking tab.
For details on this screen refer Tracking Tab section in Underwriting chapter.
8.16 Document tab
The Document Maintenance link allows you to view documents attached to an application in the form of GIF files, PDF files, DOC files, XLS files, and TXT files and add comments regarding a selected document.
For more information, see the chapter Document Management in this User Guide.
To view a document attached with an application
  2. Click Document.
For details on this screen refer Document Tab section in Underwriting chapter.
8.17 Verification Tab
The system can be configured to automatically validate portions of an application when you attempt to change its status. The results of this data check appear on the Verification link’s Edit screen as an Error, a Warning or an Override.
If it is an Error, the system will not allow you change the application’s status and approve the Loan until you fix all the errors.
If it is a Warning, the system enables you to change an application’s status without correcting the matter. While you should still investigate the problem, Warning messages are of a lesser importance than Error messages.
If it is an Override, the system displays a dialog box informing you that an override is needed; your responsibility level does not have the authority required to process this step. (Choose Yes on the dialog box to move the application to the queue of the user with the required authority.)
The system can be configured to verify different sets of information; for example, the system could check one set of data when checking application entries for completeness and another when approving auto Loan. Each one of these “edit types” has its own set of “edit details.”
Note
The Edit Details section’s errors and warnings are created during the setup process.
To complete the Verification tab
  2. In the Edit Type drop-down list, select 'Application Approval Edits' and click on 'Check Edits' button.
Edit details are displayed in the table below along with the result, expected value, actual value and the override responsibility. This is based on the product and contract set up details that is done initially.
For more information, refer to Configuring Lending and Leasing setup guides.
  1. Specify all the information associated with the application on the Funding screen.
  1. When you are finished entering data, on the Funding link bar, click Verification.
For details on this screen refer Verification Tab section in Underwriting chapter.
8.18 Correspondence Tab
Ad-hoc correspondence enables you to include information from applications in document templates you create yourself without manually transferring the data. Ad-hoc documents can be generated as either Microsoft Word or PDF files.
Ad-hoc correspondence can be viewed on the Correspondence link’s Correspondence screen when you have opened an account. The screen enables you to generate a new letter or view a previously generated letter.
To generate an ad hoc correspondence
  2. Click Correspondence.
For details on this screen refer Correspondence Tab section in Underwriting chapter.
8.19 Escrow Analysis Tab
If escrow is allowed for the selected instrument, the Escrow Analysis link is available on the Contract drop-down link. This screen enables you to view and perform the initial escrow analysis. When you are satisfied with the analysis, complete the Approval Dt field in the Approval section and save your entry.
The escrow payment for the Loan account starts on the 1st date of the Loan payment month. The disbursement happens on the 10th of the month (as per the disbursement rules). The escrow analysis lasts for a year (12 months) irrespective of the Loan term.
You can perform multiple analysis; however, the Escrow Analysis screen only records the last analysis performed. No record of any earlier analysis is currently available.
To complete the Escrow Analysis screen
  2. On the Funding screen, Click Escrow Analysis tab.
  3. In the Escrow Analysis section, view or enter the following information:
    Field:
    View:
    Escrow
    The escrow item.
    Disbursement Rule
    The escrow disbursement rule.
    Yearly Amt
    The escrow disbursement yearly amount.
  4. Click Analyze.
  5. Information on the Analysis Details screen is based on expected cash flow from contract and escrow disbursement setup. Payments received appear before escrow disbursement in any given month. Click View in Escrow Analysis section.
  6. In the following section, enter, view, or edit the following information:
    Field:
    View:
    Parameters section
    Date
    The date.
    From Dt
    The FROM date for the escrow activity.
    To Dt
    The TO date for the escrow activity.
    Opening Bal (Act)
    The opening balance actual amount.
    Opening Bal (Est)
    The opening balance estimated amount.
    Calculation: cushion amount + low required balance
    Cushion Type
    The cushion type.
    Cushion Value
    The cushion value.
    Cushion Amt
    The cushion amount.
    Calculation: as per the shortage /cushion Rule maintenance
    Results section
    Std Pmt Amt
    The standard payment amount.
    Escrow Pmt Amt (+)
    The escrow payment amount.
    Calculation: Yearly Amount/12.
    Spread Pmt Amt (+)
    The spread payment amount.
    Calculation: Surplus amount / 12
    Other Pmt Amt (+)
    The other payment amount.
    New Pmt Amt =
    The new payment amount.
    Calculation: standard payment amount + escrow payment amount + spread payment amount + other payment amount
    Surplus section
    Surplus /<Shortage Amt>
    The surplus shortage amount.
    Calculation: escrow account balance - opening balance
    Refund Amt
    The refund amount.
  7. Click View in the Analysis Details section.
  8. On the Analysis Details sub screen, view the following information:
    Field:
    View:
    Txn Dt
    The transaction date.
    Transaction
    The escrow transaction.
    Vendor
    The vendor name.
    Txn Amt
    The amount of the transaction.
    Balance Amt (Est)
    The estimated amount of balance.
    Balance Amt (Act)
    The actual amount of balance.
Information on the Analysis Details sub screen is based on expected cash flow from contract and escrow disbursement setup. Payments received appear before escrow disbursement in any given month.
  1. If you want to re-analyze the escrow analysis, change the escrow information on the Contract link’s screen and sub screens.
If you want to approve the escrow analysis, complete the following information fields on the Approval section:
Field:
View:
Approval section
Approval Dt
The approval date.
Approved By
The person who approved the Loan.
  1. Click Save on the Funding screen.
8.20 Tool Tab
The Tools tab calculates the payment amount, term, interest rate, Loan amount, amortization schedule and allows for the printing of a report.
For detailed information on using the tools, refer “Tools” chapter in the document.
8.21 Review Request
The Review Request tab facilitates to flag an Application for the attention of another Oracle Financial Services Lending and Leasing user and ask for review / feedback. It allows the system users to send and receive requests (including e-mail) commenting on a specific account or application. The Review Request tab supports iterative review of selected Application and also to process the review with multiple reviewers.
For detailed information on using this feature, refer to ‘Review Request’ section in Underwriting chapter of the document.
