System defined parameters help in configuring system specific data, User-access, location of system files; reports related URLs and other administration controlled data. These are essential to be configured during installation and some of them by nature of application will have to be reviewed and maintained in a regular and periodic manner.
Following are the types of parameters are used in OFSLL system depending on the areas of the system that these would apply and impact:
Note
All the above parameters can be controlled (enabled/disabled) only by System Administrators, and users with Admin/Super User privileges who would be involved in setting-up OFSLL system.
System parameters apply to the entire system. They relate to the overall processing of the system like application server file locations, data purging configurations and so on. Table below details the list of system parameters with their description and pre-defined values.
| Parameter | Description |
| ACA_DLQ_AMT_EXCLUDED | This parameter is used to exclude delinquency amount for account ACH |
| ACA_PAYMENT_AUTO_LOAD | This parameter is used to control posting directly from the ACH file that has been created for customer payments. Input parameter value is Boolean (Yes/No). If the parameter is set to ‘Y’, the system automatically creates payment batches for the payments in the ACH file and posts them on the day of payment. |
| ACA_PRENOTE_DAYS | This parameter is used to define the number of days the prenote should be initiated for customer ACH (Automated Clearing House) accounts. Input parameter value is numeric. |
| ACA_PRE_PROCESS_DAYS | This parameter is used to specify the number of days before draft day for Account ACH process. Input parameter value is numeric. |
| ACH_PAYEE_PRENOTE_DAYS | This parameter is used to define the number of days for prenote to occur for Producer or Vendor ACH accounts. Input parameter value is numeric |
| ADMIN_SERVER_URL | This parameter is used to define the admin server URL |
| ADR_DIRECTORY | This parameter is used to define the Oracle Directory Object Name for ADR file location |
| ADR_PROCESSED_DIRECTORY | This parameter is used to define the Oracle Directory Object Name for ADR file location |
| AGE_APPROVED_CONDITIONED_DAYS | This parameter is used to specify the number of days by which an application in ‘Approved’ or ‘Conditioned’ status is treated as Aged Application. Input parameter value is numeric with no upper limit. |
| AGE_CONTRACT_DAYS | This parameter is used to specify the number of days by which a contract is treated as Aged Contract. Input parameter value is numeric with no upper limit. |
| ASC_COL_SER_ENABLED_IND | This parameter is used as the Collection Servicing Enabled Indicator |
| CAC_DIRECTORY | This parameter is used to define the Oracle Directory Object Name for CAC file location |
| CAC_PROCESSED_DIRECTORY | This parameter is used to define the Oracle Directory Object Name for CAC file location |
| CHECK_PRINT_PREVIEW | Using this parameter we can allow preview of application in pdf form before printing. Input parameter value is Boolean (Yes/No). |
| CMN_AMOUNT_ROUND_FACTOR | This parameter is used to define the rounding factor for applicable fields (in this case calculated amounts). Input parameter value is ‘ROUND AMOUNT TO 2 DECIMALS’. Currently system supports rounding factor 2 only. |
| CMN_AMOUNT_ROUND_METHOD | This parameter is used to define the amount round method during system set-up and would be applicable for all calculated amounts (calculated fees, payment etc.) across the application. Input values are ROUND, RAISE and CUTOFF:  |
| CMN_APP_ACC_TITLE_FN_LN | This parameter is used to set the Application or Account title in one of the formats – First/Last Name or Last/First Name. Input parameter value is Boolean (Yes/No). If Yes is chosen, title would be in the format – First/Last Name, else the other option. |
| CMN_APP_SERVER_HOME | This parameter is used to set the Application Server Home Directory. Input parameter value is user defined. |
| CMN_CURRENT_MODEL_YEAR | This parameter is used to default the Current Model Year. |
| CMN_DEBUG_LEVEL | This is the Common Debug Level |
| CMN_DEBUG_METHOD | This parameter allows to define the location to which generic debug logs (other than Alert/Warning and GRI) are to be written. If set to ‘ADVANCE_QUEUE’, system writes the logs in Logs table and if set to ‘UTL_FILE’, system generates the alert log file. |
| CMN_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the incoming or outgoing files/documents are to be processed. If set to ‘Y’, system processes the data to/from LOB and if set to ‘N’, system processes the data to/from FILE. The same is used by the batch jobs available in SET-IFP (input file processing) Batch Job Set. |
| CMN_GL_POST_DT | This parameter is used to specify the General Ledger Posting date. If scheduler is enabled, it automatically updates this to current system date. Else Admin User would need to set this date manually to ensure correct posting dates in GL. |
| CMN_HTTP_PROXY_PORT | This parameter is enabled to specify the port to be used for outgoing HTTP connections. Input parameter value is user defined. |
| CMN_HTTP_PROXY_SERVER | This parameter is enabled to specify the proxy server to be used for outgoing HTTP connections. Input parameter value is user defined. There exists an interdependency of this parameter with CMN_HTTP_PROXY_PORT mentioned above. |
| CMN_INT_360_ACCRUAL_DAYS_MTHD | This parameter is used to specify the interest accrual method for 360 days, to be used by the System for all calculations with interest. Currently two methods are supported. Input parameter value is ‘US’ or ‘EU’ representing American and European method of interest accrual for 360 days. |
| CMN_TEST_TOOL_LOGGING | This parameter is used to set testing tool logging parameter |
| CMN_SCHEMA_ID | This is used to specify the schema identifier for all users. |
| CMN_SCHEMA_NAME | This is used to specify the Oracle User Name for a specific schema. Input parameter value is user defined. |
| CMN_SCHEMA_PASSWORD | This captures the password for Oracle, for the specific schema. Input parameter value is user defined. This parameter need not be enabled when in Oracle Network. |
| CMN_SERVER_HOME | This parameter captures the Server Home Directory. Input parameter value is user defined. |
| CMN_SERVER_TEMP_DIR | This parameter is used to specify the temporary directory on the server along with the path. Input parameter value is user defined. |
| CMN_SER_ENVIRONMENT_FILE | This parameter captures the environment file (and its path) for running the Operating System commands from Job Service. Input parameter value is user defined. |
| CMN_WALLET_PASSWORD | This parameter is used to specify the common wallet password. Input parameter value is user defined. |
| CMN_WALLET_PATH | This parameter is used to specify the common wallet path for oracle database. Input parameter value is user defined. |
| CPP_NO_OF_PROMISES | This parameter is used to define the maximum number of promises/chances allowed for a customer who is delinquent and promises to pay. Input parameter value is numeric with no upper limit. |
| CPP_PROMISE_HELD_DAYS | This parameter is used to define the maximum number of days after the promises made by the customer to pay are broken to initiate further actions. Input parameter value is numeric with no upper limit. |
| CRD_CHS_BIN | This parameter holds the value of the credit card BIN (Bank Identification Number for Credit Cards), for CHASE interface. Input parameter value is user defined.  |
| CRD_CHS_CUR_CODE | This parameter is used to specify the currency code of the transacting currency for CHASE interface. Input parameter value is user defined. |
| CRD_CHS_DIR_PATH | This parameter is used to specify the directory path for CHASE payment interface for Credit Cards. Input parameter value is user defined. |
| CRD_CHS_IND_TYPE | This is used to specify the industry type for CHASE payment interface for Credit Cards. Input parameter value is user defined. |
| CRD_CHS_MERCHANT_ID | This captures the merchant ID number for CHASE payment interface for Credit Cards. Input parameter value is user defined. |
| CRD_CHS_REMOTE_HOST_NAME | This captures the remote host name for seeking approvals for CHASE payment interface. Input parameter value is user defined. |
| CRD_CHS_SEC_REMOTE_HOST_NAME | Similar to the previous parameter this captures the secondary remote host name of CHASE interface for seeking approvals for credit card payments. Input parameter value is user defined. |
| CRD_CHS_TIMEOUT | This parameter is used to define the timeout limit when polling the interface for processing credit card payments. Input parameter value is numeric. |
| CRD_CHS_USR_ID | This parameter captures the user id for CHASE interface which is required whenever the System needs to access/seek authorizations/process payments for credit cards etc. Input parameter value is user defined. |
| CRD_PTB_REMOTE_HOST_NAME | This is the Protobase Remote Host Name |
| CRD_PTB_REMOTE_HOST_PORT | This is the Protobase Remote Host Port |
| CRD_PTB_TIMEOUT | This is the Protobase Timeout Value |
| CRD_SOURCE_TYPE_CD | This is the Source Type Code |
| DDT_CREATE_DUE_DATE_HISTORY | This parameter must be enabled to create a due date history for any account. Due date history sub tab under Transaction history displays the delinquency history of an account in a tabular format detailing Due date, Due Amount, Last Payment date, Payment Amount, Balance Amount, Days past due and Payment received flag. The input parameter value for this parameter is Boolean (Yes/No). |
| DECISION_BUY_RATE_TOLERANCE | This parameter is used to define the variance in buy rate |
| EDF_DIALER_ACCT_TYPE | This parameter is used to set up the account number reference for the dialer file to pick-up records for Auto dialer interface. Input parameter value is account number. |
| FLL_BPEL_PROCESS | This parameter is set to use BPEL process in OFSLL. Input parameter value is Boolean (Yes/No). |
| ICA_INPUT_FILE_FORMAT | This parameter is used to define the input call activity file format |
| IFD_DIRECTORY | This parameter is used to define the Oracle directory object name for IFD file location |
| IFD_PROCESSED_DIRECTORY | This parameter is used to define the Oracle directory object name for IFD file location |
| INCOMING_LOB_PURGE_DAYS | This parameter is used to define the incoming process file table purge days |
| INPUT_DIRECTORY | This parameter is used to define the Oracle directory object name for INPUT file location |
| ITU_DIRECTORY | This parameter is used to define the Oracle directory object name for ITU file location |
| ITU_PROCESSED_DIRECTORY | This parameter is used to define the Oracle directory object name for ITU file location |
| IVR_DIRECTORY | This parameter is used to define the Oracle directory object name for IVR file location |
| IVR_PROCESSED_DIRECTORY | This parameter is used to define the Oracle directory object name for IVR file location |
| JSC_TIMEOUT | This parameter is used to set the polling interval for job scheduler. Input parameter value is numeric. To check whether it represents minutes/seconds. |
| JSV_ARCHIVE_SERVER_CONFIG | This parameter is used to set the configuration file for reports archive server. Input parameter value is user defined. |
| JSV_ARCHIVE_SERVER_URL | This parameter is used to specify the archive server url. Input parameter value is user defined. |
| JSV_BI_PASSWORD | This parameter is used to define the BI Publisher Password |
| JSV_BI_USER | This parameter is used to define the BI Publisher User ID |
| JSV_TEMPORARY_DIRECTORY | This parameter is used to define Oracle directory object name for Job Service Temp file location |
| JSV_BI_PASSWORDJSV_REPORTS_RUNTIME | This parameter is to specify the reports runtime program. Input parameter value is user defined. |
| JSV_REPORTS_RUNTIME_CMDFILE | This parameter is used to specify the reports runtime command file. Input parameter value is user defined. |
| JSV_REPORTS_SERVER_CONFIG | This parameter is used to specify the configuration file for reports server. Input parameter value is user defined. |
| JSV_REPORTS_SERVER_URL | This is used to specify the URL for the reports server. Input parameter value is user defined. |
| JSV_REPORT_ARCHIVE_DIRECTORY | This is used to specify the path and directory of Reports archive, input parameter value being numeric. |
| JSV_SMTP_SERVER | This parameter specifies the SMTP server used by job service for sending email messages. Input parameter value is user defined. |
| JSV_TIMEOUT | This is to specify the polling interval for the job service during time out. Input parameter value is numeric. To check whether it represents minutes/seconds. |
| JSV_USE_BI_PUBLISHER | This parameter defines whether BI publisher should be used to process reports are not. Input parameter value is Boolean (Yes/No). |
| JSV_USE_REPORTS_SERVER | This parameter is used to specify whether reports server from job service should be used or not. Input parameter value is Boolean (Yes/No). |
| LBX_TXN_GROUPING_CNT | This parameter is used to specify the no. of records per batch for payment transactions and lock box batch records. Input parameter value is numeric. |
| LCO_COL_LETTER1_GEN_DAYS | This parameter specifies the number of days post which first collection letter should be generated for accounts with dues unpaid. Input parameter value is numeric. |
| LCO_COL_LETTER2_GEN_DAYS | This parameter specifies the number of days post which second collection letter should be generated for accounts with dues unpaid. Input parameter value is numeric. |
| LCO_COL_LETTER3_GEN_DAYS | This parameter specifies the number of days post which third collection letter should be generated for accounts with dues unpaid. Input parameter value is numeric. |
| LIEN_RELEASE_DAYS | This parameter is used to define the Lien Release Days |
| LOCKBOX_DIRECTORY | This parameter is used to define the Oracle directory object name for Lockbox file location |
| LOCKBOX_PROCESSED_DIRECTORY | This parameter is used to define the Oracle directory object name for processed Lockbox file location |
| LOR_ADVERSE_ACTION_GEN_DAYS | This parameter is used to specify the number of days after the third collection letter post which the adverse action letter is to be generated. Input parameter value is numeric. |
| LOG_LOB_PURGE_DAYS | This parameter is used to log files header table purge days |
| MAX_AGED_TXN_AUTHORIZE_DAYS | This parameter is used to specify the maximum number of days within which a transaction should be authorized. Input parameter value is numeric and represents the number of days. |
| MAX_VOID_TXN_AUTHORIZE_DAYS | This parameter is used to set the maximum days to authorize transaction |
| OCP_CUSTOMER_PMT_SITE_ID | This parameter is used to set the customer payment extract file site id |
| OCP_INCLUDE_ACH_ACC | This parameter is used to set the customer payment extract including ach accounts |
| OUTGOING_LOB_PURGE_DAYS | This parameter is used to define the outgoing process file table purge days |
| OUTPUT_DIRECTORY | This parameter is used to define Oracle directory object name for OUTPUT file location |
| PAC_ARCHIVE_DAYS | This parameter is used to define number of days for periodic archiving of account. Input parameter value is numeric. |
| PAC_OARCHIVE_DAYS | This parameter is used to define the number of days for archiving accounts from ‘O’ tables i.e. old tables. Input parameter value is numeric |
| PAP_ARCHIVE_DAYS | This parameter is used to define the number of days for archiving applications on a periodic basis. Input parameter value is numeric. |
| PAP_OARCHIVE_DAYS | This parameter is used to define the number of days for archiving applications from ‘O’ tables. Input parameter value is numeric. |
| PCU_CHECK_REFUND_DAYS | This parameter is used to specify the maximum number of days within which an overpayment from the customer can be refunded. Input parameter value is numeric. |
| PDC_PRE_PROCESS_DAYS | This parameter value will define the number of days prior to the due day, regular account PDC process should be initiated. Input parameter value is numeric. |
| PENDING_PDC_DAYS | This parameter value will define the number of days before the initiation day for pending PDC accounts. |
| PGL_ARCHIVE_DAYS | This parameter defines the number of days, post which the transactions in GL would be archived. Input parameter value is numeric |
| PGL_OARCHIVE_DAYS | This parameter is used to define the number of days, post which the transactions in GL will be moved to the ‘O’ tables. Input parameter value is numeric. |
| PJR_PURGE_DAYS | This parameter is used to specify the days post which the job requests are to be purged. Input parameter value is numeric. |
| POD_PURGE_DAYS | This parameter is used to define the number of days after which the Output data file headers are to be purged. Input parameter value is numeric. |
| PPA_ARCHIVE_DAYS | This parameter is used to specify number of days after which pools and its transactions archiving is to be done to ‘O’ tables. Input parameter value is numeric. |
| PPA_OARCHIVE_DAYS | This parameter is used to specify number of days after which pools and its transactions archiving is to be done to ‘OO’ tables. Input parameter value is numeric |
| PPR_ARCHIVE_DAYS | This is used to specify the days for archival of producers details on a regular basis. Input parameter value is numeric. |
| PPR_OARCHIVE_DAYS | This is used to specify the days after which the producers details from ‘O’ tables need to be archived. Input parameter value is numeric. |
| PPX_ARCHIVE_DAYS | This is used to specify the days after which producer transactions are to be archived. Input parameter value is numeric. |
| PPX_OARCHIVE_DAYS | This is used to specify the days after which the producer transactions are to be moved from ‘O’ tables. Input parameter value is numeric. |
| PJR_COPY_PURGED_DATA | This parameter is used to copy data into purge tables |
| PST_ARCHIVE_DAYS | This parameter specifies the number of days for which the statements are to be archived. Input parameter value is numeric. |
| PST_OARCHIVE_DAYS | This parameter specifies the number of days for which the statements are to be archived in the ‘O’ tables. Input parameter value is numeric. |
| PTT_PURGE_DAYS | This is used to specify the number of days after which the PTT table is to be purged. Input parameter value is numeric. |
| PTX_ARCHIVE_DAYS | This parameter is used to specify the number of days the transactions are to be archived. Input parameter value is numeric. |
| PTX_OARCHIVE_DAYS | This parameter is used to specify the number of days after which the archived transactions from ‘O’ tables are to be moved. Input parameter value is numeric. |
| PUL_PURGE_DAYS | This parameter is used to specify the number of days post which the User login details are to be purged. Input parameter value is numeric. |
| PVA_ARCHIVE_DAYS | This parameter stores the number of days for archival of regular vendor assignments. Input parameter value is numeric. |
| PUP_ARCHIVE_DAYS | This parameter stores the number of days for archival of transaction upload. Input parameter value is numeric |
| PUP_OARCHIVE_DAYS | This parameter is used to specify the number of days after which the archived transactions from ‘O’ tables are to be moved. Input parameter value is numeric |
| PVA_OARCHIVE_DAYS | This parameter value specifies the number of days for archival of vendor assignments from ‘O’ tables to ‘OO’ tables. Input parameter value is numeric. |
| PVI_ARCHIVE_DAYS | This parameter is used to specify the number of days for which the regular vendor invoices are to be archived. Input parameter value is numeric. |
| PVI_OARCHIVE_DAYS | This parameter is used to specify the number of days post which the regular vendor invoices are to be moved from ‘O’ tables to ‘OO’ tables. Input parameter value is numeric. |
| RAC_LOAD_FREQUENCY | This parameter is used to specify Accounts RDH Load Frequency |
| RAP_LOAD_FREQUENCY | This parameter is used to specify Applications RDH Load Frequency |
| RAT_LOAD_FREQUENCY | This parameter is used to specify Asset Tracking RDH Load Frequency |
| RBK_LOAD_FREQUENCY | This parameter is used to specify Bankruptcy Details RDH Load Frequency |
| RCA_LOAD_FREQUENCY | This parameter is used to specify Call Activities RDH Load Frequency |
| RCH_LOAD_FREQUENCY | This parameter is used to specify Deficiency Details RDH Load Frequency |
| RCO_LOAD_FREQUENCY | This parameter is used to specify Contracts RDH Load Frequency |
| RFO_LOAD_FREQUENCY | This parameter is used to specify Repo-Foreclosure RDH Load Frequency |
| RPR_LOAD_FREQUENCY | This parameter is used to specify Producers Rdh Load Frequency |
| RST_LOAD_FREQUENCY | This parameter is used to specify Setup Data RDH Load Frequency |
| RTX_LOAD_FREQUENCY | This parameter is used to specify Txns RDH Load Frequency |
| SALESAGENT_MAIL_SEND_IND | This parameter is used to specify whether decision fax needs to be sent to sales agent (yes/no) |
| SCORING_PARAMETER_ALERT | This parameter is used to set the scoring parameter alert |
| SQL_DIRECTORY | This parameter is used to set the Oracle directory object name for SQL file location |
| TES_ANA_PRE_PROCESS_CYCLES | This parameter is used to specify the pre-process cycles required for Escrow analysis. Input parameter value is numeric. |
| TES_DSB_ANALYSIS_PERCENT | This parameter is used to specify the percentage for escrow disbursements. Input parameter value is numeric. |
| TES_DSB_PRE_PROCESS_DAYS | This is used to specify the number of days for pre-process for escrow disbursements. Input parameter value is numeric. |
| TPE_AMORTIZE_ACCRUED_INT_ONLY | This parameter is used to specify that system has to amortize accrued interest at month end |
| TPE_APPLY_LTC_FROM_CURR_DUE_DT | This parameter is used for pyramid law fee method to apply late charge from current due date |
| TPE_ESC_ANALYSIS_DELQ_AMT | Parameter considers billed but uncollected amount for escrow analysis |
| TPE_EXCESS_PAYMENT_TO_MEMO | Excess payment on the account will be moved to memo payment. |
| TPE_EXCLUDE_ESC_LTC | This parameter defines whether escrow should be included or excluded while calculating late charge. Input parameter value is Boolean (Yes/No). |
| TPE_EXT_CYCLES_BACKDATED | This parameter is used to define the maximum extension cycles allowed for back dating. Input parameter value is numeric with no upper limit |
| TPE_FUTURE_PAYOFF_DAYS | The value specified in this parameter validates the ‘Valid Up to Date’ with ‘Payoff quote’ during monetary transactions posting. |
| TPE_GL_REFUND_HOLD_DAYS | This parameter is used to define the number of days the non-refunded amount can be held in GL. Input parameter value is numeric. |
| TPE_MAX_CYCLES_BACKDATED | This parameter is used to define the maximum cycles that are allowed for back dating in OFSLL. Input parameter value is numeric. |
| TPE_MIN_1098_INT_AMT_PAID | This parameter is used to specify the lower limit or minimum interest amount paid for 1098 i.e. Mortgage Interest Statement. In the US, FIs need to report mortgage interest of $600 or more received from individuals, during the course of their business. Input parameter value is 600, the minimum value above which reporting by FI is required in form 1098 for each mortgage account. |
| TPE_OLDEST_DUE_DT_NEW_MTHD | This parameter is enabled to specify whether new method for calculation of oldest due date based on given data should be used or not. Input parameter value is Boolean (Yes/No). |
| TPE_PAID_TO_CLOSE_DAYS | This parameter is used to specify the number of days allowed post which a paid account would be closed. Input parameter value is numeric. |
| TPE_PAYMENT_TO_MULTI_ACCOUNTS | This parameter is enabled to allow one payment for dues in multiple accounts. Input parameter value is Boolean (Yes/No). |
| TPE_PAYOFF_VALID_THRU_DAYS | This parameter is used to specify the number days the pay-off quote is valid by default. i.e. if the parameter is set as 7, the payoff quote is valid for 7 days and customer can pay the quoted amount as final closure amount within those days. Input parameter value is numeric. |
| TPE_PMT_POST_EOD | This parameter is used to allow payments when the batch process for End of Day is running. Input parameter value is Boolean (Yes/No). If this is set to ‘Y’, payments can be allowed during EOD. |
| TPE_SCHGOFF_DLQ_DAYS | This parameter is used to define the number of delinquent days to treat an account for SCHGOFF (charge – off). Input parameter value is numeric. (To verify) |
| TPE_SCHGOFF_REVIEW_DAYS | This parameter is used to define the number of days allowed for review of SCHGOFF accounts. Input parameter value is numeric. |
| TPE_SCRA_DEFAULT_INTEREST_RATE | This parameter is used to define the default interest rate that is to be applied for customers who are in military duty. OFSLL will apply the lower of the prevailing interest rate or SCRA default interest rate specified through this parameter. Input parameter value is numeric (in this case 6, which is interest rate to be applied for SCRA accounts. |
| TPE_SHOW_BACKDATE_WARNING | This parameter is used to define whether a warning message is to be shown if monetary transaction is backdated |
| TPE_STM_INC_ALL_TXNS | This parameter is enabled to define whether all transactions should be included in the statements or otherwise. Input parameter value is Boolean (Yes/No). |
| TPE_STOP_COMP_DELQ_DAYS | This parameter is used to stop computation when delq days > 60 |
| TPE_TXN_POST_DEFAULT_GLDATE | This parameter is used to default GL date in date type parameters during txn posting (y/n) |
| TPE_VOID_TO_CLOSE_DAYS | This parameter is used to define the number of days allowed for closing Void accounts. Input parameter value is numeric. |
| UIX_DEFAULT_IMAGE_PATH | This parameter is used to define the default image directory maintained for the purpose of online attachment of document images to an application using documents maintenance section under Account documentation. Input parameter value is user defined. |
| UIX_DIRECT_LOAN_COMBO_ULN_UFN | This parameter when set to yes allows underwriting and funding to be carried on by a single responsibility for direct loans only. Input parameter value is Boolean (Yes/No). |
| UIX_INCOMING_FILE_PATH | This parameter is used to specify incoming file path of app server |
| UIX_LOCAL_COUNTRY_CD | Through this parameter we can set the local country where an FI has multiple branches across different geographies. Input parameter value is user defined. |
| UIX_LOCK_UNLOCK_AND_COPY | This parameter is used to enable the user interface lock / unlock and copy features. Input parameter value is Boolean (Yes/No). |
| UIX_MAX_ACC_SEARCH_ROWS | This parameter is used to specify the maximum number of account rows to be returned for search functionality. Input parameter value is numeric. |
| UIX_MAX_APP_SEARCH_ROWS | This parameter is used to specify the maximum number of application rows to be returned for search functionality. Input parameter value is numeric. |
| UIX_OUTGOING_FILE_PATH | This parameter is used to specify outgoing file path of app server |
| UIX_REPORTS_SERVER_CONFIG | This parameter can be used to specify the user interface reports server configuration file. This is not required for OFSLL. |
| UIX_REPORTS_SERVER_URL | This parameter sets the URL for Reports server. Input parameter value is user defined. |
| UIX_SHOW_LN_VARIABLE_RATE_TABS | This parameter can be used to show loan variable rate tabs. Input parameter value is Boolean (Yes/No). This is not required for OFSLL. |
| UIX_UTILITIES_SERVLET_URL | This parameter can be used to specify the User Interface utilities servlets URL. This is not required for OFSLL. |
| UPR_PRO_NBR_SYS_GENERATED | This parameter can be used to specify whether producer number should be system generated or seek input from user. Input parameter value is Boolean (Yes/No). Generally this is set to yes for system generation. |
| VEV_NADA_TOKEN_URL | This parameter is used to set the token URL for vehicle evaluation interface NADA. Input parameter value is user defined. |
| VEV_NADA_UPDATE_DAY | This parameter is used to specify the day of the month to update the vehicle evaluations every month. Input parameter value is numeric. |
| VEV_NADA_URL | This parameter is used to set the URL for vehicle evaluation interface NADA. Input parameter value is user defined. |
| VEV_NADA_USER_ID | This parameter is used to specify the User id for login to the NADA interface. Input parameter value is user defined. |
| VEV_NADA_USER_PASSWORD | This parameter is used to specify the password for login to the NADA interface. Input parameter value is user defined. |
| VEV_VALUATION_REGION | This parameter is used to define the default region for vehicle evaluation. Input parameter value is the region name, and is user defined. |
| VEV_VALUATION_SOURCE_CD | This parameter is used to specify the default vehicle evaluation source code. Input parameter value is user defined. A number of parameters are possible in OFSLL as below: |
| WFP_DIRECTORY | This parameter is used to specify the Oracle directory object name for WFP file location |
| WFP_MAX_CYCLES_BACKDT | This parameter is used to specify the back dated cycles date for WFP. |
| WFP_PROCESSED_DIRECTORY | This parameter is used to define oracle directory object name for wfp file location. |
| WFP_REVERSE_TXN_IND | This parameter is enabled to define the WFP reversal indicator. Input parameter value is Boolean (Yes/No). |
| XAE_DEALUPD_MAX_ALLOWED_DAYS | This parameter is used to define the max allowed days for Deal Update |
| XAE_DEALUPD_ALLOWED_IND | This parameter is used to indicate whether deal update is allowed or not |
| OUTBOUND_CALL_Q | This parameter is used to generate reports (including emailing statements/letters) using Application Server instead of Database server. |
| ACA_PRE_PROCESS_DAYS_FIRST | This parameter is used to configure the number of days before the debit day for ACH process in first time/ one-time case |
| IPR_PROCESSED_DIRECTORY | This parameter is used to define the Oracle directory object name for processed IPR file location |
| IPR_DIRECTORY | This parameter is used to define the Oracle directory object name for IPR file location |
| UIX_PWD_MGMT_EXTERNAL_URL | This parameter is used to set external password management url, if applicable |
| UIX_PWD_MGMT_EXTERNAL | This parameter is used to define the parameter if password management is external. (SET Y IF PASSWORD MANAGEMENT IS EXTERNAL (Y/N)). |
| ICU_PROCESSED_DIRECTORY | This parameter is used to define the Oracle directory object name for processed ICU file location |
| ICU_DIRECTORY | This parameter is used to define the Oracle directory object name for ICU file location |
| UIX_BILL_CYCLE_ALLOWED_IND | This parameter is used to indicate whether Billing cycle is allowed at the application level |
| CMN_EOD_SLEEP_MINS | This parameter is used to set in minutes the EOD sleep time |
| CMN_CORE_BANK_TXN_CD | This parameter is used to set code for OFSLL and Core Banking integration |
| UIX_DIRECT_DISB_MANUAL_SELECT | This parameter will allow manual selection of disbursement mode for direct loans |
| ICC_DLQ_AMT_EXCLUDED | This parameter enabling will exclude delinquency amount for CASA account |
| CMN_CORE_BANK_IND | This parameter is used to set whether OFSLL can integrate with Core Banking. |
| BKRP_FILE_REC_LIMIT | This parameter is used to set the limit of total number of records allowed to be added in the ‘Input Data File’ shared from external interface. Note: if the number of records exceeds the set limit, multiple ‘Input Data Files’ are to be created. |
| UVN_VEN_NBR_SYS_GENERATED | This parameter is used to validate if ‘Vendor Number’ has to be auto generated (if set to Y) or to be specified manually in the Vendor details screen. |
| METRO_WITHOUT_COLL_IND | This parameter indicates whether Metro II reporting is handled without OFSLL Collections module being used. If the parameter value is set as ‘Y’ i.e. collection module is not used, system updates the collateral status directly as part of ‘REPO’ call activity. However when Collections module is being used, the Collateral status is tracked with the repossession details updated in 'Repo/Foreclosure' screen of Collections module. |
| METROII_FIRST_DELQ_DT_ADD_DAY | This parameter is used to calculate the first delinquency date that needs to be reported in the Metro II reporting file. By default the parameter is 'disabled' indicating that the initial delinquency date calculated by the system is used for Metro II reporting. The same needs to be enabled to add the parametrized number of days to the system calculated first delinquency date for the Metro II reporting purpose. |
| DAYS_TO_PULL_CRB_REPORT | This parameter is used to configure the number of days permitted to pull a Bureau report from the same company and for the same customer. |
| XWS_ACS_RESP_MULTI_RECORD_IND | This parameter is used to indicate if multiple records exist in the response file received for account search. Accordingly, when there are multiple records found and this parameter is enabled and set to ‘No’ (default), system displays an error message “Too Many Records Found. Please Refine Search by Adding One More Parameter” However, when this parameter is set to ‘Yes’, system only indicates that there are multiple records/rows in response file. |
| GRI_DLQ_DAYS_AUTO_STATUS_CHG | This parameter is used to define the delinquency days which inturn is used to automatically update the status of a work order to ‘PENDING ON HOLD’ status. |
| TPE_PMT_POSTING_CLS_ACCOUNT | This parameter is used to define the payment posting criteria for Closed - Paid Off/ Charged-off accounts. Accordingly, OFSLL accepts payment posting on closed accounts only when the parameter is set to ‘Y’ and all the payments received through Payment Entry screen or ‘Payment Upload’ file are posted to a ‘Suspense’ account. |
| TPE_BACKDT_PMT_POSTING | This parameter is used to define the payment posting criteria for backdated payments for the following type of account conditions: - Paid off - Charged-off - Account under activation - Account under conversion - Non-performing Account - PC2 SI (Pre-computed to Simple Interest) Reschedule Accordingly, OFSLL accepts backdated payment posting only when the parameter is set to ‘Y’ and all the payments received through Payment Entry screen or ‘Payment Upload’ file are posted to a ‘Suspense’ account. |
| EXP_PA_SOFT_PULL_IND | This parameter when enabled allows ‘Soft Pull’ Credit Bureau request, specifically for Experian Premier Attribute Consumer Report without impacting the consumer FICO score. |
| PMT_BATCH_POSTING | This parameter (PAYMENT BATCH POSTING PREFERENCE) is used to define the status of payment transactions which are uploaded in bulk through a batch process. |
| POOL_ACTIVE_ACCOUNTS_ONLY | This parameter controls the type of accounts that can be added to a Securitization Pool and allows adding only ‘Active’ status accounts since the same is enabled (value set to ‘Y’) by default. To add accounts with other status such as Active, Paid Off, Charged Off, Void, Terminate. and so on, set the value of system parameter to ‘N’. |
| AUTO_GEN_ACC_NBR_CONV | This parameter is used for conversion accounts to decide option of account number generation. If the value of parameter is set to ‘Y’ the account number is automatically generated in OFSLL during conversion and if the value is ‘N’, then external reference number (generated in third party system) itself is appended as the account number. |
| OUTBOUND_DLR_TRACK_Q | This parameter defines the settings for batch job ‘SET_XPR’ to either use MDB (Message Driven Bean) flow (if value set to ‘Y’) or existing work flow (if value set to ‘N’) to dump producer details maintained in the system into Dealer Track. MDB flow generates outbound JMS message though the configured MDB interface and can avoid current database outbound calls and session timeout. In the existing workflow, the database makes synchronous outbound calls to producer data dump web service, to dump the data and acknowledge the database with the status (success or failure). |
| OUTBOUND_ROUTEONE_Q | This parameter defines the settings for batch job ‘SET_XPR’ to either use MDB (Message Driven Bean) flow (if value set to ‘Y’) or existing work flow (if value set to ‘N’) to dump producer details maintained in the system into ROUTEONE. MDB flow generates outbound JMS message though the configured MDB interface and can avoid current database outbound calls and session timeout. In the existing workflow, the database makes synchronous outbound calls to producer data dump web service, to dump the data and acknowledge the database with the status (success or failure). |
| GRI_WEBSERVICE_LOG_IND | This parameter is used to decide on logging GRI (Generic Recovery Interface) communications. If enabled, system logs all the GRI related web service communications between OFSLL and external interfaced system. The recorded logs can be viewed in Dashboard > System Monitor > Database Server Log Files tab by selecting ‘Interfaces’ view option. |
| PVE_ARCHIVE_DAYS | This parameter stores the number of days for archival of regular vendors. Input parameter value is numeric. |
| PVE_OARCHIVE_DAYS | This parameter is used to specify the number of days post which the regular vendors are to be moved from ‘O’ tables to ‘OO’ tables. Input parameter value is numeric. |
| LBX_DR_CR_VALIDATE_AMT_IND | This parameter (VALIDATE LOCKBOX DR/CR BATCH TOTALS) is used to facilitate NACHA file validation. Based on the status of the parameter, system is either allowed to validate the file or process without validation. |
| PAP_PURGE_DAYS | This parameter allows to define the number of days after which the application data from archival folders are to be deleted permanently. Purging happens based on elapsed number of days i.e. if value is set to 60 days, only those records which are older by 60 days in archival folder are deleted. |
| PAC_PURGE_DAYS | This parameter allows to define the number of days after which the accounts data from archival folders are to be deleted permanently. Purging happens based on elapsed number of days i.e. if value is set to 60 days, only those records which are older by 60 days in archival folder are deleted. |
| CMN_SED_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the incoming or outgoing seed data is to be processed. If set to ‘Y’, system processes the data to/from LOB and if set to ‘N’, system processes the data to/from FILE. |
| CMN_EDF_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the incoming or outgoing data from Dialer Interface is to be processed. If set to ‘Y’, system processes the data to/from LOB and if set to ‘N’, system processes the data to/from FILE. The same is used by the batch jobs EDFADR_BJ_100_01 and EDFIVR_BJ_100_01 which are available in SET-EDF Batch Job Set. |
| CMN_FAX_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the incoming or outgoing Fax data is to be processed. If set to ‘Y’, system processes the data to/from LOB and if set to ‘N’, system processes the data to/from FILE. |
| CMN_RED_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the outgoing details of Data Masking Policy (i.e. Redaction policy output file) is to be processed. If set to ‘Y’, system processes the data from LOB and if set to ‘N’, system processes the data from FILE. The same is used by the batch job REDPRC_BJ_100_01 available in SET-RED Batch Job Set. |
| CMN_WFP_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the incoming or outgoing WFP Unit details are to be processed. If set to ‘Y’, system processes the data to/from LOB and if set to ‘N’, system processes the data to/from FILE. The same is used by the batch job WUPPRC_BJ_132_01 available in SET-WFP Batch Job Set. |
| CMN_AUD_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the outgoing Audit scripts are to be processed. If set to ‘Y’, system processes the data from LOB and if set to ‘N’, system processes the data from FILE. |
| CMN_LBT_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the incoming or outgoing Lockbox files are to be processed. If set to ‘Y’, system processes the data to/from LOB and if set to ‘N’, system processes the data to/from FILE. The same is used by the batch jobs LBXPRC_BJ_100_01 and LBXSEP_BJ_100_01 available in SET-LBT Batch Job Set. |
| CMN_ODD_FILE_PROCESS_TO_LOB | This parameter allows to define the location from where the outgoing ODD or Output Data Dump files are to be processed. If set to ‘Y’, system processes the data from LOB and if set to ‘N’, system processes the data from FILE. The same is used by the batch job ODDPRC_BJ_000_01 available in SET-ODD3 Batch Job Set. |
| CMN_ALERT_DEBUG_METHOD | This parameter allows to define the location to which Alert and Warning logs are to be written. If set to ‘ADVANCE_QUEUE’, system writes the logs in Logs table and if set to ‘UTL_FILE’, system generates the alert log file. |
| CMN_GRI_WS_DEBUG_METHOD | This parameter allows to define the location to which GRI (Generic Recovery Interface) web service logs are to be written. If set to ‘ADVANCE_QUEUE’, system writes the logs in Logs table and if set to ‘UTL_FILE’, system generates the log file. |
| UIX_CUSTOMER_BASED_PMT_IND | If this parameter is set to ‘Y’ and is ‘Enabled’, system accepts posting direct payment to an account and also accepts customer based payments to all linked accounts. To facilitate customer based payments, ‘Customer/Business #’ and ‘Payment Hierarchy’ fields along with ‘Populate Accounts’ button are enabled in ‘Payment Entry’ screen to specify required values. |
| PMT_HIERARCHY_CODE | In this parameter, you can specify a payment hierarchy which is populated by default in Customer Details and Business Details (if applicable) screen after account activation. However, the specified value is selected by default only if there is a matching hierarchy definition enabled record maintained in Setup > Administration > User > Payment Hierarchy screen. Else, ‘Equal Amount’ value is selected which in-turn adjusts the payment equally to all customer/business linked accounts. Note: System does not consider this parameter value while ‘creating account using existing customer/business details’ since the default selection is done during the creation of existing customer / business account. |
| EVI_MAX_RETRY_COUNT | This parameter, records and controls the maximum attempts to re-trigger FAILED Webhook requests which cannot exceed more than 5 times. However, this parameter can be modified if the maximum re-trigger attempts is to be less than 5 times. |
| UIX_CUSTOM_LABEL_ENABLED_IND | This parameter indicates if the field label customizations are allowed i.e. ability to change label and provide access to fields in Label Configuration and Security User Access Definition Details screens. If set to ‘Y’, system refers data from database If set to ‘N’, system refers data from XLIB file. |
| UIX_MASTER_ACC_BASED_PMT_IND | If this parameter is set to ‘Y’ and is ‘Enabled’, system accepts posting direct payment to a master account and also accepts master account based payments to all linked accounts. To facilitate master account based payments, ‘Master Account #’ field is enabled in ‘Payment Entry’ screen. |
| TPE_PMT_REFUND_CURRENCY_SRC_CD | This parameter indicates the currency in which payment refund has to be processed in the system as either ‘Payment Currency’ or ‘Account Currency’. The same is considered during payment refund operation in Payment Maintenance screen. |
| AUTO_GEN_ACTIVE_TXN_CONV | This parameter if enabled, auto posts a dummy ACTIVE transaction on all ‘migrated accounts’ during the schedule batch job run. This in-turn allows to post RESCISSION / VOID transaction specifically for migrated accounts by selecting the dummy transaction from Customer Service > Maintenance screen or Transaction History transactions tab, For more information, refer ‘Voiding an Account’ section Servicing user guides. |
| FLL_CMN_JET_JWT_ENABLED_IND (JET JWT TOKEN ENABLE INDICATOR ) | This parameter if set to ‘Y’, enables the ‘Account Dashboard’ screen in Servicing LHS menu. This screen is based on Oracle JET framework and facilitates to view Account summary details maintained in the system. For information on screen functionality, refer to Servicing User Manuals and for details on deployment and configuration, refer to Installation Manuals. |
| FLL_CMN_JET_JWT_TOKEN_URL (JET JWT TOKEN GENERATION URL ) | Define the value of the O-JET URL (app-shell application URL) in the format https://<hostname>:<port no>/ofsll-app-shell/<token> |
| FLL_SER_JET_ACC_CREATE_URL (JET SIMPLE ACCOUNT CREATE URL) | Define the value of the O-JET URL (app-shell application URL) in the format https://<hostname>:<port no>/ofsll-app-shell?root=accountonboarding |
| FLL_SER_JET_ACC_DASHBOARD_URL (JET ACCOUNT DASHBOARD URL) | Define the value of the O-JET URL (app-shell application URL) in the format https://<hostname>:<port no>/ofsll-app-shell?root=accountdetailsdashboard |
| FLL_SET_JET_INTELLIGENTSEG_URL (JET INTELLIGENT SEGMENTATION URL ) | Define the value of the O-JET URL (app-shell application URL) in the format https://<hostname>:<port no>/ofsll-app-shell?root=queuecreation |
| SYP_LINK_EXISTING_CUSTOMER (LINK CUSTOMER BY CUSTOMER NBR/ID) | During Account on-boarding/conversion process, OFSLL has capability to associated existing customer to an account using Customer ID/Customer Number. This System Parameter is used to perform existing customer Association. ‘Update Customer Info’: This filed is used to update existing customer details with new details provided as part of the new Account on-boarding request. ‘Link Existing Customer Ind’: This fields is used to link existing customer provided with new Account. If Customer ID is not provided then system searches with SSN/National ID and associate existing Customer with new Account. If Customer ID is provided, then system validates SSN/National ID and associate it with new Account. The following tables indicates the scenario on how system decides the update:
| SYP_AUTO_GEN_CUS_NBR (AUTO GENERATE CUSTOMER NUMBER FOR CONVERSION PROCESS) | During Account on-boarding/conversion process, this system parameter is used to determine if Customer Number is to be generated by OFSLL (if set as Yes) or provided by External System (if set as No). |
| SYP_AUTO_GEN_BUS_NBR (AUTO GENERATE BUSINESS NUMBER FOR CONVERSION PROCESS ) | During Account on-boarding/conversion process, this system parameter is used to determine if Business Number is to be generated by OFSLL (if set as Yes) or provided by External System (if set as No).
| SYP_AUTO_GEN_ASE_NBR (AUTO GENERATE ASSET NUMBER FOR CONVERSION PROCESS ) | During Account on-boarding/conversion process, this system parameter is used to determine if Asset Number is to be generated by OFSLL (if set as Yes) or provided by External System (if set as No). |
| UPR_PRO_NBR_SYS_GENERATED (PRODUCER NUMBER IS SYSTEM GENERATED) | During new Producer creation, this system parameter is used to determine if Producer Number is to be generated by OFSLL (if set as Yes) or provided by External System (if set as No). |
| UVN_VEN_NBR_SYS_GENERATED (VENDOR NUMBER IS SYSTEM GENERATED) | During new Vendor creation, this system parameter is used to determine if Vendor Number is to be generated by OFSLL (if set as Yes) or provided by External System (if set as No). |
Organization parameters control the functions related to User login, password expirations, responsibilities and accessibility limits in the OFSLL system. Individual parameters can be created with different values for uniquely defined organizations, divisions, and responsibility combinations.
There are three more dimensions other than parameter name, description and enabling (similar to system parameters) as indicated below:
These dimensions help to define the applicability of the responsibility for specific User in an Organization across selected Divisions/departments.
When determining which parameter to use, OFSLL system selects the best match based on a hierarchical sort by the Organization, Division, and Responsibility fields, with values of 'ALL' being a lower order match than an exact match.
While the system allows for Organization parameters to be defined at all three hierarchical levels (organization, division, and responsibility), not all will be applicable to each parameter.
| MAX_PASSWORD_HISTORY_CHECK | This is used to set limit for number of times a password has been repeated during password change. This can be set for specific branches of the Organization, Divisions and Users based on responsibilities. Numeric value to be input to specify the limit. |
| UCS_GROUP_FOLLOWUP_DAYS | This parameter is used to set up the number of days range for Group follow-up field in customer service screen which displays the set of accounts that share same account condition as the selected account and bear the same customer ID. The pre-requisite for this is Group Follow-up indicator should be enabled in queue setup. Input value is numeric. |
| UCS_REVIEW_QUEUE_ALLOWED | This is used to specify whether review can be done by the specific responsibility (user group) without entering details in call activities/activities. Parameter value to be input is Boolean (Yes/No). |
| UIX_APP_VIEW_ALL_APPS | The system uses this parameter to determine which users have the ability to view all applications. The system selects the best match based on a hierarchical sort by Organization, Division and Responsibility fields, with values of ‘ALL’ being a lower order match than an exact match. Input parameter value is Boolean (Yes/No). |
| UIX_HIDE_RESTRICTED_DATA | This is used to hide sensitive data relating to the Contract / Applicant to a specific group/responsibility etc. Suppose there is a need to hide data relating to SSN, Bank account details etc. to a specific user responsibility who will not need such data, this parameter can be enabled with input value Boolean (Yes/No). If this parameter is set to ‘Y’, the details appear in a masked format (for e.g. SSN – XXX-XX-456) |
| UIX_SMTP_SERVER | This parameter is used to set up the email server for user interface. The input value would be ‘SETME’ and check the ‘Enable’ flag. |
| UIX_VIEW_SECURED_ACCOUNTS | This is used to specify whether an account can be viewed by a specific responsibility (users). Parameter value is Boolean (Yes/No) and when flagged as Yes, such accounts would be viewable only by users defined in the Organization, Division hierarchy with the specified responsibilities. For example, all employee accounts may not be viewable by all users and should be made available only to the HR department with specific responsibility levels. |
| UIX_VIEW_SECURED_APPLICATION | This is used to specify whether an application can be viewed by a specific responsibility (users). Parameter value is Boolean (Yes/No) and when flagged as Yes, such applications would be viewable only by users defined in the Organization, Division hierarchy with the specified responsibilities. For example, all employee accounts may not be viewable by all users and should be made available only to the HR department with specific responsibility levels. |
| ULG_DAY_END | This is used to specify the upper limit time in day for a user to be able to work in the System. Parameter value is numeric and range is 1-24, else system will throw error. |
| ULG_DAY_START | This is used to specify the lower limit time in day for a user to be able to work in the System. Parameter value is numeric and range is 0-24, else system will throw error |
| ULG_FAILED_LOGIN_TRIALS_MAX | This parameter is used to specify the maximum number of login trials allowed before disabling the User ID due to security reasons. Input parameter value is numeric with upper limit of 999999999999. |
| ULG_INACTIVITY_DAYS_MAX | This parameter is used to specify the maximum number of days the User ID can be without utilization before disabling the User ID due to security reasons. Within the specified number of days the User Id must be utilized for sign in at least once. Input parameter value is numeric with upper limit of 999999999999. |
| ULG_PWD_CASE_SENSITIVE_REQ | This is used to allow all passwords to be case sensitive or otherwise. Input parameter value is Boolean (Yes/No). When this parameter is set as ‘NO’, password would be stored in Upper case. If this parameter is set to N. then the ULG_PWD_LOWER_CHAR_REQ parameter should also be set to N. |
| ULG_PWD_CHANGE_DAYS_ACTUAL | This is used to set the maximum number of days after which system will force a password change, in cases where the User has not changed the password. Input parameter value is numeric with upper limit of 999999999999. |
| ULG_PWD_CHANGE_DAYS_PROMPT | This is used to set the maximum number of days after which system will prompt the User for password change, in cases where password has not been changed within the set period. Input parameter value is numeric. |
| ULG_PWD_LENGTH_MIN | This is used to set the minimum length of password string that is required. If this criterion is not met, system would throw an alert specifying minimum character length required to be input. |
| ULG_PWD_LOWER_CHAR_REQ | This is used to allow at least one lower case character in password strings. Input value is Boolean (Yes/No). Setting this as ‘NO’ would mean passwords would be allowed in uppercase only. |
| ULG_PWD_NBR_REQ | This parameter allows setting password with at least one numeric character. Input value is Boolean (Yes/No) and setting this as ‘YES’ would require passwords to have at least one numeric character. |
| ULG_PWD_SPECIAL_CHAR_REQ | This parameter is used to allow special characters like ‘$’, ‘#’, ‘@’, in passwords. Input value is Boolean (Yes/No) and setting this as ‘YES’ would require passwords to have at least one special character. |
| ULG_PWD_UPPER_CHAR_REQ | This is used to allow at least one upper case character in password strings. Input value is Boolean (Yes/No). Setting this as ‘NO’ would mean passwords would be allowed in lowercase only. |
| ULG_WEEK_END | This parameter enables to set the last day of the week when a user can have access to the system. Input parameter value is numeric ranging from 1 to 7. This is useful in business requirements where the Organization does not need a specific set of responsibilities (users) to not access the system on a weekend / week-off day etc. |
| ULG_WEEK_START | This parameter is used to set the start day of the week when a user is allowed to access the system. Input parameter value is numeric. |
| CRB_ERROR_VALIDATION_IND | This parameter is used to validate the Credit Bureau report generation request depending on the number of days permitted to pull a Bureau report from the same company and for the same customer and report as either warning/error. When the number of days is less than or equal to the permitted days (as defined in parameter DAYS_TO_PULL_CRB_REPORT), system displays an ‘Error’ message stating ‘Bureau Report exists for the same Customer from the same Bureau for Account# XYZ’ along with list of account number(s) and/or application number(s). If not, a ‘Warning’ message is display and request is accepted for processing. Note: Both ‘CRB_ERROR_VALIDATION_IND’ and ‘DAYS_TO_PULL_CRB_REPORT’ are to be enabled for Credit Bureau report processing. |
| OCP_CUST_PMT_PREF | This parameter MASTER ACCOUNT ROLLUP FOR PMT EXTRACT FILE is used to decide the basis of dues consolidation at master account level based on the parameter values selected. For more information, refer to ‘Outbound Customer Extracts To Payment Agencies Batch’ section. |
Company parameters control the processes associated with functions that vary for different companies and branches. These parameters address credit scoring, credit bureau interfaces, fax services, and fax generation.
Individual parameters may be set up with different values for uniquely defined company and branch combinations (i.e. these can be defined to the level of branches in each company or a group of companies in terms of applicability).
| AUD_ADV_REASON_MODEL | This parameter is used to set-up default adverse action reasons for scoring models during set-up in the Parameters sub page. Whenever the flag ‘Bureau Score Reasons’ is unchecked during credit bureau scoring model set-up, then automatically rejected applications scored using this scoring model picks up the Adverse Action Reasons from the Parameters sub page. |
| AUD_SCORING_METHOD | This parameter is used to set when/where the application scoring method has to be applied within the company. So when the parameter value is chosen as ‘primary applicant only’, the system will perform the application scoring for the primary applicant only and according to other applicable parameters specified. Other parameter input values are Minimum Score, Maximum Score, Minimum Tier (Grade), Maximum Tier (Grade). |
| AUD_SCORING_METHOD_IN_BUREAU | This parameter is used to define what value to be picked up for application scoring from the scores returned from the various bureaus. The input parameter values are Maximum Score and Minimum Score. If Maximum score is set-up in company parameters, then for all applications where a bureau report is pulled, the system will pick-up the Maximum score from the different bureaus. |
| CBU_DATA_SET_SIZE | Parameter to define the metro 2 file data selection criteria, option values are monthly, Daily, weekly, semi monthly. |
| CBU_FILE_FORMAT | Metro 2 file format definition, user need to select from the parameter value drop down. |
| CMN_ASE_VALIDATE_MAKE_MODEL | This parameter is set up to specify to the system whether it needs to validate the asset make and model at the time of data entry. In parameter value is Boolean (Yes/No). |
| CMN_CMB_DEFAULT_PRINTER | This is used to define the default printer for printing. The input parameter value is the printer name. There is no LOV for this field. If no default printer is defined and the parameter enabled, the system would display ‘Undefined’. |
| CMN_WEEKLY_NONBUSINESS_DAYS | This parameter is used to set-up the weekly holidays at the company level. The input parameter value is character string; if no details specified and parameter is enabled, system would display ‘UNDEFINED’. |
| COR_STORAGE_DIRECTORY | This parameter is used to specify the path/location for Oracle directory object template for correspondence documents. Input parameter value is ‘SETME’; if none is specified and parameter enabled, ‘UNDEFINED’. |
| DBR_JOINT_INC_DEBT_WITH_2NDRY | This parameter defines whether system should consider income and debt details of the Spouse and Secondary Applicant along with that Primary Applicant. Input parameter value is Boolean (Yes/No). |
| DBR_JOINT_INC_DEBT_WITH_SPOUSE | This parameter is used to define whether system should consider the income and debt details of Spouse alone along with that of Primary applicant details. Input parameter value is Boolean (Yes/No). |
| DDP_CRB_EXPIRATION_DAYS | This parameter is used to define the credit bureau report expiration days. So if this is set as 30, system will use all available credit bureau reports pulled which are not older than 30 days from current day, during de-dupe. Input value is numeric with no upper limit. |
| DDP_DEDUP_DEBT_WITH_2NDRY | This parameter defines whether the system should de-dupe credit bureau liabilities for Spouse and Secondary Applicants, in addition to de-duping Primary applicant’s liabilities. Input parameter value is Boolean (Yes/No). |
| DDP_DEDUP_DEBT_WITH_SPOUSE | This parameter defines whether the system should de-dupe credit bureau liabilities for Spouse, in addition to de-duping Primary applicant’s liabilities. Input parameter value is Boolean (Yes/No). |
| DOT_STORAGE_DIRECTORY | This parameter is used to define the location/path of the Oracle Directory Object name for Account Document Loading. Input parameter value is ‘SETME’. |
| ECB_EDIT_FAIL_ANY_APL | This parameter is used to set the credit bureau edit to fail in case the bureau report for any of the applicant fails. Input parameter value is Boolean (Yes/No). So if this parameter is set to ‘YES’, the edit will fail even if one of the applicant’s bureau score fails to qualify. |
| ECB_USE_APL_CURRENT_SCORE_CRH | This parameter is used to define whether the system should run the credit bureau edits only on the current scored applicant bureau. Input parameter value is Boolean (Yes/No). |
| LOR_AUTOMATIC_CON_FUND_FAX | This is used to define the decision fax generation when an application is funded. The input parameter value is Boolean (Yes/No), and when this is set as ‘YES’, system automatically generates the fax approval in the pre-defined template whenever an application is approved. |
| LOG_STORAGE_DIRECTORY | This parameter is used to define the Oracle storage directory. Input parameter value is user (System Administrator) defined. |
| LOR_AUTOMATIC_APPROVAL_FAX | This is used to define the decision fax generation when an application is approved. The input parameter value is Boolean (Yes/No), and when this is set as ‘YES’, system automatically generates the fax approval in the pre-defined template whenever an application is approved. |
| LOR_AUTOMATIC_REJECTION_FAX | This is used to define the decision fax generation when an application is rejected. The input parameter value is Boolean (Yes/No), and when this is set as ‘YES’, system automatically generates the rejection fax in the pre-defined template whenever an application is declined. |
| MAX_LEAD_DAY_AGE | This parameter is used to define the maximum no. of days, post which the sales lead would be considered cold. Input parameter value is numeric with no upper limit. |
| MULTI_OFFER | Through this parameter the multiple offers (sub-tab) in pricing can be enabled or disabled for a Company/Branch. Input parameter value is Boolean (Yes/No). If the flag is set as ‘Y’, the underwriter can view multiple offers and select one of them to be applied for the specific application. |
| MULTI_OFFER_MAX_NUMBER | This parameter is used to specify the maximum number of multiple offers that can be permitted for an application. Input parameter value is numeric with no upper limit. If MULTI_OFFER company parameter is set as ‘N’, this parameter can be ignored as there is no use specifying a value. |
| MULTI_OFFER_MAX_TERM | This company parameter sets the maximum term (as in no. of instalments, whichever billing cycle is selected) for which multiple offers are calculated and displayed during pricing. Input parameter value is numeric. |
| MULTI_OFFER_MIN_TERM | This company parameter sets the minimum term (as in no. of instalments, whichever billing cycle is selected) for which multiple offers are calculated and displayed during pricing. Input parameter value is numeric. |
| MULTI_OFFER_PMT_TOLERANCE | For Multi offer variance in payment is defined in this parameter. |
| MULTI_OFFER_TERM_VAR | For multi offer Term variance will be defined in the parameter. |
| PRESENT_VALUE_COMPUTE_RATE | This parameter will perform Present Value Computation Rate (Inflation/Discounting Rate). |
| RATE_CHG_LTR_PRE_PROCESS_DAYS | This parameter is used to set up the number of days prior to rate change effective date to generate rate change letters in order to provide advance intimation to customers. Input parameter value is numeric with no upper limit. |
| STM_GEN_AFTER_MATURITY_IND | This parameter is used to enable the statement generation for an account after the maturity date but Account remains unpaid. Input parameter value is Boolean (Yes/No). If this is set to ‘Y’, statements will get generated for accounts that remain unpaid even after maturity. |
| UIX_RUN_AAI_ACT | This parameter is used by the system to determine whether to create and activate an account online. Input parameter value is Boolean (Yes/No). |
| UIX_UCS_CAC_MAX_FOLLOWUP_DAYS | This parameter is used to set up the maximum number of days for follow up when the account is in delinquent state. Input parameter value is numeric with no upper limit. |
| UIX_UCS_CAC_MAX_PROMISE_DAYS | This parameter is used to set up the maximum number of days allowed for customers who promise to pay when following up for delinquent accounts. Input parameter value is numeric. |
| AUD_QUEUE_INITIAL_CRB_FAILED | This parameter enabling will Queue the application if any bureau failed. |
| UIX_UCS_CUA_MAX_FOLLOWUP_DAYS | This parameter will allow the user to maintain the Collections maximum follow-up days that are allowed in the system. |
| XSL_TAX_INTERFACE | This parameter is used to specify the sales tax interface in OFSLL. Input parameter value is user defined. In this case it is held as ‘Manual’. |
| CMN_SYSTEM_UNDER_MAINTENANCE | This parameter specifies whether the system is under maintenance or not. Input parameter value is Boolean (Yes/No). |
| CMN_GL_POST_DT | This parameter is used to define the GL Post Date of Company in MM/DD/YYYY format. The same is also updated by Scheduler if ENABLED. |
| PTX_TXN_LAST_PURGE_DT | This parameter stores the date when transactions were purged last in the OFSLL system. Input parameter value is date. |
| PUP_TUP_LAST_PURGE_DT | This parameter stores the date when transactions upload were purged last in the OFSLL system. Input parameter value is date. |
| JSC_START_OF_BUSINESS_TIME | This parameter is used to set the start of business time. Input parameter value is time in 24 hour format. |
| CMN_PROMISE_FUTURE_MTHD | This parameter helps to define the future promise handling method in the system. When multiple ‘Promise to Pay’ records are defined on an account and if any one of the promise is not satisfied i.e. if there is no credit / Payment transaction of the corresponding amount on the promise date, then system uses any of the following method defined in this parameter to update the future promises. - No Action on future promises (default) - Mark current and future promises as broken - Mark current as broken but future promise as cancelled |
The following additional set of parameters are also available to control system specific data and other administration process.
| Parameter | Description |
| CRB_MAX_BUREAU_PULL | This parameter is used to determine the number of credit reports automatically per applicant. Input parameter value is numeric. |
| CRB_ALL_APL_BUREAU_PULL | This parameter is used to set up whether credit bureau reports should be pulled for the primary applicant only or to all other applicants also (for joint applications), regardless of their relationship with the primary applicant. Input parameter value is Boolean (Y/N). |
| CBU_FILE_FREQUENCY | This parameter is used to set the Metro II File Frequency and determine whether output file is to be generated daily or monthly. If this is monthly, then output file is written with daily data but generated monthly. |
| JOINT_DEDUP_SPOUSE_LIABILITIES | This parameter is used to determine duplicate liabilities in the Spouse’s liabilities in de-duping logic. Input parameter value is Boolean (Yes/No). |
| JOINT_DEDUP_ALLAPL_LIABILITIES | This parameter is used to determine duplicate liabilities of all applicants’ liabilities in de-duping logic, irrespective of whether they are related to each other. Input parameter value is Boolean (Yes/No). |
| ASC_COL_SER_ENABLED_IND | This parameter is used for enabling the Collection Servicing Indicator. Input parameter value is Boolean (Y/N). |
| CMN_TEST_TOOL_LOGGING | This parameter is used to set the testing tool logging to enable or disable testing tool log in. Input parameter value is Boolean (Yes/No). |
| ICA_INPUT_FILE_FORMAT | This parameter is used to specify the Input format for call activity file. Two Parameter values are possible – US format and OFSLL format. |
| JSV_BI_USER | This parameter is used to define the BI publisher User ID. Input parameter value is user defined (Admin user). |
| JSV_BI_PASSWORD | This parameter is used to define the BI publisher User password. Input parameter value is user defined (Admin user). |
| PJR_COPY_PURGED_DATA | This parameter is used to specify whether data should be copied into the purge tables or not. Input parameter value is Boolean (Yes/No). |
| PUP_ARCHIVE_DAYS | This parameter is used to specify the number of days after which the transactions upload details are to be archived. Input parameter value is numeric. |
| PUP_OARCHIVE_DAYS | This parameter is used to specify the number of days after which the transactions upload details are to be moved from ‘O’ tables. Input parameter value is numeric. |
| TPE_APPLY_LTC_FROM_CURR_DUE_DT | This parameter is used to specify whether late charge should be applied from current due date for Pyramid Law fee method. Input parameter value is Boolean (Yes/No). |
| TPE_EXCESS_PAYMENT_TO_MEMO | This parameter will make excess payment to the memo payment by marking this Parameter as YES. |
| TPE_STOP_COMP_DELQ_DAYS | This parameter is enabled to stop computation if the account is delinquent for more than 60 days. |
