When you select Individual as the search type, the Jurisdiction, Business Domain, First Name, and Last Name field specific to the individual candidate appear by default. You can perform the Real-Time Screening with and without creating a case by selecting the Search with case creation toggle button.
NOTE:
You must provide values in all mandatory
search fields to get search results. The mandatory fields are marked with
an asterisk.
For Search without case creation,
First Name and Last Name are mandatory fields.
For Search with case creation, the Jurisdiction, Business Domain,
To perform the Advanced Search, follow the subsequent steps:
1. click the
Advanced
Search icon. The Advanced Search
Parameter left pane is displayed.
2. Enter the
values in the search fields and click Apply
Filter. For more information on advanced search fields, see Table
2. Click Clear to reset the entries.
When the mandatory and advanced search
parameters are applied, the parameter entries appear in the Additional Search parameters
field in the Real-Time Screening window. For the First Name and Last
Name fields, the entries are combined and added to the Full Name in the
Additional Search parameter field.
If you want to remove any parameter, click the close button against the
parameter in the Additional Search parameters
field.
NOTE:
The First Name
and Last Name entries are deleted
when you delete the Full Name parameter from the Additional Search
parameters field. You must add the
full name via Advanced Search to add the Full Name parameter.
3. Click Search to view the search results.
4. Click Reset to clear the search fields.
The following table provides the list of search fields for individual records
Table : Search fields for Individual Records
Record Name |
Description |
Candidate pane |
Source Request ID |
Enter the unique ID for the individual. Note: The Source Request ID is used to suppress the Batch alert for a customer who has a Real-time Screening alert. |
Applicant ID |
Enter the individual's applicant ID number. You can provide alphanumeric characters. |
Jurisdiction |
Select the individual's jurisdiction. |
Business Domain |
Select the individual's business domain. |
First Name |
Enter the individual's first name. |
Middle Name |
Enter the individual's middle name. |
Last Name |
Enter the individual's last name. |
Title |
Enter the honorific used to address the individual. |
Full Name |
Enter the individual's full name. |
Alias |
Enter the alias used by the individual. |
Date Of Birth |
Enter or select the individual's date of birth. To enter the date, click inside the field. The date must be in the format MM/DD/YY. To select the date, click Calendar and select the date from the date picker. |
SSN/TIN |
Enter the individual's Social Security Number (SSN) or Tax Identification Number (TIN). |
Gender |
Select the drop-down list and then select the individual's gender. |
Primary Citizenship |
Select the drop-down list and then select the country where the individual has primary citizenship. Primary citizenship is typically related to the individual's country of birth. |
Secondary Citizenship |
Select the drop-down list and then select the country where the individual is a naturalized citizen or has legal citizenship, if applicable. |
Country Of Birth |
Select the drop-down list and then select the country where the individual was born. |
Country Of Residence |
Select the drop-down list and then select the country where the individual resides. |
Existing Internal ID |
Select the individual's internal ID. This is an unique identification number used by the individual. |
Address pane |
Select the forward icon to expand the Address pane and view the fields. |
Street Line 1 |
Enter the individual's residential address. |
City |
Enter the city in which the individual resides. |
State |
Enter the state in which the individual resides. |
Country |
Select the drop-down list and then select the country in which the individual resides. |
Postal Code |
Enter the postal code of the city where the individual resides. |
Identification Document pane |
Select the forward icon to expand the Identification Document pane view the fields. |
Document Type |
Enter the document provided to verify the individual's identity. |
Document Number |
Enter the document number of the document type provided by the individual. |
Issuing Country |
Select the drop-down list and then select the country in which the document used to verify the individual's identity is issued. |
Year of Birth |
Enter the year of birth in the format YYYY. When the Date of Birth is provided, the Year of Birth is automatically populated. In that case, the Year of Birth field is not editable. When the Year of Birth is provided without providing the date of birth, then the Year of Birth field is editable. |
NOTE:
an asterisk
For Search without case creation, First Name
fields.
Name, and Last Name
1. Click the
Advanced Search icon. The
Advanced Search Parameter left pane is displayed.
2. Enter the values in the search fields and click Apply Filter.
Table 2.
Click Clear
field.
NOTE:
When you delete the Full Name parameter
from the Additional Search parameters
field, the First Name and
Last Name entries are deleted. You
must add the full name via Advanced Search to add the Full Name parameter.
The following table provides the list of search fields for entity screening
Table 3: Search fields for Entity Records
Record Name |
Description |
Candidate pane |
Source Request ID |
Enter the unique ID for the individual. Note: The Source Request ID is used suppress the Batch alert for a customer who has a Real-time Screening alert. |
Applicant ID |
Enter the entity's applicant ID number. You can provide alphanumeric characters. |
Jurisdiction |
Select the entity's jurisdiction. |
Business Domain |
Select the entity's business domain. |
Organization Name |
Enter the entity's name. |
SSN/TIN |
Enter the entity's Taxpayer Identification Number (TIN). |
Country Of Incorporation |
Select the drop-down list and then select the country in which the entity is registered. |
Country Of Taxation |
Select the drop-down list and then select the country in which the entity is located. |
Select the entity's internal ID. This is an unique identification number used by the entity. |
Address pane |
Select forward icon to expand the Address pane and view the fields. |
Street Line 1 |
Enter the entity's residential address. |
City |
Enter the city in which the entity is located. |
State |
Enter the state in which the entity is located. |
Country |
Postal Code |
Enter the postal code of the city in which the entity is located. |
Select the forward icon to expand the Identification Document pane and view the fields. |
Document Type |
Enter the document provided to verify the entity's identity. |
Document Number |
Enter the document number of the document type provided by the entity. |
Issuing Country |
Enter the country in which the document used to verify the entity's identity is issued. |
