There are two ways to add Goods Watchlist records:
1. Add a record using the Goods Watchlist window. When you add a new record, it appears on the Goods Watchlist grid. To add Goods Watchlist records follow the subsequent steps:
a. From the Navigation List, click Transaction Filtering Management.
b. From the Navigation List, click Prohibited Goods Watchlist. The Goods Watchlist Screen displays.
c. Click Add
d. Enter values for the following fields in the Add Goods Watch List window:
The following table provides the search fields for Goods Watchlist.
Table : Search fields for Goods Watchlist
Record Name |
Description |
| Good Code | Enter the goods code. |
| Good Name | Enter the goods name. |
| Good Description | Enter the goods name. |
| Good Synonyms | Enter the goods synonyms. |
| Import CountryISO | Enter ISO code for import country. |
| Export CountryISO | Enter ISO code for export country. |
| Data Source | Enter the data source. |
| Data Source | Enter the source of data. |
| Risk Score | Enter a risk score. |
e. Click Save to save the record.
To edit a record, follow these steps:
a. Select the check box in line with the record you want to edit.
b. Click Edit
to open the Add Goods
Watchlist window.
c. Edit the required fields.
d. Click Save to save the record.
2. To add or edit Goods watchlist records in bulk, export the Goods Watchlist, add values in the applicable columns, or add a new row and provide values in the applicable columns, and upload the file. You cannot change the structure of the file.
To add watch list data using the template, follow these steps:
a. Click Export
to download the template.
b. Enter the values in the required columns and save the file.
c. Click Import
The file is uploaded and the records are displayed on the
Goods
Watchlist
grid.
