There are two ways to add Ports Watchlist records:
1. Add a record using the Ports Watchlist window. When you add a new record, it appears on the Ports Watchlist grid. To add Ports Watchlist records follow the subsequent steps:
a. From the Navigation List, click Transaction Filtering Management.
b. From the Navigation List, click Prohibited Ports Watchlist. The Ports Watchlist Screen displays.
c. Click Add
d. Enter values for the following fields in the Add Ports Watch List window:
The following table provides the search fields for Ports Watchlist.
Table : Search fields for Ports Watchlist
Record Name |
Description |
| Country Name | Enter the Country code. |
| Port Name | Enter the port name. |
| Port Code | Enter the port code. |
| Port Synonyms | Enter the port synonyms. |
| Data Origin | Enter the Origin of data. |
| Risk Score | Enter a risk score. |
e. Click Save to save the record.
To edit a record, follow these steps:
a. Select the check box in line with the record you want to edit.
b. Click Edit
to open the Add Ports
Watchlist window.
c. Edit the required fields.
d. Click Save to save the record.
2. To add or edit Ports watchlist records in bulk, export the Ports Watchlist, add values in the applicable columns, or add a new row and provide values in the applicable columns, and upload the file. You cannot change the structure of the file.
To add watch list data using the template, follow these steps:
a. Click Export
to download the template.
b. Enter the values in the required columns and save the file.
c. Click Import
The file is uploaded and the records are displayed on the
Ports
Watchlist
grid.
