There are two ways to add Stop Keywords Watchlist records:
1. Add a record using the Stop Keywords Watchlist window. When you add a new record, it appears on the Stop Keywords Watchlist grid. To add Stop Keywords Watchlist records follow the subsequent steps:
a. From the Navigation List, click Transaction Filtering Management.
b. From the Navigation List, click Stop Keywords Watchlist. The Stop Keywords Watchlist Screen displays.
c. Click Add
d. Enter values for the following fields in the Add Stop Keywords Watchlist window:
The following table provides the search fields for Stop Keywords Watchlist.
Table : Search fields for Ports Watchlist
Record Name |
Description |
| Stop Keywords | Enter the stop keyword. |
| Type | Enter the type/category of the keyword |
e. Click Save to save the record.
To edit a record, follow these steps:
a. Select the check box in line with the record you want to edit.
b. Click Edit
to open the Add Stop
c. Edit the required fields.
d. Click Save to save the record.
2. To add or edit Ports watchlist records in bulk, export the Stop Keywords Watchlist, add values in the applicable columns, or add a new row and provide values in the applicable columns, and upload the file. You cannot change the structure of the file.
To add watch list data using the template, follow these steps:
a. Click Export
to download the template.
b. Enter the values in the required columns and save the file.
c. Click Import
The file is uploaded and the records are displayed on the
Stop Keywords
Watchlist grid.
