Conversion Considerations
XER projects can store far more data than the SDEF specification requires. For example, the SDEF file structure allows for only one application of a resource per activity, while XER enables you to apply a resource to an activity repeatedly using resource lags and durations.
XER projects intended for use with the SDEF interface should comply with the SDEF specification. There is no requirement to utilize the additional capabilities that XER offers because the SDEF file structure cannot store the additional data.
Consider the following items when exchanging data between the XER and SDEF formats:
SDEF Field
XER Field or Calculation
Total Qty
Planned/Budgeted Units for the activity assignment
Cost Per Unit
Planned/Budgeted Cost divided by the Planned/Budgeted Units for the activity assignment
Qty to Date
Actual Units for the activity assignment
Activity Cost
Planned/Budgeted Cost for the activity assignment
Cost to Date
Actual Regular Cost for the assignment plus the Stored Material Cost (STMA) amount for the activity
Note: The Stored Material Cost is derived from the Activity UDF named 'STMA'. Refer to “Required User-defined Field (STMA)” for more information
Copyright © 1999, 2021
Last Published Friday, December 10, 2021
