Assigning a Status Reviewer to a WBS
Assign status reviewers to a WBS to enable reviewers to view team member activity updates, make changes to the updates, and approve or reject the updates for the selected activities in the WBS.
You only need to perform this task if the required reviewers are not set at the project level or users with Admin or Project superuser privileges.
To assign status reviewers to a WBS:
  1. Click Projects.
  2. On the Projects navigation bar, click Activities.
  3. On the Activities page:
    1. Select a WBS.
    2. In the General detail window, double-click the Status Reviewer field.
      Note: If the Status Reviewer field is not displayed, click Customize Columns or Customize View and select Status Reviewer.
  4. In the Select Status Reviewers dialog box, select the reviewers and click OK.
  5. If the WBS contains child WBSs, you are prompted with a choice to assign the status reviewers to all child WBSs in the project. Choose Yes or No.
  6. Click Save.
Tips
Related Topics
About P6 Team Member Status Updates
Configuring P6 Team Member Status Update Reviews
Working with P6 Team Member Status Updates
Selecting an Activity for Review
Reviewing Team Member Status Updates
Viewing Team Member Status Updates History
Copyright © 1999, 2024
Last Published Friday, July 26, 2024
