About Importing and Exporting Projects
You can import and export information to and from P6 using external files and then share this information with other P6 EPPM users, Oracle Primavera Contractor users, other project management tools (such as Microsoft Project and Microsoft Excel), and your organization's human resource and accounting systems. You can also use external files to archive your projects or create a backup of your database. You must have the Export Project Data project privilege to export projects.
You can import and export project data between P6 and other applications using the following file formats:
You can import and export project data every day, week, two weeks, or month by creating and configuring a project scheduled service.
Note: All project data is stored in a central database. You can also import projects using the Primavera XER format in P6 Professional.
Related Topics
Configuring Microsoft Project Templates
Configuring UN/CEFACT Templates
Configuring IPMDAR Templates
Importing Projects using Primavera XML Format
Exporting Projects using Primavera XML Format
Importing Projects using Microsoft Project XML
Exporting Projects using Microsoft Project XML
Exporting Projects using UN/CEFACT XML
Exporting Projects using IPMDAR
Exporting Projects to Excel
About Project Scheduled Services
Copyright © 1999, 2024
Last Published Friday, July 26, 2024
