To return a setting to its default value:
- Position your mouse over the setting to display the tool tip.
- Enter the Default into the field.
- On the You have unsaved changes context menu, select Save Changes.
Reviewing and Modifying Configurations for P6
Changing a Setting in the Primavera P6 Administrator
Adding Configurations to the Primavera P6 Administrator
Adding Database Instances to a Configuration in the Primavera P6 Administrator for On-Premises
Exporting Configurations Using the Command Line for On-Premises
Copyright © 1999, 2022
Last Published Wednesday, September 21, 2022
