Note: Before you begin, ensure you are using the supported version of Internet Explorer. See the Tested Configurations document for more information.
- Open Internet Explorer.
- Go to Tools, Internet Options.
- In the Internet Options dialog box, select the Security tab:
- Select Trusted sites.
- Click Sites.
- In the Trusted sites dialog box:
- Ensure the site in the Add this website to the zone field is correct. If not change it to the location for P6.
- Click Add.
- Click Close.
- In the Internet Options dialog box:
- In the Security level for this zone section, click Custom Level.
- In the Security Settings - Trusted Sites Zone dialog box:
- In the Reset custom settings section, select Medium.
- In the Run ActiveX controls and plug-ins section, select Enable.
- In the Script ActiveX marked safe for scripting section, select Enable.
- In the Downloads, File download section, select Enable.
- In the Downloads, Automatic prompting for file downloads section, select Enable.
- In the Miscellaneous, Submit non-encrypted form data section, select Enable.
- In the Scripting, Active scripting section, select Enable.
- Click Reset....
- Click Yes when the warning appears.
- Click OK to return to the Internet Options dialog box.
- Select the Privacy tab:
- In the Pop-up Blocker section, deselect the Turn on Pop-up Blocker option.
- In the Settings section, click Advanced.
- In the Advanced Privacy Settings dialog box, deselect the Overrride automatic cookie handling option.
- Click OK to exit all dialog boxes.
- Go to Tools, Compatibility View Settings.
- In the Compatibility View Settings dialog box:
- Deselect the Display all websites in Compatibility View option.
- Click Close.
- Go to Tools, F12 Developer Tools.
- In the F12 panel:
- Select the Emulation tab.
- In the Mode section, select 11 on the Document mode menu.
- From the Windows Control Panel, select Java.
- Go to the Advanced tab:
- Expand Java Plug-in.
- Select the Enable the next-generation Java Plug-in option.
Note: Depending on your Java version, this option may already be selected.
