Define a base currency (P6 Professional Only)
The base currency, by default, is U.S. dollars.
  1. Choose Admin, Currencies.
  2. Select the current base currency, then click the General tab.
  3. Type the new ID, name, and symbol over the existing values, to define the new base currency.
  4. Click the Appearance tab.
  5. Select the symbol used to separate whole values from decimal values in the currency display, for example, 500.5 or 500,5.
  6. Select the symbol used to separate groups of digits in the currency display, for example, 300,000 or 300-000.
  7. Select the number of decimal places to display in currency values, for example, none (70), one (70.1), or two (70.14).
  8. Select the format used to display positive and negative currency values.
Tip
Note
Related Topics
Currencies (P6 Professional Only)
Copyright © 1999, 2021
Last Published Tuesday, November 16, 2021
