Once you set up the EPS structure, you can add an unlimited number of projects as follows:
- Choose Enterprise, Projects, then select the EPS node or root element to which you want to add a project.
- Click
on the Edit Toolbar or choose Edit, Add. - Follow the instructions in the Create a New Project Wizard.
To quickly add a new project using the default settings, click Finish on the Create a New Project Wizard. - Use the detail tabs across the bottom of the Project window to add details specific to this project.
