Add Then and Else statements
  1. Choose Tools, Global Change.
  2. Click New, or select an existing specification and click Modify.
  3. Click in the Then section to define a Then statement and in the Else section to define an Else statement.
  4. Click Add.
  5. In the Parameter field, select a data item.
  6. In the Parameter/Value field, select a data item to use as the first parameter in the statement. Select Custom to type a text or numeric value.
  7. Select an operator to define an arithmetic equation to change numeric data.
    Arithmetic operators can connect two data items, a data item and a number, or two numbers.
  8. Depending on the data items selected for the first parameter, either type a value in the second Parameter/Value field, or select it from a predefined list.
    If the first parameter requires a valued definition rather than a second parameter, you can leave this field empty.
Note
Related Topics
Else: statement
Then: statement
If: statement
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
