- Choose Project, Activities.
- Choose View, Filter By, Customize.
- Mark the checkbox next to the filter you want to apply.
To preview your changes, click Apply.
Tip
- Combine existing filters to narrow the activities selected. Use any combination of default, global, layout, and user-defined filters. For example, combine the Critical and Milestone filters to view critical start and finish milestone activities in the layout.
