Assign resource codes and values
  1. Choose Enterprise, Resources, then select the resource to which you want to assign a code and value.
  2. Click the Codes tab.
  3. Click Assign.
  4. Select the resource code value you want to assign.
    You can only assign one value per code.
  5. Click Assign, then click Close.
Tips
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
