- Select the work product or document.
- Display WP & Doc Details, then click the Assignments tab.
- Click Assign.
- Select the activity or WBS element to which you want to assign the selected document, then click the Assign button.
- Click
Note
- You can select only WBS elements or activities that belong to the project for which the work product or document was created.
