Bars dialog box
Use the Bars dialog box to specify the style and labels for the bars in a Gantt Chart.
The Bars dialog box contains the following tabs:
In addition, the following fields and buttons are available in the Bars dialog box:
Display: Mark to display the corresponding bar in the Gantt Chart.
Name: The bar name; this does not display in the layout. Double-click to change the bar name.
Timescale: The timescaled data that the bar represents. Double-click the timescale to change it.
Filter: The filter applied to the data item represented by the bar type. Double-click the filter to change it.
Preview: Shows how the bar will appear.
Apply: Click to preview your changes without closing this dialog box.
Add: Click to add a bar to the current layout.
Delete: Click to delete the selected bar. To remove a specific bar from the layout display without deleting it, clear the Display checkbox next to the bar.
Copy From: (Activity Layouts only) To apply Gantt Chart settings from another layout to the current activity layout, click this button.
ShiftUp: Click to move the selected bar up one position.
ShiftDown: Click to move the selected bar down one position.
Options: Click to specify Gantt Chart background line and legend options.
Default: Click to apply the default Gantt Chart settings.
Related Topics
More Detail: Specifying a bar's timescale
Bar Labels tab - Bars dialog box
Bar Settings tab - Bars dialog box
Bar Style tab - Bars dialog box
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
