Baseline Duplicates dialog box
Use the Baseline Duplicates dialog box to choose whether to renumber selected activity IDs in the baselines when you are renumbering activity IDs.
The top section of this dialog box lists baselines associated with the current project that P6 Professional will not update because doing so would create duplicate activity IDs; P6 Professional does not update activity IDs in a baseline if it detects that doing so would create duplicate activity IDs.
The bottom section of this dialog box presents you with a Yes or No choice whether to continue renumbering.
Note
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
