Copy an EPS node or project
  1. Choose Enterprise, Projects, then select the EPS node or project you want to copy.
  2. Choose Edit, Copy.
  3. Click the location in the EPS where you want to paste the new EPS node/project.
  4. Choose Edit, Paste.
  5. Mark the checkboxes beside any optional information you want to include in the copied EPS node or project in the Copy Project Options, Copy WBS Options, and Copy Activity Options dialog boxes.
Notes:
Tip
When you select an EPS node to copy, all of the selected EPS node’s subordinate EPS nodes/projects are also copied, even if you do not select them.
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
