Create a project calendar
  1. Choose Enterprise, Calendars, then choose Project.
  2. If more than one project is open, select the projects to which you want to add a calendar, then click Add.
  3. Select the calendar you want to copy for the new project calendar, then click the Select button.
  4. Type the new calendar's name.
  5. Click Modify and edit the new calendar.
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
