Currencies dialog box (P6 Professional Only)
Use the Currencies dialog box to set up the currencies you want to use for costs. To display this dialog box, choose Admin, Currencies. The top portion of the Currencies dialog box contains the following elements:
Display Options bar: Click to search for a currency or print the list of currencies.
Base: Indicates the currency used to store costs in the database. You cannot mark or clear this checkbox. The base currency can be edited but not deleted. The base currency ID, name, and symbol default to U.S. dollars. The exchange rate for the base currency is always 1.0.
Currency ID: The identifiers for all defined currencies.
Currency Name: The names of all defined currencies.
Currency Symbol: The symbol used to identify each defined currency.
Exchange Rate: The exchange rate between the selected currency and the base currency.
The lower portion of the Currencies dialog box is divided into the following tabs:
In addition, the following buttons are always available in the Currencies dialog box:
Add: Adds a new currency.
Delete: Deletes the selected currency.
Note
Related Topics
Appearance tab - Currencies dialog box (P6 Professional Only)
General tab - Currencies dialog box (P6 Professional Only)
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
