Define Resource Shifts dialog box
Use the Define Resource Shifts dialog box to view or modify the work schedule for a shift calendar.
Shifts can be divided into segments. The total shift hours must add up to 24 hours, and each shift segment must have a duration of at least one hour. The start hour must begin and end on the hour, for example, 8:00, rather than 8:30 A.M.
Define Shifts
Shift: Lists a reference number for each segment of a shift.
Start Hour: Enter the start hour for the selected segment of the shift.
Duration (Hrs): Specifies the duration of each segment of the shift.
Add: Adds a segment to the shift.
Delete: Delete the selected segment of the shift.
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
