Delete an OBS element
  1. Choose Enterprise, OBS.
  2. Click the OBS Name column label to display the OBS hierarchy.
  3. Select the OBS element you want to delete, then click Del/Merge.
    If the OBS element you want to delete has work breakdown structure (WBS), issue or threshold assignments, you are prompted to merge the element with its parent OBS.
  4. Click Yes.
Note
Related Topics
Edit an OBS element
Parent Element
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
