Edit role codes
  1. Choose Enterprise, Role Codes.
  2. Click Modify.
  3. Select the role code you want to edit.
    To change the role code's name, type a new name.
    To change the maximum number of characters the code's values may have, specify a new number.
    To change the placement of the code in the list, click Shift Up or Shift Down.
  4. Click Close.
Tip
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
