Enterprise Project Structure dialog box
Use the Enterprise Project Structure (EPS) dialog box to define the EPS—the hierarchical structure of your database of projects.
Display Options bar: Click to change the EPS display. You can show or hide EPS details at the bottom of the dialog box, view the EPS as a table or chart, customize the columns in the hierarchy, and change the font and colors of the table or chart.
EPS Table: Displays EPS elements. To sort the display, click a column label.
EPS ID: Identifies the selected EPS node. You can type a new ID.
EPS Name: Description of the selected EPS node. You can type a new name.
Responsible Manager: Use this field to select an OBS element to associate with the selected level of the EPS.
Add: Adds an EPS element.
Delete: Deletes the selected EPS element.
Cut: Removes the selected element from the EPS.
Copy: Copies the selected element.
Paste: Pastes an EPS element that you have either copied or cut back into the hierarchy.
Arrows: Change the selected element's position in the EPS.
Related Topics
EPS node
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
