Exporting a layout
- In the Project menu, choose Activities, or Resource Assignments, or WBS to open the respective layout. Or, choose Enterprise, Projects to open a project layout.
- Choose View, Layout, Open.
You can also click the Layout Options bar and choose Layout, Open.
You are prompted you to save the current layout. - Highlight the layout you would like to export.
- Click Export. Browse to the location where to save the . plf file.
- Click Save.
Importing a layout
You are prompted you to save the current layout. - Click Import. The application responds by prompting you to choose a . plf file.
- In the Import Layout As dialog box, type an appropriate name for the layout.
- In the Available To field, select a user category. Depending on your privileges, you will be able to choose All Users, Another User, Current User, or Project.
- If you selected Another User, in the User field, click
to specify a user. The Select User dialog box displays. - If you selected Project, in the Project field, click
to specify a project. The Select Project dialog box displays.
Note: Only currently opened projects will appear in the Select Project dialog box.
- Click Save.
